Brian@Vortech
Old 03-19-2014, 01:17 AM   #309
Frs32907
Drives: Asphalt grey, manual Fr-S
Do you need a maf to tune with this kit or can you remove it and tune without it using ecutek
Frs32907 is offline   Reply With Quote
Old 03-19-2014, 01:29 AM   #310
nelsmar
This question literally makes no sense whatsoever.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
ramiram1984 (03-19-2014)
Old 03-19-2014, 01:58 AM   #311
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by nelsmar View Post
the "new" setup has been the only setup. There are however two setups. A standard and a race version. The race version uses oil fed from the engine and can rev higher than the standard unit. The standard unit will probably work for 98% of people as it his quite a bit of overhead on it. Upwards of 400WHP on E85 can be achieved with the standard unit. However OFT currently doesn't support non MAF based tuning so there is a tuning limitation. This post is about vortech switching the actual blower as the original unit was different on the original release. I don't know of anyone that has had the original unit as they offered to replace anyone who had the original with the new one.
The OFT should have no problem supporting up to 12psi with the Vortech hardware. There is quite a bit of headroom with the factory MAF thanks to the larger-than-stock diameter MAF housing.
Shiv@Openflash is offline   Reply With Quote
Old 03-19-2014, 02:41 AM   #312
Sniper2606
Sniper2606's Avatar
Not to bring this thread down but is it true the SC kit only comes with a 90 day warranty?
I called last week because the idler pulley has been making some chirping noise and also to find a fix for the tube grinding on the blower pulley before it shreds the belt. http://www.ft86club.com/forums/showthread.php?t=41080
I was told that you guys are not using the gates idler pulley anymore but now the Ford F8KZ-8678-AA and ill will have to buy it to fix the issue.... ($40) I didn't ask about the new redesigned tube price since apparently i cannot get it replace for free, even tho its pretty much a factory fault for having it so close to the belt/pulley.
Of course its my fault, I should of done the research on the warranty before purchasing, but im just staggered by this limited warranty.
1 year warranty wouldn't hurt, specially for early adopters.
P.S. Note that a new fuel pump has been replace by Subaru 2 months ago due to the know chirping issue, i checked with a stethoscope new fuel pump is doing fine.
Sniper2606 is offline   Reply With Quote
Old 03-19-2014, 03:41 AM   #313
nelsmar
Yes I am quite familiar with the maf capabilities of the vortech unit which is a big reason as to why it is my preferred recommendation due to simplicity. However I was referencing the race unit. The race unit can spin to iirc 62krpm vs 50krpm. Depending on your setup at atmospheric conditions typically the 3.125" pulley at sea level would likely be in the 4.9-5v range at stock rev limit which is more than I am comfortable with. Both you and I have spent lots of time with the vortech unite and both seen upwards of 4.8v on the stock pulley. And yes I am familiar with how much of a gap there is between 4.8 and 5.0. The race unit is intended for those wanting to go below the 3.00" pulley in which you would be pushing the limits of the maf extremely quickly. And although you could hack tables by over fueling via rpm and a fixed load I personally would prefer switching to speed density. But it's all up to your tuners preference.
Sorry if my post came out referencing oft not bring able to support more than the stock pulley. I was mostly refrencing the upgraded unit.
Old 03-19-2014, 07:33 AM   #314
DJCarbine
Thupercharged
DJCarbine's Avatar
Did you get the warranty information in the kit?
Pretty sure its a 1 year limited warranty with an optional 3 year 36000 mile powertrain warranty (with limitations)
Did you fill out your warranty registration card and read over the terms and conditions?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 03-19-2014, 11:19 AM   #315
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think he is asking if EcuTek is capable of running a solely speed density tune with the MAP sensor and not using any input from the MAF sensor in the tune.
Old 03-19-2014, 11:35 AM   #316
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I just installed my Vortech kit 2 weeks ago. It came with a Dayco 89052 idler pulley. $14 at Amazon.
HRTROB is offline   Reply With Quote
Old 03-19-2014, 01:55 PM   #317
Frs32907
That is my question. Thanks for clarifying it on here
Old 03-19-2014, 02:40 PM   #318
nelsmar
That would be an ecutek question and not a vortech question. Sure you could, but if this is due to your sensor problems I would recommend doing as I told you and test someone else's sensor before moving forward. As doing a full time SD map would be rather time consuming if its just to get beyond your MAF. You would also need to install an IAT if you were completely removing the MAF from the tube.
Old 03-19-2014, 02:50 PM   #319
Frs32907
Thanks for the info nelsmar
Old 03-19-2014, 06:46 PM   #320
Sniper2606
Sniper2606's Avatar
Did not, just the instructions.
I wasn't aware that there is a registration either.
Old 03-19-2014, 07:16 PM   #321
DJCarbine
Thupercharged
DJCarbine's Avatar
It should have been included in the box that you got from vortech. Did a shop do the install?
http://www.vortechsuperchargers.com/page.php?id=33514
Get the warranty registration card and fill it out, then read over the terms and conditions etc.
2013 FRS
Vortech V3 11psi
Old 03-19-2014, 07:42 PM   #322
Sniper2606
Sniper2606's Avatar
I did the installation.
Ill fill it out, but it shows that it must be sent within 30 days of purchase...bought this in june.
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
aFe Power/Takeda Air Intake System and Exhaust aFePower Engine, Exhaust, Bolt-Ons 10 08-06-2012 03:03 PM
