Old 03-11-2014, 01:19 PM   #29
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Grip Ronin View Post
ive tried zeroing timers, it didnt do much but i did find that messing wit the front o2 ratio changes the 20.3 ratio when in closed loop off throttle but i havnt found the timing control for it. i dont know if the primary igniton table would do that
Not sure what table you are talking about for the front 02 ratio. Are you referencing a dedicated wideband when you say messing with the ratio changes the 20.3 you see during decel? If you are going off the factory front sensor then messing with the sensor scaling will change the value you log, but not the actual ARF. During closed loop operation, it will cause the actual afr to shift since the ecu will be looking for a different voltage / current value for stoich.
It may not track the timing maps if it has unique logic for decel fuel cut, but you should be able to tell from your logs what load cell is tracking during decel and if it is using the map values or some other values during decel.
Old 03-11-2014, 01:25 PM   #30
mad_sb
Originally Posted by andrew5826 View Post
wow. great discussion going on. did some testing. I changed the ignition advance base timing A map to neg 10 degrees on the first column (,15) and the base idle (above speed threshold) to negative timing. lots of pops at partial throttle. lots on downshift and a couple on hard shifts. I'm gonna fine tune it a bit more so I don't have to play with the throttle so much to get the pops.
Sent from my SGH-I337M using Tapatalk
I would advise you rescale the columns and set the first column to the load you see in full decel and the second column just above the load you see in decel and make the timing normal in the second column. Otherwise you will be driving around at light load with horribly retarded timing.
The Following User Says Thank You to mad_sb For This Useful Post:
gonzo (03-28-2014)
Old 03-11-2014, 01:34 PM   #31
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Look into Bee*R, i am considering buying it and giving it a shot too
Old 03-11-2014, 03:44 PM   #32
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
ya so the scaling wouldnt be the answer. i knew i couldnt do it without timing change so i didnt keep the setting.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-11-2014, 11:27 PM   #33
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
would this make it so that it pops every time im off the gas? with just the first column set to negative timing, i found that i don't get pops unless i get the throttle in the perfect position.. which means the engine doesn't see the load with the negative timing unless i want it to and i like that because its kind of like an on off switch. cops probably wouldn't be too happy if they heard it
andrew5826 is offline   Reply With Quote
The Following User Says Thank You to andrew5826 For This Useful Post:
gonzo (03-29-2014)
Old 03-12-2014, 07:34 AM   #34
Grip Ronin
The Mechanic
Grip Ronin's Avatar
its because of your load break point, off throttle is less then .10. but maps start at .15... did you try it without the idle adjustment?
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
gonzo (03-28-2014)
Old 03-12-2014, 07:48 AM   #35
s2d4
s2d4's Avatar
Which map are you talking about?
Most of your posts don't make much sense.
Edit: I see what mad_sb is talking about now, got thrown off with cl/ol delay timers and o2 ratio weirdness...
Old 03-12-2014, 09:30 AM   #36
Grip Ronin
The Mechanic
Grip Ronin's Avatar
sorry you dont understand. i get impatiant typing on a phone. im talking about his ignition table. he said that he only gets the crackle when at part throttle. thats the change in engine load and possibly because it switches to open loop fuel map once you hit the gas
IG-Joey_Soul
gonzo (03-28-2014)
Old 03-14-2014, 12:20 AM   #37
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
been driving with the changes to ignition map for a couple days. no change in off/on throttle response and drives just like before. I really got the throttle positioning down to where I can drop pops anywhere and anytime I want.
to those negative individuals, it sounds ****ing awesome. [ame]http://youtu.be/c2VgspN8oBQ[/ame]
The Following 2 Users Say Thank You to andrew5826 For This Useful Post:
Migero86 (03-14-2014), Plxdjake89 (11-21-2015)
Old 03-14-2014, 12:28 AM   #38
SmsAlSuwaidi
Boosted
Does it shoot flames or just pops ?
Sent from my IBrick
Old 03-14-2014, 12:29 AM   #39
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
no flames
Old 03-14-2014, 12:29 AM   #40
SmsAlSuwaidi
Boosted
no flames
Saaaaadfaaaaace
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
mr. slim (03-19-2014)
Old 03-14-2014, 12:30 AM   #41
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
probably could get some if you added extra fueling. or maybe a turbo
Old 03-14-2014, 12:31 AM   #42
SmsAlSuwaidi
Boosted
I might go ahead and buy bee*r ( i'll be turbo)
Sent from my IBrick
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
