Old 03-20-2014, 07:59 AM   #841
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by DylanFRS View Post
Ugh, i just got my Koseis w/ tires mounted from Tirerack with those stupid stems in them. I really don't like the metal valve stems because I have more troubles quickly checking pressures with them too.
I liked them, made checking easier as the stem didn't move around. But then that happened...
I think Steven did it on purpose as I stood a chance of catching him that day. He ensured I couldn't make run 4 to catch him hahah
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
ViperASR (03-21-2014)
Old 03-20-2014, 08:18 AM   #842
zohaib
Wrong Wheel Drive :(
zohaib's Avatar
Drives: FiST
It's probably in this thread, but I'm lazy; what's a good compromised brake pad? My BRZ is a daily drive+CS autocrosser, and I don't want a squealy pad. I used to run EBC Yellowstuff on my G20, and Hawk HP+ on my MR2, and they were squealy on the road. I've never used the Hawk HPS and the EBC Redstuff brakes wear down like a ding dong in a prostitute. Recommendations?
Ford Fiesta STmountune
wrong wheel drive club of america
zohaib is offline   Reply With Quote
Old 03-20-2014, 08:23 AM   #843
Kido1986
Dodging cones
Kido1986's Avatar
I would highyl recommend Ferodo DS2500 for a daily'd autocross twin. Absolutely love them on my car. @ViperASR will attest to the fact that this thing stops quicker than his STR S2000. And repeatedly. I suggest doing brake fluid too with something trackday-worthy.
Old 03-20-2014, 09:10 AM   #844
mla163
Overthinking it
Drives: BRZ in CS
+1 for Ferodo as a "compromise" pad. They don't squeal. The downside is price, dust, and they need a little warmth to work on cold days. I took mine off for the winter.
But they are a very good track / autocross pad.
mla163 is offline   Reply With Quote
Old 03-20-2014, 09:24 AM   #845
zohaib
zohaib's Avatar
Drives: FiST
Price I don't mind too much, and dust doesn't bother me because I keep my car clean. How bad are they in the cold? I don't want to be switching pads around every few months. Laziness and all.
Old 03-20-2014, 09:54 AM   #846
Kido1986
Dodging cones
Kido1986's Avatar
I need minor heat to work in my experience. I drag them up to my first run and they are perfect by the time I hit the brakes for the 2nd time. The first braking zone of the day is that only time they aren't 90%+
These are light on dust compared to every other decent performance pad I've seen. In the 30s, they work well, haven't been in anything colder. Slight squeal for first 2-3 stops then silence.
zohaib (03-20-2014)
Old 03-20-2014, 11:02 AM   #847
SeanRTR
C-Street AutoX
SeanRTR's Avatar
For likely half the price, I've been very happy with the Stoptech Performance pads. Not nearly as aggressive as a Hawk HP+, but slightly more aggressive and better for light track day duty compared to a Hawk HPS. I haven't personally run EBC Yellow's, or Ferrodo so I can't quite compare. I ran these pads all summer/winter. Dust is minimal, but it's there. They squeaked slightly after a track day, but went away after a few days. Strongly recommended.
SeanRTR is offline   Reply With Quote
The Following User Says Thank You to SeanRTR For This Useful Post:
zohaib (03-20-2014)
Old 03-20-2014, 11:45 AM   #848
zohaib
zohaib's Avatar
Drives: FiST
Thanks guys! I'll keep it in consideration. I'll try to drive a few different cars this season and see if I like anything else. Worse case I gotta get a second set of pads, right?
Old 03-20-2014, 11:57 AM   #849
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
and clean your car/wheels before the paint gets fucked.
The Following User Says Thank You to 7thgear For This Useful Post:
zohaib (03-20-2014)
Old 03-20-2014, 12:27 PM   #850
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I love the Ferodo DS2500s. They're quiet but definitely let off a lot of brake dust.
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
zohaib (03-20-2014)
Old 03-20-2014, 12:36 PM   #851
Kido1986
Dodging cones
Kido1986's Avatar
I feel they aren't all that dusty but I came to Ferodo from Carbotech. Then again, coal mining is relatively dustless compared to (admittedly awesome) Carbotech pads
zohaib (03-20-2014)
Old 03-20-2014, 12:39 PM   #852
vroom4
I thought your autocross wheels were supposed to be black when you took them off, that saves you from marking which ones were on the front last event!
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
zohaib (03-20-2014)
Old 03-20-2014, 01:30 PM   #853
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
+2 (or +3) on the DS2500’s. Work great for auto-x as others have stated.
I’ve run them all winter and they are fine on the street through all kinds of nasty conditions – at least as much as I can tell on Michelin X-ICE’s – you just have to be conscious that you will have a little bit of non-linearity with pad temperature. For example, on my commute I have a long straight off ramp that ends in a traffic light with several miles of zero braking before hand – with constant brake pedal pressure you can actually feel the braking force pick up a little bit as you slow – the initial bite is still fine (could immediately engage ABS if I wanted/needed to) and some drivers might not even notice it happening.
They do make more noise at <20 F, but mostly at parking lot speeds and the noise is very mild.
More dust than stock, but nothing I would complain about. I have no experience with the others mentioned, though, so ymmv/etc.
jdrxb9 is offline   Reply With Quote
Old 03-20-2014, 01:34 PM   #854
jdrxb9
jdrxb9's Avatar
Originally Posted by 7thgear View Post
yeah my front bumper has eaten a lot of cones, it ain't pretty.
Is it this bad?
I just noticed it has jumped my 'stop hole' Still, this happened early last year and hasn't gotten too much worse. I’m considering it an example of how to use the car properly and don’t plan to replace it until I really have to.
I did end up replacing both front wheel well liners over the course of last year – they each ended up dragging on the wheels/tires.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
