#57 | |
Drives: Subaru BRZ Limited
http://ae64.com/Rear-camera-16-pin.htm I got it installed at Best Buy for $70ish. They were extremely fast and the install was very clean. Total for everything purchased and installed was about $200ish. Not that bad for a great upgrade!
| The Following User Says Thank You to ericmpena For This Useful Post: | JS + BRZ (03-20-2014) |
#58 | |
Drives: Subaru BRZ 2014 Limited WRB
That was probably me, and you may be right--maybe it is only the knock-off ones. I have seen clear side marker condensation myself in a parking lot BRZ, but did not ask the driver if those were Helix or OEM. |
| The Following User Says Thank You to zinzan For This Useful Post: | roroskis (03-20-2014) |
#59 | |
Drives: 2010 MS3
I'll look into the parts and get them installed! Thanks for the info man. Appreciate it. |
#60 |
Drives: 2014 Subaru BRZ
#61 |
Drives: 2013 Raven Scion FR-S
I really like this thread. One thing I would highly recommend if you plan to do any work under-the-hood is GrimmSpeed Hood Struts - $114.39 @ FT86SpeedFactory.com. Gives you a lot more lift on your hood than the OEM prop and look awesome.
#62 | ||
Drives: 2013 BRZ Limited WRB
Sent from my SGH-I337M using Tapatalk
#63 |
Drives: 2003 S2000, 2008 Fit
For those who don't like the BRZ silver dash trim, just get a couple cans of plastidip.
It is cheap enough that you can change it up, and it isn't permanent, so you can remove it if you wish. Takes some practice though (I haven't got it down yet). |
| The Following User Says Thank You to daiheadjai For This Useful Post: | Frank5364 (04-14-2014) |
#64 |
Coffee Snob
Drives: '14 SWP BRZ Limited
#65 |
Drives: 2013 Asphalt FR-S
I work at a Best Buy in Texas and receive a 50% discount on the parts and intsallation fees. They put in my amp, subwoofer, and dynamat. Geek Squad does very clean installs.
#66 |
Getting Best Buy to do the backup camera installation never occurred to me, and I've been waiting 5 weeks for the harness guy SVXdc to reply to my last email. (ironically, he's less than 10 miles away from me here in Atlanta, but unresponsive). I've pulled out the head unit myself to test the camera, but haven't yet fully run the wires or drilled the mounting hole.
Do you just give them them the camera and they do all that stuff? Or do you also provide them downloaded instructions? Do they modify the OEM harness, or use their own installation pieces as necessary? -Z |
#67 | ||
| The Following User Says Thank You to Simon99 For This Useful Post: | zinzan (03-20-2014) |
#68 | |
Drives: swp brz limited
The way you hop with both feet into Internet group think is kind of adorable. Most of us... The landscape for automotive electronics has changed alot in the last 10 years. Blanket statements are pretty certainly wrong. And it's wierd the way people like to be so sure of things |
#69 | |
#70 | |
I've contacted QwikValve after lots of interest from members regarding the Fumoto valve.. any ideas how a member can setup a groupbuy for other members ? They told me we get 10% off if we get 25 interested and I'm sure that easy to get !
| The Following User Says Thank You to Simon99 For This Useful Post: | Churnobyl (04-13-2014) |
| BRZ Basic SQ Build | hellyvin | Electronics | Audio | NAV | Infotainment | 13 | 07-22-2014 12:25 AM |
| Basic STX build? | Kodi | Tracking / Autocross / HPDE / Drifting | 22 | 02-04-2014 09:50 AM |
| Taniguchi shows basic technique | m.box.design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 10-25-2013 10:47 PM |
| What basic tool set to get? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 09-05-2013 11:46 AM |
| Visual Basic and SQL | Trashed675 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 06-10-2013 12:18 PM |
