Old 03-13-2014, 01:52 PM   #1
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Can you stagger this tire combo?
Okay so I'm trying to figure out a tire combination for when I go F/I
I'm thinking about 275/35/18 or 265/35/18 for the rear and 245/40/18 for the front.
The problem is, the profiles don't match 35 & 40, will this affect much or its possible to do this? The lowest I can get in a 245 for Michelin PSS is 40 and I don't want to go into a 255 for the front..
So the question is, will the 5 difference affect anything?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-13-2014, 02:04 PM   #2
cactus
cactus's Avatar
Drives: 13 SWP BRZ
The 35/40/45 is not a direct measurement of the sidewall, but a percentage of the tread width.
Now, they are similar height tires.
cactus is offline   Reply With Quote
The Following User Says Thank You to cactus For This Useful Post:
Brody602 (03-13-2014)
Old 03-13-2014, 02:07 PM   #3
Brody602
Drift King
Brody602's Avatar
Perfect! So mixing a 275/35/18 with a 245/40/18 only has 1.8% difference and 0.07", so I guess the answer would be that no, it shouldn't really affect anythng
Old 03-13-2014, 03:48 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
why in f*** sakes are you going to 275's in the rear?
Old 03-13-2014, 03:49 PM   #5
gramicci101
Off Topic
The stock tire is 24.62 inches in diameter. By going to a 245/40-18 you're adding over an inch to your tire diameter. A 245/35 and 285/30 would be a lot closer to the stock diameter, but I have no idea if you could actually fit 285s in the rear.
Old 03-13-2014, 03:53 PM   #6
Brody602
Drift King
Brody602's Avatar
I'm not quite sure what you're trying to tell me, I was pretty much just asking how if it would be quite a bit higher at the front end compared to the back and if it would affect anything, I'm not sure if a 285 would fit but I was told a 275 should as long as I have coilovers
Old 03-13-2014, 03:53 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
As mentioned, tires are too tall! Should consider 245/35-18 front and 265/35-18 rear. Rears would still be a bit taller than stock, but not absurdly so. 245/35-18 is defnitely a btter choice up front than 245/40-18.
Old 03-13-2014, 03:55 PM   #8
Brody602
Drift King
Brody602's Avatar
They don't make Michelin PSS in 245/35-18 only 40 and up, but I'm kind of set in stone with Michelin PSS
Old 03-13-2014, 04:07 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Tire Rack has PSS in 245/35-18 in stock.
http://www.tirerack.com/tires/TireSe...erformance=ALL
Old 03-13-2014, 04:11 PM   #10
Brody602
Drift King
Brody602's Avatar
Oh wow, I normally order from Discount Tire Direct because they seem to be the best to bring them into canada, here's what they have listed I wonder if it's just cause they don't have any in stock Name:  ImageUploadedByTapatalk1394741465.669653.jpg
Old 03-13-2014, 04:29 PM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
There is also 1010tires for Canada, or KXwheels (both Canadian websites)
But REALLY, 275 section tires in the rear? Why is that? The Z06 has 275's in the rear. The new model sting-ray went with 255's. 265's or less for Porsche's in the rear.... (point being made, these are are true sports/high HP cars) How much power are you aiming for with your FI goals?
Old 03-13-2014, 05:05 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Base C6 and the new Stingray have 285 rears, 245 fronts. C6 Z06 had 325 rears and 275 fronts!
Porsche 911 S (non-turbo) has 295 rears, 245 fronts.
Old 03-13-2014, 05:10 PM   #13
Brody602
Drift King
Brody602's Avatar
I'm aiming for 450whp,
Someone with 255's and 420whp was able to smoke the tires up in third gear for a 60mph pull, and another still had pretty bad traction issues with 265's and 480whp, I might settle for 265's
Old 03-13-2014, 05:11 PM   #14
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So Google and wiki gave us different numbers eh?
19" gram lift 57extreme wheel and tire combo frojas1985 Wheels and Tires 13 09-18-2013 01:15 AM
Anybody taken their wheel/tire combo off their FR-S and... cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-05-2013 01:47 PM
Functional tire combo tintumz22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 02-06-2013 12:12 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 08:33 AM
