Old 03-01-2014, 10:31 PM   #29
Supertek Industries
Supertek Industries's Avatar
Originally Posted by jono_l View Post
Received the updated (shorter) coupling and new intake tube (with extra processing to ensure no more material build-up) a couple weeks ago, and finally got around to installing the intake tube on my car today!
The updated intake tube was pretty much perfect right out of the box, so hats off to Supertek for sorting out those teething problems and also honouring an exchange. The updated (shortened) airbox coupling was still a little too long for the pipe to sit comfortably in my opinion, so I cut it down further until it was 50mm long.
Installation was straight forward ; hardest part was removing the existing sound tube all the way to the firewall, especially that one stubborn clip attaches the hose to the chassis. Brute force solved the issue and I managed to get everything out intact with no damage.
Butt dyno suggests little change in power from stock setup, but I hadn't driven the car in 2-3 weeks so my calibration is out :P Setup sounds great - no unwanted booming resonances at cruising rpms, with a healthy amount of natural induction noise above 4000rpm.
All in all I'm stoked with the outcome - to me, it's the way it should have come from factory!
Attachment 68898
Thank you for your patience and sharing your feedback (not to mention awesome engine bay shot), Looks great@ With that said, we are really lucky to be involved in a community that is so supportive and understanding.
Supertek Industries is offline   Reply With Quote
Old 03-03-2014, 11:01 PM   #30
xDanger_208x
xDanger_208x's Avatar
Drives:
Quick picture of my SuperTek intake pipe w/filter.
Thanks for the great product and thanks to FT86SpeedFactory for the great price!
xDanger_208x is offline   Reply With Quote
The Following 2 Users Say Thank You to xDanger_208x For This Useful Post:
EpicNameBro (03-15-2014), FT-86 SpeedFactory (03-03-2014)
Old 03-08-2014, 11:52 PM   #31
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Attachment 68898
Looks great! I recently installed this product but i have the same issue with the airbox coupling. I'm also thinking to cut it so it'll sit better. what did you use to cut yours?
Jolaessss is offline   Reply With Quote
Old 03-09-2014, 12:56 AM   #32
jono_l
Drives: 86 GTS M/T 37J
I tried a few different methods. Youtube suggested using a hose clamp as a guide, but I found it difficult to get a clean perpendicular cut into the hose using either a box cutter (worse) or a double edged razor blade (better).
In the end, I used fresh box cutter blade placed on a flat-topped object of my desired height on my desk - this keeps the blade parallel to the desk at all times. I held the silicone hose against the object then used the blade to cut through it - this gave me a clear, nearly perfect perpendicular cut with a constant height.
For reference, the height I settled on was approx 50mm.
jono_l is offline   Reply With Quote
Old 03-09-2014, 05:43 AM   #33
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Ahh, I may just go this route. I was contemplating either using a hacksaw or Dremel to do the job, but a box cutter sounds like you have more control for a more precise cut. Thanks!!
Old 03-09-2014, 06:59 AM   #34
s2d4
s2d4's Avatar
Anyone else logged Intake air temp?
Old 03-15-2014, 12:54 PM   #35
grichardt
grichardt's Avatar
I found the supertek intake tube on ebay brand new for 90 shipped. Vendors have it also with the filter for 109 shipped. Super pleased
grichardt is offline   Reply With Quote
Old 03-15-2014, 01:41 PM   #36
s2d4
s2d4's Avatar
Well, I logged it and it heat soaks like crazy.
Old 03-15-2014, 04:34 PM   #37
grichardt
grichardt's Avatar
More so than the stock tube?
Old 03-15-2014, 05:40 PM   #38
s2d4
s2d4's Avatar
Yes. It'll rise up about the same temp but it won't shake the heat whereas the stock one will drop 20-30F lower in comparison.
Old 03-16-2014, 12:14 AM   #39
BlackyRose
Drives: 2013 Raven FR-S
Very dissapointing. Looks like mine will be hitting the for sale section soon
BlackyRose is offline   Reply With Quote
The Following User Says Thank You to BlackyRose For This Useful Post:
leicaboss (03-17-2014)
Old 03-16-2014, 12:31 PM   #40
Supertek Industries
Our intake pipe and filter have proven performancegains over stock setup and other inlet pipes. We challenge anyone to do their own independent testing, and actually PROVIDE results. If our claims are not true we will gladly refund any customer. We have offered this already many times already, but still no one has come forward. We wonder why?
Its interesting that that we do not see these attacks against companies like HKS or Blitz that make similar products. Maybe we need to a 30 page forum thread that attempts to convince everyone.
The Following User Says Thank You to Supertek Industries For This Useful Post:
xDanger_208x (03-16-2014)
Old 03-16-2014, 12:39 PM   #41
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Are you able to post your data?
I think I asked for it before but don't remember seeing it.
Old 03-16-2014, 01:20 PM   #42
s2d4
s2d4's Avatar
Not an attack, just what I saw in my own car.
Both reaches ~+140F being stuck in traffic, the lowest it went down to was about ~115F. Stock went down to ~95F at a much quicker pace too.
Both days were approximately 80-85F.
NW Shop Review: BK Industries (Boise ID) DarrenDriven Northwest 1 03-16-2014 11:40 AM
SuperTek Industries 86 logo center caps SurfAndSand Wheels and Tires 4 10-11-2013 08:32 PM
Supertek Industries - New Parts Announcements Supertek Industries Announcements, Contests, Giveaways 6 09-15-2013 09:51 AM
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 07:18 AM
NW Shop Review: Portland Speed Industries (PSI) (Hillsboro OR) DarrenDriven Northwest 1 06-01-2012 01:29 PM
