Old 03-12-2014, 10:45 PM   #365
Drofnum
Drives: CBS Subaru BRZ
I put about 10.5 gallons of e85 in, so about 2.5 gallons of gasoline.
Drofnum is offline   Reply With Quote
Old 03-12-2014, 11:05 PM   #366
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That makes sense. Your E85 is probably a bit lower than 85% ethanol this time of year in your location. So the actual ethanol content in your tank may be as low as E60 which is why it's taking a bit more time for LTFT to increment upwards. Might only need to drop 1-2% before you hit the desired AFR target. Until then, you may be down 3-5whp. Totally safe as is though. Absolutely no sign of knock. You may feel a bit more power with the next fill up. After than and a bit of driving, take another log and post it up
Shiv@Openflash is offline   Reply With Quote
Old 03-12-2014, 11:35 PM   #367
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I am so excited to get my tax return and an oft. How awesome is it to have someone like shiv who can take the time to check out everyone's logs and see what's going on. Awesome support. Can't wait to get the header tablet combo!!!
jebuwh is offline   Reply With Quote
The Following 2 Users Say Thank You to jebuwh For This Useful Post:
fstlane (03-12-2014), Shiv@Openflash (03-12-2014)
Old 03-12-2014, 11:42 PM   #368
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Pistol View Post
hmm
im on e85 stage 2 tune,1.55
maybe 5th- 6th tank of e85 and its hardly what i call cold in the morning maybe 14 celsius
however took me seven attempts to get car started
winter isnt even close yet, and dont really want to add fuel to change mixture
@shiv@vishnu is there a solution for this
here is log from third tank
http://datazap.me/u/pistol/e85-3rd-t...der-1-2-3-pull
The logs look great. No knock. Good AFR. Everything is solid. As for the cold start, I think that is going to be an issue depending on conditions and fuel formulation. Others have posted revised cold start cranking table values which have helped people who were having a similar experience as you. Anyone know where that thread is again?
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Pistol (03-22-2014)
Old 03-12-2014, 11:44 PM   #369
Shiv@Openflash
Drives: 2013 FRS
To be fair, ongoing data log review isn't really an official part of our post-sales support. So don't thank me excessively. But with datazap.me it's easy and quick to do. So when time permits, I'm happy to throw in my 2c
leicaboss (03-16-2014)
Old 03-13-2014, 06:09 AM   #370
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
You'll find something here!
vgarcin is offline   Reply With Quote
Old 03-16-2014, 07:57 AM   #371
Pistol
Drives: 86
thanks mate
looks complex but i'll give it a go
Pistol is offline   Reply With Quote
Old 03-16-2014, 06:39 PM   #372
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
@shiv@vishnu
Couple questions regarding oil and e85:
How often do I have to change it?
Can I run either Royal Purple synthetic 0w20 or genuine Subaru oil?
Ocean-Grown 86 is offline   Reply With Quote
Old 03-16-2014, 08:09 PM   #373
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Ocean-Grown 86 View Post
@shiv@vishnu
When running E85 exclusively (or very frequently), I usually change oil twice as frequently. So every 2.5-3k or thereabouts. Royal Purple synthetic (or Motul/Redline/Amsoil) is all good stuff. Most of it is really overkill for an non-turbo engine though.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
Ocean-Grown 86 (03-16-2014), Pistol (03-22-2014), steve99 (03-16-2014)
Old 03-16-2014, 08:59 PM   #374
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I just changed mine today with about 1/2 e85 use and 7500 miles and it was blacker than I expected. It was still very viscous and seemed fairly clean. Not as much drained out as I expected though. I think I will be cutting back my change intervals some to accomodate.
Not nearly as bad as the "changes" we were doing for my mom's Grand Caravan towards the end of its life. We were taking 5,000 mile oil out of my Wrangler (that was coming out golden amber) and just pouring it in the van (without changing the filter or draining any oil).
Luckrider is offline   Reply With Quote
Old 04-06-2014, 12:52 PM   #375
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
hi @shiv@vishnu - I have been searching but can't find any post where you explain your recommended sequence of events for switching to e85 and then back
I have read several people run it down 20-30m past fuel light, then add 2 gallons, but others just add a full tank? And then when to flash? Also, what about when going back to 93? Finally, what specifically to look for in datalogs to make sure things aren't out of hand
Would be great if you could outline this.
86-tundra is offline   Reply With Quote
Old 05-09-2014, 05:25 PM   #376
Lemar58
Drives: Scion FR-S
I'm a little confused on this. I don't have my headers yet but I wanna run e85. Do I need to go on my laptop and load the e85 map on my tablet because I don't think I'm supposed to flash any of the stage 2 maps and those are the only ones that came with the tablet. Anyone?
Lemar58 is offline   Reply With Quote
Old 05-09-2014, 05:26 PM   #377
Luckrider
Luckrider's Avatar
Use the EL Stage 2 E85 tune for e85 with the stock header.
The Following User Says Thank You to Luckrider For This Useful Post:
Lemar58 (05-09-2014)
Old 06-10-2014, 09:35 PM   #378
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Is it possible to change the cold start idle speed on the Stg2 E85 maps?
I saw some posts about changing values in the MAF and timing tables via RomRaider in order to do so, but I'm pretty sure they only apply to gasoline.
RavioliG is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 11:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
