Old 03-20-2014, 12:19 AM   #15
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by cmspooner View Post
It was pretty awful...imagine putting metal ball bearings in a blender
was their no distinct event that happened before ? like a loud pop or something? or did it just immediately go to marbles sound?
86-tundra is offline   Reply With Quote
Old 03-20-2014, 08:03 AM   #16
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
The lighting is bad since it was dark out.
I get oil changes every 5000 miles.
The sound was marbles on the failed start, no pops or anything that I noticed.
cmspooner is offline   Reply With Quote
Old 03-20-2014, 08:17 AM   #17
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Has it been a long time since you started the car or have you been driving it and this all the sudden happened? What caused your battery to die?
industrial is offline   Reply With Quote
Old 03-20-2014, 08:38 AM   #18
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I'm inclined to thing you've got a blown motor based on the tiny amount of evidence presented. I hope I'm wrong, for your sake. Good luck!
The car was running fine last time it was driven? how long has it been sitting? What killed the battery?
I don't recognize those bits in the second pic...
AdrianG is offline   Reply With Quote
Old 03-20-2014, 09:18 AM   #19
Malt
Drives: 2015 WRX
Originally Posted by 6speed_Sam View Post
Is it just the picture or is your oil really that dark? 5k miles on an oil change should not even be that dark.
For the record, the color of the oil is not a good indication of how used the oil is or if it needs to be changed. This is a pretty common misconception.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
MagicBobert (06-17-2014)
Old 03-20-2014, 09:22 AM   #20
cmspooner
cmspooner's Avatar
I had just driven it and stopped to run an errand; actually to buy a different USB hub for my android stereo that I just installed. I was plugging everything in and testing with the car in Acc mode; which is what I thought killed the battery (it was only a few minutes in Acc mode; but I killed the battery during the install on Saturday).
Old 03-20-2014, 01:36 PM   #21
celica73
do you have an aftermarket crank pulley? That's not a connecting rod or main bearing. Not sure if that little piece is a roller bearing or a press-in pin for something.
Old 03-20-2014, 01:59 PM   #22
cmspooner
cmspooner's Avatar
I have not done crank-pulley yet...they only things that I have directly on the engine are a perrin intake and perrin silicone tube and quick change oil valve.
I called and they told me that they are currently inventorying my aftermarket parts to send to Subaru of America (I assume they mean they are trying to find a way to weasel out of paying for the repair, whatever it may be).
Old 03-20-2014, 02:21 PM   #23
wparsons
wparsons's Avatar
Was it a sound like this?
[ame="https://www.youtube.com/watch?v=YhhycnO14Ko"]Car wont Start, Fast clicking noise (Solved! Solution in the description) - YouTube[/ame]
flickr
G-Man (03-20-2014)
Old 03-20-2014, 02:25 PM   #24
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Those pieces look like rod bearings for some reason....
Interested to see the outcome.
N1rve
Old 03-20-2014, 02:27 PM   #25
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
word to the wise, never tow directly to a stealership. Bring you car home, reinstall OEM parts.
It doesn't seem like an engine bearing of any sort. As someone said, some sort of press-in type pin.
I'm really leaning towards your quick change oil valve. Looks like a part inside that valve that blew out or something (hence the oil).
Jason@DSG is offline   Reply With Quote
Old 03-20-2014, 02:32 PM   #26
Jason@DSG
Jason@DSG's Avatar
Rod bearings are WAY bigger than that. Google image rod bearings and you'll see
The Following User Says Thank You to Jason@DSG For This Useful Post:
wparsons (03-20-2014)
Old 03-20-2014, 02:37 PM   #27
cmspooner
cmspooner's Avatar
It was definitely not the starter solenoid...the sound was way more mechanical...the sound or starting should not of come from the valve...plus only a a quart or so leaked out.
Old 03-20-2014, 02:46 PM   #28
N1rve
N1rve's Avatar
I said for some reason...
N1rve
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Died out at light Legacy Issues | Warranty | Recalls / TSB 12 05-29-2013 12:27 AM
I made a terrible mistake in buying an FR-S for my wife. Storm_Trooper Scion FR-S / Toyota 86 GT86 General Forum 20 01-18-2013 01:20 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
