Old 03-15-2014, 06:13 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
effects of a roof wing?
im always interested in aerodynamics but im skeptical of a roof wing having a positive effect on downforce. i already have a Stillen roof wing and a duckbill on the trunk, but would the roof wing counter any positive effects of the trunk lip?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-15-2014, 08:36 PM   #2
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
No idea, but a good question. What does your car currently look like?
I had this in mind when I read the title of the post:
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
Gilwith1l (03-22-2014)
Old 03-16-2014, 10:55 AM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
http://www.frsport.com/Stillen-KB210...-_p_69725.html
thats what it its. not much angle to it
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
Black Tire (03-16-2014)
Old 03-16-2014, 02:15 PM   #4
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
i doubt either wing does anything other than cosmetic purposes
zex is offline   Reply With Quote
Old 03-16-2014, 03:02 PM   #5
T_Scott
T_Scott's Avatar
Drives: 2013 Raven FR-S
I was wondering the same thing actually. I feel like it would almost create an air pocket above the rear window, like the way a pocket is formed on a truck when the truck has the tailgate up and the air pocket forms basically in the bed. Correct me if i'm wrong though, it's only a thought and I have no proof or anything to back it up haha.
Three pedals, six gears, and nothing but time.
T_Scott is offline   Reply With Quote
Old 03-16-2014, 03:04 PM   #6
Crazy Drew
Drives: Smells like tires when I drive
Are you also part of the flat earth society?
Spoilers on car do exactly what they say, they spoil the lift generated from the car traveling at speed. It's not so much that you have to worry about it crushing the trunk like a real sports car wing however it does negate the lift. Is the critical point at which the car becomes unstable without one anywhere near the speed limit? No, but a blanket statement that they're cosmetic only is pretty closed minded.
OP, it's hard to tell honestly without doing a bunch of research such as photographing the car at various speeds with strings taped all over it and a couple smoke bombs to watch the air flow. They probably don't interfere with each other although the roof wing will create a larger area of low pressure air behind the car.
Crazy Drew is offline   Reply With Quote
Old 03-16-2014, 09:16 PM   #7
Grip Ronin
The Mechanic
Grip Ronin's Avatar
lol flat earth. ya the wing doesn't have much of a lip to it, but everything has an effect small or large. im guessing vortex generators would give the effect to assist the trunk lip.
IG-Joey_Soul
Old 03-16-2014, 10:55 PM   #8
Crazy Drew
Yep, a vortex generator will create the necessary turbulence to allow the air to re-converge closer to the car and clean up the air going in to the trunk spoiler and reducing the size of the negative pressure "bubble" behind the car.
There is a speed at which the roof spoiler would "throw" the air so far off of the car that it wouldn't be able to converge in time for the trunk to have an effect. Do I have any idea what speed this is at? No, but it's probably honestly pretty darn fast.
I'm kinda curious now to have someone drive next to me with a camera and a smoke bomb on a stick so I can get some aero photos of the car.
Old 03-17-2014, 06:59 AM   #9
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya im interested to see it. id assist but i dont know if u live in nj
IG-Joey_Soul
Old 03-17-2014, 12:43 PM   #10
Crazy Drew
Nah, I'm down in Dallas, TX. I'll probably have to wait for the fireworks stands to open up before I can even get any smoke bombs big enough to be able to tell and I'll just have to coordinate with some friends to be able to take the pics. I'll let you know if/when I do this.
The Following User Says Thank You to Crazy Drew For This Useful Post:
Grip Ronin (03-17-2014)
Old 03-17-2014, 01:14 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
my opinion is thay you will be much better of with diffusers to help streamline the air over the rear glass and trunk.
this to me just seems inefficienct.
Old 03-17-2014, 01:51 PM   #12
Crazy Drew
Take a look at a golfball. See the dimples? Those are on there to get the air in the boundary layer directly around the golf ball to be turbulent and to get the air to converge quickly following behind it. If these didn't have the dimples they would fly very slow in comparison and tumble all over the place.
Not just any turbulence is good either, I'm talking about breaking up the air in the closest inch or two to the car and leaving the rest untouched to do it's thing.
Old 03-17-2014, 02:01 PM   #13
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not sure what you are commenting on
diffusers on the end of the roof would do to the car what you are describing
the OP's winglet would not, it would only further icnrease the turbulance over the rear window which is present even with nothing on there.
Old 03-17-2014, 09:34 PM   #14
plucas
plucas's Avatar
Drives: Subaru
Flow stays attached to rear glass pretty well without anything. No vortex generators needed. I could make some assumptions about a roof spoiler, but it would just be an assumption.
The picture below shows how the fluid stays attached
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
Grip Ronin (03-22-2014)
Changing camber. Effects on toe? FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-28-2014 12:51 AM
effects of elevation StormTrooper Engine, Exhaust, Transmission 1 01-27-2014 12:26 AM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 12:55 AM
effects of bigger wheels-video 315FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-01-2012 09:50 AM
