Old 03-22-2014, 10:02 AM   #113
Sonolin
Where are you seeing/hearing this at?
Nowhere just heresay.
Sonolin is offline   Reply With Quote
Old 03-22-2014, 11:19 AM   #114
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Sonolin View Post
Good to know.
Also note, it took no effort to pull the .bin from a .dev loaded tune. Even the "locked" tunes are not encrypted and don't have write-protect.
The one thing I noticed about his dyno numbers compared to Shiv's was that their torque are well within the expected variance due to different setups (not that I am saying the difference leaves the OFT300 with an inherent advantage). They were within 9-16 wh/tq of each other.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Sonolin (03-22-2014)
Old 03-22-2014, 12:53 PM   #115
Sonolin
Thanks.
I thought his dyno looked very good and exactly what I expected, I just heard something about the files being locked around the ft86 campfire koolaid circle.
(I'm running on no sleep sue me )
Old 03-22-2014, 12:57 PM   #116
Sonolin
So, all that being said, can anybody download the oft300 .bin files?
Shiv can I take a look by any chance? I'd be curious to what a N/A map vs. a supercharged map would look like
Old 03-22-2014, 02:44 PM   #117
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Still trying to figure that out... Shiv only had a catback while mine had a full headerback exhaust. Ofh and borla seem to be Similar in design.
cjsporl1996 is offline   Reply With Quote
Old 03-22-2014, 02:47 PM   #118
Luckrider
Luckrider's Avatar
I think the dynos are the real big difference here which is why the wheel-torque is so different. Your number sound low compared to the base tune that comes with the full vortech kit so I think it is yours. Shiv's fit pretty well in line with what I have seen for other vortech dynos. It is for this reason that I make such specific not of the wheel torque produced.
Edit: I have not even been slightly trained in it, but if I had to guess, there was something off with the weather correction of the mustang. That, or the systems really are more different than I though.
Old 03-22-2014, 02:51 PM   #119
cjsporl1996
I will have more dyno results. We are testing different pulleys at the moment trying to see how far we can go on the stock engine. Eventually getting down to the 3.125 pulley if possible. Other plans as well. I'll give a hint. Supercharger+supercharger+ built block
The Following User Says Thank You to cjsporl1996 For This Useful Post:
Luckrider (03-22-2014)
Old 03-22-2014, 03:19 PM   #120
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You can't compare results from a dynojet to a mustang dyno since they measure output differently. The mustang dyno is also subject to setup error when dyno operators use a wheelspeed factor (common practice) to estimate engine speed instead of an optical or ignition pickup which takes a bit more time. This is probably why it shows peak hp at lower rpm.
Fwiw, our test car make 240-245whp on a mustang dyno the day before it made 275-280whp on a dynojet.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-24-2014), Luckrider (03-22-2014)
Old 09-20-2014, 03:40 AM   #121
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I am very much considering purchasing OFT300... will the stock exhaust system (other than OFH) be very restrictive?
2much is offline   Reply With Quote
Old 09-20-2014, 01:59 PM   #122
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Originally Posted by Shiv@Openflash View Post
This is correct. You can still purchase the Vortech kit alone using the OFT dollar discount you earned with the OFT purchase. If you are running another header, you may need to custom tune the map slightly for optimal performance. The main reasons we recommend the OpenFlash Header is because it works, is well built, fairly priced and was a part of the OTS map development. Our goal was to creat a forced induction kit offering that doesn't require any custom tuning or additional fiddling. And using the parts that we recommend allows for just this.
Substitute components can complicate matters a bit. But in the case of using another header, I think the issues are minimal.
Makes sense.
Wondering how screwed I am if I want to buy the OFT and Vortec SC but already have my own header and exhaust (JDL UEL header, JDL overpipe with no cat + HKS mid pipe with one cat + HKS Hi Power exhaust).
Totally custom tune needed? How easy to work something out with an OFT tune?
Trying to look for an easy, reliable 'system' as close as possible to being 'plug & play' and foolproof but the lack of one cat is really doing me in when it comes to most 'package' kits.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-20-2014, 05:19 PM   #123
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by ultra View Post
Makes sense.
Not a problem. Our oft300 maps is intended for use with our OFH UEL header. It will work fine with your mods. I always review preliminary datalogs to ensure that all new oft300 users are running safely.
Mike86 (09-29-2014), ultra (09-24-2014)
Old 10-03-2014, 11:13 AM   #124
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Guessing OFT350 is Vortech kit on corn juice? Looking forward to the unveiling.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 10-03-2014, 11:34 AM   #125
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Was this anounced anywhere?
bee_are_zee is offline   Reply With Quote
Old 10-06-2014, 09:12 PM   #126
Luckrider
Luckrider's Avatar
Look at Shiv's signature.
Introducing, the widow. IloveBaldEagles Member's Car Journals 7 05-02-2014 11:47 AM
Introducing myself fz6r Scion FR-S / Toyota 86 GT86 General Forum 11 02-14-2014 02:54 PM
Introducing myself and my FRS Apes Six Scion FR-S / Toyota 86 GT86 General Forum 11 07-12-2013 04:51 AM
Introducing the PHR Clutchline Powerhouse Racing Engine, Exhaust, Transmission 12 09-11-2012 05:47 PM
Officially Introducing The Audi A1 vh_supra26 Other Vehicles & General Automotive Discussions 26 06-23-2011 01:19 AM
