Old 03-18-2014, 01:31 PM   #813
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by Wepeel View Post
That's a lot of junk for the glovebox!
Have you tried filling the trunk with some blankets or anything like that? I found running the muffler delete in my GR STI the amount of noise in the cabin was much better with the trunk floor on than off. Wonder if the BRZ would benefit the same way.
It's not as bad with the backseats up but when I have the car loaded with tires (so seats down), it gets much more annoying on the highway
Originally Posted by Rexpelagi View Post
For whatever it is worth, I run a delete and I never notice it on the highway. I drove to Nationals and back with it last year and it never bothered me. Wind noise and tire noise mask the exhaust noise. It is loud around town, but I like it for the cost and weight savings.
I paid $35 for my custom so I love the value. It's only a real issue on longer trips where the seats are down and I get no break from it. Which realistically is only a half a dozen times a year.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 03-18-2014, 01:32 PM   #814
Kido1986
Dodging cones
Kido1986's Avatar
Originally Posted by vroom4 View Post
See "FT86...made of glass?" on RRAX for how my weekend went....
I saw that and was shocked. We've had some hard hits in my car and never any real damage. Just sagging front bumper.
I wonder if you somehow hit the base of the cone, where it's very stiff rubber.
Old 03-18-2014, 04:43 PM   #815
bobaab
Drives: 13 Subaru BRZ Limited
Kido,
Did the rear end become less planted with the exhaust delete? With the track pipe and the trunk stuff out of there, I'm guessing you took off about 35-40 pounds off the rear. Did that unsettle the car at all?
I'm looking to do the Nameless muffled track pipe to take off 20 pounds or so in the back and was just wondering.
bobaab is offline   Reply With Quote
Old 03-18-2014, 05:26 PM   #816
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I've had an off day once and was hitting cone after cone... first instance was trying to push the limits coming into a slalom - came in too hot to the second cone square on at the very top of 2nd gear. Second instance was in that same slalom (was in a rough, bumpy section of the lot) and the car got unsettled and the back end swung around. I hit 3 cones right behind the driver's side door, at around 40mph. Both just left some cone scuffs and no damage. You just must have just been unlucky
Propaganda is offline   Reply With Quote
Old 03-18-2014, 05:30 PM   #817
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yeah my front bumper has eaten a lot of cones, it ain't pretty.
Old 03-18-2014, 05:35 PM   #818
TRev
I had a weird one last year too. I got sideways in a top of 2nd gear section and hit a wall of cones sideways with the back tire/quarter of the car at the Milwaukee Match Tour. As I neared the finish, I started hearing a weird noise under hard cornering. Turns out the cone hit my valve stem just right and broke it half way off. Managed to finish the run just as the tire finished going flat. Now I use rubber valve stems instead of aluminum.
TRev is offline   Reply With Quote
Old 03-18-2014, 05:57 PM   #819
Rexpelagi
Drives: 2013 Subaru BRZ
Originally Posted by Sccabrz192 View Post
Thanks, that does help. Have you ever checked your dB levels at any events, any ones that were cooler with a low cloud ceiling?
Nope, I don't have any dB data. I haven't actually run my car anywhere that has sound monitoring as I got it at the end of the season last year and drove John's car at Nationals.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 03-18-2014, 08:38 PM   #820
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Originally Posted by bobaab View Post
Kido,
Interesting... I removed spare tire one time, was very tail happy and spun several times. Never removed it again since...
But then that was on stock tires. Last practice with new Yokohama Neova AD08R, I noticed the rear end stayed glued quite nicely, so will try removing the spare again this weekend and hopefully not start another spin cycle.
I would imagine removing both spare & getting muffler delete will require some kind of front sway bar to bring balance back? Is that how everyone else does it?
brz7400 is offline   Reply With Quote
Old 03-18-2014, 09:04 PM   #821
FastWhite
Drives: Subaru BRZ Limited M/T
I put I a 20 mm adj. bar. With everything out of I find the car well balanced. When I start to spin out, lift off the gas, it corrects and away I go.
But them again I may not be driving at the absolute edge.
I'm also on 225 Rival's. About 8600 miles on them. I am very happy with my current set up. I apart don't want to mod, afraid I will mess up the balance.
FastWhite is offline   Reply With Quote
Old 03-18-2014, 09:13 PM   #822
Rexpelagi
Originally Posted by FastWhite View Post
When I start to spin out, lift off the gas , it corrects and away I go.
O.o
-John L.
2011 BMW M3 - 57 FS
The Following User Says Thank You to Rexpelagi For This Useful Post:
Kido1986 (03-18-2014)
Old 03-18-2014, 09:21 PM   #823
FastWhite
Ok enlighten me. Old man remember. Where did I put my foot this time?
Old 03-18-2014, 09:21 PM   #824
Kido1986
Dodging cones
Kido1986's Avatar
That happened to us! Kosei's with 2 metal valve stems per wheel. Ripped it clean out at a local event. All 8 changed immediately to rubber.
The Following User Says Thank You to Kido1986 For This Useful Post:
ViperASR (03-19-2014)
Old 03-18-2014, 09:25 PM   #825
Kido1986
Dodging cones
Kido1986's Avatar
Kido,
Nope, but Ive removed it (trunk junk) on every run Ive ever done. As such, I setup the car with this in mind. I run decent amount of rear toe in
Old 03-18-2014, 09:41 PM   #826
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
O.o
Exactly my thoughts! When I lifted after powering out of a slalom ... I ended up 3' from a light pole (backwards). This was my first HPDE and before I had made my 2nd payment on the car. Not my proudest moment.
Lesson to the new guys (myself included): When the car starts to come around on you, gently ease off the throttle and countersteer to induce a neutral (4 wheel) slide sideways. Let your tires bleed the speed, and make sure all the weight transfers have settled down. Regain control instead of overcorrecting and cheesing it a second time.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
