Old 03-10-2014, 09:14 PM   #15
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by shiv@vishnu View Post
I'm quite sure it's possible to do by just remapping the active ignition table and by playing around with the duration for throttle enrichment.
Any alteration to the main ignition and fueling tables will make for a rough transition from on/off throttle. With RaceROM we can make a custom map that is only active in a certain range, only for a certain time, and only when desired. That is why we can enable this without messing up cruise and low load operation and trims. Otherwise if you tweak the primary fueling and timing tables (or enrichment) you get sideffects that make for a lousy ride. Been there done that with the MX5 where we don't have custom maps (yet....), so this is a FT86/GTR only feature.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
86-tundra (03-10-2014), GT86_PRAGUE (08-19-2015), mad_sb (03-11-2014)
Old 03-10-2014, 09:32 PM   #16
DJCarbine
Thupercharged
DJCarbine's Avatar
The next time I send in logs I'm going to request this... for science and stuff.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Xero-Limit (03-10-2014)
Old 03-10-2014, 09:43 PM   #17
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i only see the ignition tables go to .15 and theres no way to adjust the break points on it. closed loop goes ~.08 always a steady 32 degrees. how would i go about changing closed loop timing?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-11-2014, 12:16 AM   #18
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You can adjust load and rpm breakpoints in Rom Raider. In Tuner Pro, I never bothered to defined them individually since it didn't seem necessary or useful at the time. For maximum pop-age, you'd want to run negative timing during over-run and try to delay deccel-triggered fuel cut. Basically making the ECU control fuel/spark like ECUs did 10 years ago before emissions required them to get clean. It's all do-able and shouldn't require any custom maps.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Grip Ronin (03-11-2014), mad_sb (03-11-2014)
Old 03-11-2014, 08:07 AM   #19
Grip Ronin
The Mechanic
Grip Ronin's Avatar
im gonna give it a shot and get back to you thanks.
IG-Joey_Soul
Old 03-11-2014, 08:17 AM   #20
Malt
Drives: 2015 WRX
Have any of you guys seen an muffler burst from backfires or had to replace a muffler due to the packing being ruined from constant over fueling? I'm honestly surprised a tuner would intentionally tune this into a tune as it serves no practical purpose other than wasting fuel and potentially causing exhaust damage.
Malt is offline   Reply With Quote
Old 03-11-2014, 08:19 AM   #21
mad_sb
Drives: 2013 Asphalt FR-S
im gonna give it a shot and get back to you thanks. for the fuel delay id change which cl,ol timer?
No, not the timers, there are some beta tables for overrun fueling, but they look like they are all related to the resume normal fueling cutover point. I assume if you raised the overrun fueling rpm resume threshold you could get it to do what you want, or possibly just change the RPM delta value.
As for the timing.. you will need to setup the map with the first load column being a little uder the decel load you see and the next column just over the decel load so you can run negative values in the first column and normal values in the second so your not trying to cruise at low load with retarded timing values.
Just had another thought, you might run into some idle / low fuel trim issues if you turn off decel fuel cut.. keep an eye on them and see. You could always force open loop at decel load values and that might allow you to play around with how much fuel etc you have during decel, you will need to modify the load axis of the fuel tables as well as the closed loop fueling target compensation A&B tables (set them to 14.7 where you want open loop). But that might require you to zero out the cl-ol timers and transition based on fuel map values.
The Following User Says Thank You to mad_sb For This Useful Post:
Old 03-11-2014, 08:20 AM   #22
s2d4
s2d4's Avatar
Wouldn't this also increase EGT? Increased potential of burning/melting cats?
Old 03-11-2014, 08:22 AM   #23
Grip Ronin
The Mechanic
Grip Ronin's Avatar
what cats? lol
IG-Joey_Soul
The Following 4 Users Say Thank You to Grip Ronin For This Useful Post:
8R6 (04-09-2014), AZFA20 (03-14-2014), glorydays (03-11-2014), WolfsFang (03-29-2014)
Old 03-11-2014, 08:27 AM   #24
DJCarbine
Thupercharged
DJCarbine's Avatar
Never had a muffler explode due to overrun popping. Maybe if it was overdone.... but the popping in the video was extremely subtle. Ive had cars that popped/banged twice as aggressive on a stock tune with only exhaust mods
2013 FRS
Vortech V3 11psi
Old 03-11-2014, 08:28 AM   #25
DJCarbine
Thupercharged
DJCarbine's Avatar
Im a dog person myself....
2013 FRS
Vortech V3 11psi
The Following 7 Users Say Thank You to DJCarbine For This Useful Post:
8R6 (04-09-2014), jamesm (03-11-2014), mrk1 (04-08-2014), nofferman (03-12-2014), Pistol (03-18-2014), racecaresuaceb (04-07-2014), Xero-Limit (03-11-2014)
Old 03-11-2014, 08:53 AM   #26
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ive tried zeroing timers, it didnt do much but i did find that messing wit the front o2 ratio changes the 20.3 ratio when in closed loop off throttle but i havnt found the timing control for it. i dont know if the primary igniton table would do that
IG-Joey_Soul
Old 03-11-2014, 11:21 AM   #27
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
wow. great discussion going on. did some testing. I changed the ignition advance base timing A map to neg 10 degrees on the first column (,15) and the base idle (above speed threshold) to negative timing. lots of pops at partial throttle. lots on downshift and a couple on hard shifts. I'm gonna fine tune it a bit more so I don't have to play with the throttle so much to get the pops.
Sent from my SGH-I337M using Tapatalk
andrew5826 is offline   Reply With Quote
The Following 3 Users Say Thank You to andrew5826 For This Useful Post:
Gilwith1l (03-29-2014), Grip Ronin (03-11-2014), Proof (03-11-2014)
Old 03-11-2014, 12:24 PM   #28
DJCarbine
Thupercharged
DJCarbine's Avatar
I would try to get the partial throttle popping resolved.... is it fun though? I miss the overrun popping/crackle on my e36
2013 FRS
Vortech V3 11psi
mad_sb (03-11-2014)
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
