#295 | |
Drives: 2013 FRS
#296 |
Drives: SWP BRZ
I just did the datalogging on Stage 1 V1.56b map. with Avo Silicon inlet, Motiv Catless Front pipe, Nameless axle back
http://www.datazap.me/u/zc06kissther...4?log=0&data=1 somehow, except time and engine speed, all other fields shows as colum1~11 FIXED file! http://www.datazap.me/u/zc06kissther...0&data=1-2-8-9 when i compare this datalog file from my previous tune, it seems very similar. i guess looks ok? EDIT: i updated template file and shows all colums now! Last edited by zc06_kisstherain; 03-16-2014 at 10:19 AM. |
#297 |
The Mechanic
Drives: Civic Turbo,FR-S
its odd that people are having IAM issues. ive advanced these tunes 3 more degree in some areas and adjusted fuel tables and im having 0 knock. 93 oct
#298 |
I'm not sure exactly how to read this brief log. Quick 3rd gear pull:
http://www.datazap.me/u/transition/b...8-9&zoom=0-212 Perrin catback, Stage 1 A01C 1.55b map |
#299 |
Drives: 86
did a quick log for normal city driving as requested by steve99.
http://www.datazap.me/u/nardi330/oft...4-6-7-10-11-12 i'm running 1.55 stage 1 A01G rom on Aussie spec manual 86. it's not a 3rd gear WOT to redline pull. any comment is appreciated. |
#300 | |
Drives: 2013 FRS
#301 | |
Drives: 2013 FRS
#302 | ||
Drives: 86
thanks for your reply. I understand I need to do a WOT pull in third which i will do this saturday on a dyno. Steve99 asked me to assist him with data logging some normal driving for him as he has some issue with IAM dropping. so I thought i would also post my log here. Quote:
#303 | |
You have feedback knock at 2900rpm, 0.65 load. Did you just flash the tune or you've been driving on this for awhile? |
#304 | |
Drives: 86
i think there are issues with my OBD2 extension cable. maybe i will just plug OFT straight into OBD2 port and try again. |
#305 |
#306 | |
Drives: FT86
This is not going to destroy an engine or anything but it is pointing to out aussie 98 RON is not as good as USA 93 AKI fuel for low rpm high load knock resistance. as the engine is detecting knock at low rpm high load (city driving) is is reducing the IAM which retard the timing and robs engine of power so you don't get max benefit from tune. When IAM drops below 1 it reduced the timing (knock correction) advance for the entire rpm range by in your case by 70 to 80 % this is probably pulling 2 to 5 degrees from you timing across the entire rev range. Their are two options one is run higher octane fuel ie united 100 octane is about all we have in OZ or pull a bit of timing from the problem area which should keep your IAM up around 1. I am currently running 100 octane and IAM was dropping slightly to 0.7 at worst and not very often. I modded by advance map in a few places only pulling -0.35 degrees and it solved the IAM drop now 1 when running 100 RON. Will try on 98 once my tank runs down. I can send you a ROM with the corrections if you want to flash it and try. Or I can just send you the corrections and you can edit it yourself in RomRaider. |
#307 |
#308 |
Drives: FT86
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
