Old 03-16-2014, 10:12 AM   #1
Lisak6841
Lisak6841's Avatar
Drives: 2013 scion fr-s
HELP! wheel fitment issue
/facepalm. Regardless of my time into researching, I've messed up. I recently purchased a set of avant garde wheels 18x8 front and 18x9 rear +30 offset for both. I checked the proven wheel fitment guide and they checked out fine. BUT I guess I failed to check on tire sizes enough. I went with 225/40/18 front which fit and look beautiful. However, the rear 245/40/18 are NOT going to work as I set. Mounted them last night and I can hardly fit my fingers under the fender. Any little bump and I'm bottomed out. Note I'm also on eibach sportline springs (~2"drop) what can I do?? Will putting on some different springs (1"drop) help? Or will I need camber? I'm trying to make these tires work if possible. Nitto NT555 does not make 245/35/18, which is equivalent in height to the front 225/40/18.
Lisak6841 is offline   Reply With Quote
Old 03-16-2014, 10:55 AM   #2
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Any photos?
ericvanderwoodsen is offline   Reply With Quote
Old 03-16-2014, 11:01 AM   #3
Burrcold
Drives: Subaru BRZ Limited
Have you checked your camber? You might just need LCA's to get you back in spec so you're not rubbing.
Old 03-16-2014, 02:13 PM   #4
Lisak6841
Lisak6841's Avatar
Only photo I have as of now, I will take more from the side later on, and off the block.
Old 03-16-2014, 02:14 PM   #5
Lisak6841
Lisak6841's Avatar
I have an appointment next week to get my fenders rolled and pulled a little, hopefully this will help
Old 03-16-2014, 11:19 PM   #6
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
They do make a 255/35
Instagram @admsevi
sevi21 is offline   Reply With Quote
The Following User Says Thank You to sevi21 For This Useful Post:
Lisak6841 (03-17-2014)
Old 03-17-2014, 12:17 PM   #7
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I'm watching this to see if you get a successful fit. Please post photos from many angles if you get this sorted out. Thanks.
Old 03-17-2014, 12:43 PM   #8
Lisak6841
Lisak6841's Avatar
Will do. Like I said I am having my fenders rolled on Sunday and I will make sure to take pics for you all.
Old 03-17-2014, 12:55 PM   #9
Vten
Drives: Too heavy
do you have any rear LCA? a little bit more camber would help without messing up the fender..
also do you have more pic taken from the rear so we can see how much the tires poke out ?
Vten is offline   Reply With Quote
Old 03-17-2014, 01:05 PM   #10
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
as previously stated I would just add more camber or get different tires. Rolling fenders can easily ruin the paint on the crease or reflect the sun awkwardly and it can never be put back the exact way it was.
Old 03-17-2014, 04:33 PM   #11
Lisak6841
Lisak6841's Avatar
Size:  181.4 KBName:  ImageUploadedByTapatalk1395084771.220652.jpg
Size:  179.9 KBName:  ImageUploadedByTapatalk1395084779.621584.jpg
Size:  160.8 KBName:  ImageUploadedByTapatalk1395084792.305631.jpg
Old 03-17-2014, 04:50 PM   #12
Vten
Drives: Too heavy
wow that's really close tho ....I would go with a narrower tire such 235/40 or add the camber on the rear using an LCA , as I would avoid to mess around with rolling the fender at all cost .
my new set would be using the 225/40 bfgoodrich comp2 tires on a 9.5 wide wheels and +30 offset...a little stretch for most ppl here :P
Go bucks!
Old 03-17-2014, 04:56 PM   #13
Lisak6841
Lisak6841's Avatar
I just hate to buy new tires since these have never even made it out of the garage. This will be my $500 mistake.
Old 03-17-2014, 05:23 PM   #14
executivekoala
executivekoala's Avatar
Drives: fr-s
You cant really roll these fenders, they already have a roll. I know this because mine were rolled, i got millimeters of extra clearance. just add -2 degrees of negative camber and 0 toe and you should be okay and make the rear more stable around corners. 0 toe will wear the tires less.
executivekoala is offline   Reply With Quote
Greddy SP exhuast fitment issue ru-x Engine, Exhaust, Transmission 13 03-16-2014 05:02 PM
P&L Motorsports 4-1 Equal Length Header fitment issue DR 86 Engine, Exhaust, Transmission 10 01-01-2014 02:48 AM
BRZ front bumper fitment issue Thongpocket Cosmetic Modification (Interior/Exterior/Lighting) 0 10-21-2013 03:23 PM
Wheel Directory: MM6 Mesh 18x8.5 +38 / 18x9.5 +40 ModBargains.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 03-14-2013 06:13 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 07:33 PM
