Old 03-13-2014, 01:36 AM   #43
Eminent Performance
Eminent Performance's Avatar
Drives: 2013 Scion FRS
Originally Posted by mokinbird87 View Post
will get in touch with ya. thanks!
Not a problem! I love seeing projects like this actually getting made!
Eminent Performance is offline   Reply With Quote
Old 03-14-2014, 08:46 PM   #44
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
update posted on the opening post. my clay piece got warped during the drying process so I have to do a new one using proper automotive clay, but at least the quote I got from a 3D scanning company is not too bad. stay tuned!
mokinbird87 is offline   Reply With Quote
Old 03-15-2014, 01:23 PM   #45
JustBoostin
Drives: Asphalt FR-S 6MT
Originally Posted by z3ro View Post
i'll accept the 2nd part as a good answer but the first i'm still skeptical.
it seems like this would just push air towards the firewall which wouldn't seem to do much.
Making these vents functional actually does release a lot of heat from the engine bay. I did mine last summer and was very surprised myself!
JustBoostin is offline   Reply With Quote
The Following User Says Thank You to JustBoostin For This Useful Post:
OICU812 (03-18-2014)
Old 03-15-2014, 01:35 PM   #46
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I can't wait to see this finished. So much time, effort, and thought is going in to this project. I bet it'll look fantastic.
Old 03-15-2014, 01:48 PM   #47
troek
troek's Avatar
Drives: 2012 Toyota 86
so i have to ask..... how much heat would a heat vent vent if a heat vent could vent heat?
troek is offline   Reply With Quote
The Following 10 Users Say Thank You to troek For This Useful Post:
amaciose (03-17-2014), Black Tire (03-27-2014), disgruntld (03-27-2014), JustBoostin (03-15-2014), Kimsey47 (03-27-2014), kmbkk (03-15-2014), racecat (03-18-2014), White0utFrs (03-20-2014), wparsons (04-13-2014), Wyattkb (03-15-2014)
Old 03-15-2014, 04:15 PM   #48
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Definitely interested!
kmbkk is offline   Reply With Quote
Old 03-17-2014, 03:23 PM   #49
cncnjn
Drives: Raven FRS Veilside Nissan 350z
Subbed
cncnjn is offline   Reply With Quote
Old 03-17-2014, 10:24 PM   #50
plucas
plucas's Avatar
Drives: Subaru
Do you know what the pressure is in the engine bay? There is almost 0 psi in that area on the fender so positive pressure is needed in the engine bay. You want as high of pressure differential as possible to get as much mass flow out of there. There are some trick to do this for sure.
This got me thinking of something else to do with the vent
plucas is offline   Reply With Quote
The Following 3 Users Say Thank You to plucas For This Useful Post:
eric6 (03-25-2014), frssfo (04-10-2015), radroach (03-26-2014)
Old 03-18-2014, 12:11 AM   #51
mokinbird87
BOXER FR
Hey thanks for the input! I know we talked about getting my rear diffuser tested out and I'm not joking.. I'm very serious about it
With this side vent piece I'm not looking for a drastic performance change.. I just want something that is not a faux piece that mimics a genuine side vent. I still do think however, even if it will be just a little bit, tunneling some air out from the engine bay could remove some heat. If it were to be super functional you probably need some sort of a naca duct to draw air in from the front of the engine bay (front bumper area) and guide it out through the side vent but my personal car is not a dedicated track car...
For example, canards and splitters do their job at the track and it's super functional but is it really a beautiful design? Hmm...
I would like a good compromise of both form and function, compromising more on the functional side a bit.
Old 03-18-2014, 02:24 AM   #52
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
you could give the vent a leading edge, kind of like a reverse gurney flap, if you really want to draw the air out
EvilBeaverFace is offline   Reply With Quote
Old 03-18-2014, 02:55 AM   #53
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I don't like any of these diagrams for air pressure, as my car is always drifting sideways, so therefore I have great air pressure on my side vents.
Jkjk...it is nice to see real data/technical stuff. Plus I'm interested in the side vent, well, being a vent and I don't have the knowledge/time to figure this stuff out. So those experimenting, I thank you.
Old 03-20-2014, 06:53 PM   #54
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Here's an interesting thread on F1 Technical about air flow in the fender well area. It seems like there's an opportunity for aero there... but the low pressure zones seem to be above the wheel and aft of it. The vent location is pretty awkward, in terms of functionality.
LINK
My initial thought was to run something like this:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
mokinbird87 (03-24-2014)
Old 03-21-2014, 02:19 AM   #55
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Ah...I know that issue all too well. If you want, I have some Kolb Automotive grade modelling clay from a project I did a while back. Keep in mind that you'll need to bake it slightly to soften it enough to mold. Another tip is that after you have the shape you want, use some Acetone to smooth out any sharp lines after you use your slick.
3d scanning is a good way to go these days though, much faster and more precise. Plus you can get a super clean OEM look using CAD that is a real bear to do by hand. In fact, that's what I'm having done as well. lol
Sithspawn is offline   Reply With Quote
The Following User Says Thank You to Sithspawn For This Useful Post:
Old 03-24-2014, 05:37 AM   #56
ru-x
Drives: brz
vacuum forming would be the easiest and cheapest way of doing it...I would just take the stock trim off and remove or add to it by cutting and adding body fill. once i have the shape i'd vac form it...then turn that into a positive mold and vac the positive giving you a final piece that you can finish and place on your car.
ru-x is offline   Reply With Quote
The Following User Says Thank You to ru-x For This Useful Post:
Vent Side Marker MaximaZero Cosmetic Modification (Interior/Exterior/Lighting) 28 02-23-2014 03:09 AM
BRZ Side Vent Trade woode NY / NJ / CT / PA 4 12-31-2013 12:01 PM
Side vent change Andrew_FRS_DD Cosmetic Modification (Interior/Exterior/Lighting) 1 07-12-2013 06:33 PM
frs side vent lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-02-2013 09:54 PM
Side Vent Swap? Allankh CANADA 0 12-19-2012 03:26 PM
