Old 03-21-2014, 03:21 PM   #43
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The color of oil is irrelevant. You can't determine the life of the oil by looking at the color. If it's black, that means it's working.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
mav1178 (03-21-2014)
Old 03-21-2014, 04:17 PM   #44
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by ecko04 View Post
What's the point you're attempting to make?
One is a used oil and the other isn't. Furthermore, they're both different brands of oil.
Oil color has nothing to do with amount of wear. Used oil will not be the same color as when it was poured.
Originally Posted by wparsons View Post
The point that someone was making was that oil at 100 miles will look very similar to oil at 1000+ miles, and neither will look like it did when it was poured in.
Oil with ANY use will be darker than virgin oil, that's why colour isn't a good indication of how much life is left.
The point I was trying to make, is what is stated below:
-alex
Old 03-21-2014, 04:24 PM   #45
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
BRZ Battery died, when I tried starting it it made a terrible noise.
-alex
Basically the point I made an earlier post...gotcha
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
Old 03-21-2014, 04:27 PM   #46
mav1178
mav1178's Avatar
Never hurts to have visuals to back up what you are stating... and I was trying to back up what you were stating.
FWIW: my ENEOS after 7500 miles looks just like the 1600-mile factory fill oil.
Same shade of black.
-alex
Old 03-21-2014, 04:36 PM   #47
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
-alex
I don't think I've ran my ENEOS to 7500. I still change mine at 3000.
Old 03-22-2014, 12:05 AM   #48
Poodles
Drives: 2015 Series.Blue
3000 miles is far too short for an oil change on any modern oil. Yes, changing your oil too often can actually cause more damage.
Anyway, curious to see more about the OP's car cause it sounds crazy...
Old 03-22-2014, 12:09 AM   #49
Malt
Drives: 2015 WRX
With the exception of break in oil, the only thing that gets damaged when changing your oil to often is your bank account.
Malt is offline   Reply With Quote
Old 03-22-2014, 12:49 AM   #50
Poodles
Incorrect, as the additive package takes time to actually function. It's in one of the SAE papers that I regrettably can't link as you have to pay for it (which is stupid)
They even repeated the test because they thought it couldn't possibly be true, but it actually caused more wear to change too often. 3000 miles probably isn't too short, but you're throwing money away if you're changing your oil that often these days.
Old 03-22-2014, 01:30 AM   #51
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Everyone has their opinion. My UOAs say I can run longer, I don't want to so I won't.
Old 03-24-2014, 04:51 PM   #52
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Well it looks like I'm under warranty. It turns out that the bearing I found is from the roller/lifter. The mechanic said that he plans on getting some pictures of the broken parts.
cmspooner is offline   Reply With Quote
The Following 5 Users Say Thank You to cmspooner For This Useful Post:
codesplice (03-24-2014), mav1178 (03-24-2014), SirBrass (04-14-2014), woode (03-24-2014), wparsons (03-24-2014)
Old 03-24-2014, 07:01 PM   #53
xwd
Did you ever have any warranty service before?
Old 03-24-2014, 07:18 PM   #54
cmspooner
cmspooner's Avatar
Nothing on the engine. I got my rear lamps done and the driver window seal was malformed.
Old 03-28-2014, 10:54 AM   #55
cmspooner
cmspooner's Avatar
Well I apparently put the number 4 piston through the side of the block. They say they engine was over-reved (which it wasn't); but they are covering it...so I'm not arguing.
Old 03-28-2014, 11:07 AM   #56
gramicci101
Off Topic
You'd have to over-rev the shit out of it to do that, and I don't think the starter is that powerful. I'm glad they're replacing it under warranty though.
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Died out at light Legacy Issues | Warranty | Recalls / TSB 12 05-29-2013 12:27 AM
I made a terrible mistake in buying an FR-S for my wife. Storm_Trooper Scion FR-S / Toyota 86 GT86 General Forum 20 01-18-2013 01:20 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
