Old 03-11-2014, 12:07 PM   #71
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by jamesm View Post
it's likely that map definition is wrong or isn't scaled properly or something, as a value of 1 or 2 degrees will definitely disable coarse correction.
Definitely the correct address, and no scaling required - it's a float value. It's simply set at zero for the BRZs...
The logic behind getting into rough correction mode is quite convoluted - not just Rough_Correction_Minimum_KC_Advance_Map_Value involved.
This is a good reference - http://www.romraider.com/forum/topic1840.html
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
s2d4 (03-12-2014), steve99 (03-12-2014)
Old 03-11-2014, 12:13 PM   #72
jamesm
that pretty much mirrors the other docs i've read, actually suggesting that the last applied FLKC value be >= 3.9 degrees... and that the advance value in the map be greater than 4.9 (which i hadn't seen before, i'd only read about the FLKC value). it doesn't seem to mention anything about a value in a table, unless they just skipped over that bit:
To exit from fine correction mode to rough correction mode, ALL of the following requirements must be met:
  • Engine speed and load must be within the ranges specified by the 'Rough Correction Range' tables.
  • Timing advance (maximum) map value is greater than 4.9 degrees.
  • Some FLKC value change (positive or negative) occured last execution.
  • The last FLKC applied value (|x|) is greater than 3.9 degrees (that is, the absolute correction -> ex. -4 = 4)
  • The last FLKC raw difference (|y| * 2.84) is greater than last timing advance (maximum) map value.
  • (IAM > 1) or (IAM <= 1 and last applied FLKC was positive).
Of course this all applies to a car that isn't ours... it could totally be wrong. I have found through experimentation that using less than 3.9 in the advance table keeps it from dropping, that's all i know for sure. then again, i often set it to zero in those areas just coincidentally, so maybe that's why it doesn't seem as though the table matters. i could swear i remember running 0<value<3.9 in the advance and not seeing it drop, though i cant be sure about that without correlating old roms to logs or testing it again.
Old 03-11-2014, 01:39 PM   #73
Td-d
Yeah, it is odd that that's the case. Maybe setting that value to 0 changes the way the logic handles the advance tables - I've never really looked at it closely. The logic is pretty much the same as other Subarus, incidentally.
The Following 3 Users Say Thank You to Td-d For This Useful Post:
jamesm (03-12-2014), s2d4 (03-12-2014), steve99 (03-11-2014)
Old 03-11-2014, 11:07 PM   #74
s2d4
s2d4's Avatar
Code:
If (in fine correction) {
           If (pulled more than 4 degrees or the ECU is unhappy) {
                  Goto (IAM correction)
            If (Large/rapid change in engine load) {
                  Goto (FBKC)
} else {
           Check to see if any adjustments need to be made
           Stay in FLKC correction mode
If (in FBKC mode) {
      While (engine load is rapidly changing) {
            Check for knock and pull timing if needed
            When (Done) {
                     Go back to previous mode
According to the above, it would be part of fbkc as tip in would be where the load changed rapidly. This falls in line with my earlier log as knock correction as according to shiv is fbkc.
Looks like I'll need access to flkc @shiv@vishnu to confirm for myself or @Td-d /anyone with previous subaru platforms to clarify if the number in the map that dictates where coarse correction starts is at 4, and since ours is set at 0 so behaves differently.
Old 03-12-2014, 12:24 AM   #75
steve99
Drives: FT86
I did log FLCK as well as FBCK (via tactrix logging) very few occurrences of FLCK highest -0.67 compared to many occurrances of FBCK with values up to -2.3.
As for where course correction starts well got no idea
Old 03-12-2014, 12:29 AM   #76
jamesm
Most of the tip in knock I see shows up in fbkc. It'll write into fine learning sometimes though, particularly when tipping in to a long pull.
The Following User Says Thank You to jamesm For This Useful Post:
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 10:41 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
ca-fi knock off questions fionnsfrs Electronics | Audio | NAV | Infotainment 2 10-27-2013 01:47 PM
Knock on e85 not a problem? gdrider77 Forced Induction 76 10-20-2013 11:36 PM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
