Old 03-11-2014, 10:55 PM   #3865
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by xxscaxx View Post
I had a leak at that T fitting. No where else. If the clamps were put on tight enough, there shouldn't be any other leaks anywhere, but check the water pump inlet/outlet, and use a shop towel to wipe down each area so you can see if its wet or not.
Kk. Thx. Going to give them a call tomorrow morning to relay everything anyone thinks it might be or has experienced. Nice old guy. Want him to enjoy it!!!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
xxscaxx (03-11-2014)
Old 03-12-2014, 02:02 AM   #3866
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Look for signs of coolant leak, dry coolant goes white.
If you don't find leaks from any of the pipes, check your coolant cap there is a small hole for overflow if you notice coolant leaking from the cap, you could have a cooler leak, which is caused from seals in the core and boost , causing leak into the manifold.
Best way to test is to put the car on a dyno and do a load run, the coolant rises in the bottle and leaks out the cap.
Trace this ASAP as you don't want coolant going into the manifold, my valves were caked in dry white coolant.
Ryan86 is offline   Reply With Quote
Old 03-12-2014, 10:06 AM   #3867
xxscaxx
Drives: 2013 SWP BRZ
What were your symptoms again of the coolant leak into the manifold?
I don't think thats my problem but i'm just trying to prepare ahead of time in case I pull the direct injectors and the seals are ok.
Basically what is happening on the dyno is its breaking up/misfiring right around 5200 rpm. I could hear it from in the waiting room lol. Starts pulling smooth then just sounds like gunfire. I replaced the spark plugs and that wasn't it. Now onto the DI seals. I wish I would have remembered to check the coolant bottle while it was on the dyno to see if the coolant level would rise, but I don't think i'm having this issue as I didn't smell coolant or anything after it came off the dyno (I also was looking around at the bay too)
xxscaxx is offline   Reply With Quote
Old 03-12-2014, 10:08 AM   #3868
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
are you intercooled now?
Xero-Limit is offline   Reply With Quote
Old 03-12-2014, 10:08 AM   #3869
xxscaxx
Yeah, I have been for a while now.
Old 03-12-2014, 10:25 AM   #3870
Xero-Limit
Xero-Limit's Avatar
Ok, so 10 bucks says your DI seals and everything else is fine.
Phones have been crazy and email box is filling with dyno plots that look like the attached (mostly from other tuners but some of ours as well). Seems that this is a very common issue intercooled. We're working on this now and should have a fix soon.
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Drift-Office (03-13-2014), xxscaxx (03-12-2014)
Old 03-12-2014, 10:27 AM   #3871
xxscaxx
Thanks Mike. Wish I knew that about a day ago before I spent all the money on the DI seals and tool
Whats causing it?
@JuniorAWD
Old 03-12-2014, 05:01 PM   #3872
TemeCal
Drives: 86
Originally Posted by calispec View Post
Bill from delicious is addressing this in his next tune update. Should be released this weekend or maybe next. I think after the update 33mpg was seen IIRC. I get around 28 in the cold on winter tires. Before winter I was getting 31mpg.
@DeliciousTuning
Any word on when the update might be coming? Not that I really care, but my gas mileage sucks now. I just took a 300mi trip (600mi round trip), and I averaged 25mpg. This was all highway, where I used to get 33+mpg. Around town, I'm getting 16mpg.
I also threw a CEL for my first time, during a cold startup (aprox 50F). P0171, lean condition. I cleared the code, and monitored my AFRs closely. It must've been something at startup only, because I am definitely not running lean.
I've also been getting the occasional traction light and ABS lights coming on. It clears itself after I restart the car. It's only happened a few times (usually when I'm just idling for a while)...more of a nuisance than anything else.
TemeCal is offline   Reply With Quote
Old 03-12-2014, 05:21 PM   #3873
choi0706
Drives: t
Whats causing it?
@JuniorAWD
better than buying the injectors..
whats the tool cost?
choi0706 is offline   Reply With Quote
Old 03-12-2014, 05:29 PM   #3874
xxscaxx
Came out to 112 shipped for the tool.
Old 03-12-2014, 06:34 PM   #3875
jamesm
Originally Posted by TemeCal View Post
@DeliciousTuning
that cel means your fuel trim maxed out. not great. the traction light and cel means limp mode is on. again, not great.
Old 03-12-2014, 06:37 PM   #3876
TemeCal
Drives: 86
I realize that. But, I was out in the middle of nowhere, 300mi from home. I shut the car off and monitored my AFRs closely after I restarted it. My AFR numbers never seemed to run lean after that incident.
Thanks for the info though. I should really log this with Bill, so he's aware also.
Old 03-12-2014, 06:38 PM   #3877
jamesm
of course you won't be lean... you'll just be trimming +35% . in any case i'd get it looked at. probably a post-maf vacuum leak or something.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
mad_sb (03-13-2014), TemeCal (03-12-2014)
Old 03-12-2014, 06:52 PM   #3878
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Anyone know where I can get an aluminum charge pipe?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
