Old 03-16-2014, 02:50 PM   #561
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
KW's is over the cap isn't it? That's how the photos look
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-16-2014, 03:04 PM   #562
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Yeah but the take off plate is super tall.
digital_assassin is offline   Reply With Quote
The Following User Says Thank You to digital_assassin For This Useful Post:
dolo (08-26-2014)
Old 03-16-2014, 03:05 PM   #563
Zach3794
Right so I wanna compensate for the smaller takeoff plate with a low pro cap :P I'll figure it out
Old 03-16-2014, 03:14 PM   #564
digital_assassin
Keep us posted!
Old 03-16-2014, 03:14 PM   #565
Zach3794
That's the plan
Old 03-16-2014, 03:44 PM   #566
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Gonna order one of these... I think the over-under configuration will work perfectly with the KW setup. http://www.ft86club.com/forums/showp...49&postcount=7
cobrabyte is offline   Reply With Quote
Old 03-16-2014, 03:46 PM   #567
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Has anyone Teflon taped their reservoir cap? I'm getting ready to do mine just to ensure 100% seal. I got a little bit of residual build up around the cap. Did some pretty aggressive driving and noticed it afterwards. And by pretty aggressive, I mean very very aggressive driving. Lots of side to side vehicle movement lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-16-2014, 05:01 PM   #568
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Not the cap, but I did Teflon the inlet to the reservoir because I kept noticing some fluid on top of the reservoir after longer/harder drives. I thought my banjo fitting adapter might be the cause of the "leak" since I kind of mangled mine while trying to remove it from the hose at one point of the install, but Kraftwerks seem to think that is unlikely. They think my reservoir might just be too full and the fluid is coming out from the cap during spirited driving (I guess the cap is supposed to provide an air gap by design). I still have about 2" left in my Rotrex bottle since that was what somebody else on this thread said they went to. Each time I check the fluid level, seems to be slightly more than max from what I can tell. Not sure if I should try to siphon some out or just keep driving and let it come out from the cap until it gets down to a more nominal level (but when I do this I get some smoke from the fluid dripping on the headers after I come to a stop).
mit_peid is offline   Reply With Quote
Old 03-17-2014, 11:46 AM   #569
captain_jack
captain_jack's Avatar
I have a bit on mine as well but I think its the banjo bolt itself. The bottom one is completely dry. I thought I was low on fluid and wasnt as it started to volcano out when I added some. I did siphon some out and its at level.... thats why I think my banjo bolt is leaking.its a very minimal amount but I dont like it. On another note I was import face off yesterday and even with street tires and a very unfinished tune I ran decent. Stock cars here are running about a 15.4, I ran a 14.7 @97mph. I plan to go back after the dyno tune this weekend and letting a bit of pressure out of the tires. I ran the car how it would be on the street just to get a progress idea. We we'll see what's what afterwards.
may the schwartz be with you....
Old 03-17-2014, 11:03 PM   #570
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
Dyno logs needed
Hey guys can u post ur dyno resuts with the kit . I would like to see the boost thru the 5000 to 6000 rpm . I will explain further once I see a few and can confirm what I expect ...
Thanks
Ocho
Ocho Seis is offline   Reply With Quote
Old 03-17-2014, 11:56 PM   #571
Zach3794
Sw20, you have the KW kit now?
Old 03-18-2014, 02:16 PM   #572
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Okay guys disclosure: THIS IS NOT, I REPEAT NOT THE FINALIZED KRAFTWERKS BUT A PRERELEASED BETA UNIT THAT IS PROVIDED TO A SMALL GROUP OF PEOPLE. I'm sure the full production kit will have more powdercoating and will be "cleaner".
* Also, note there's a ding on the top of my oil cooler core, working with KW on getting another core but I'm likely going to pressure test it and throw it on if it checks out okay.
On to the pics, if you want more specific pics let me know. The threaded shaft I slid into the sandwich plate for picture purposes.
I'll get core measurements upon request.
Lines
Core
Sandwich plate(love this piece)
Main bracket to core
Other bracket I haven't looked into placement of yet and misc clamps
Omar GC
Instagram: 2jzus
The Following 4 Users Say Thank You to OmarGC For This Useful Post:
captain_jack (03-18-2014), glamcem (03-18-2014), mit_peid (03-18-2014), PRORICAN (03-18-2014)
Old 03-18-2014, 02:25 PM   #573
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Thanks for the photos, is that a thermostatic unit?
glamcem is offline   Reply With Quote
Old 03-18-2014, 02:33 PM   #574
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Sadly, it is not. I'll probably look into an outside option before next winter.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
