Old 03-08-2014, 09:31 AM   #785
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by Kido1986 View Post
I have your answer; order Z2s, mount on the Volt, eat Mini Coopers alive?
Haha I had thought about doing it once just for giggles. The car is surprisingly neutral and rotates on lift easily with the nannies defeated due to all the battery mass being low and in the center of the car. It's a lease though and I wouldn't race a leased vehicle.
John, which ZII's did you go with for the BRZ? 235/40? I have the 235/45s arriving next week (never going 3rd party for wheels/tires again). I'm really interested to compare my mounted 235/45 to a mounted 235/40.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-08-2014, 09:43 AM   #786
Rexpelagi
Drives: 2013 Subaru BRZ
Yep, I went with the 235/40's. I feel like it will probably be the better choice, as it will be faster out of every corner vs. sometimes saving a shift. Even at nationals last year I only had to shift once, and I think it was fast enough that even on 235/45's a shift would have been required. It may be worth a try though, and I can take measurements though if you want once they are mounted.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 03-08-2014, 09:51 AM   #787
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
That'd be great, I'd appreciate it.
I also went with the bigger size not just for the final drive ratio adjustment, but also because the taller sidewall will be less pinched on the 7" wide wheel. According to Dunlop, the acceptable rim width range is 8"-9.5" for the 40 A/R and 7.5-9.0" for the 45 A/R, so the 45 is a little more ideal in comparison as far as the cross section. I'm expecting it to be a little more numb, but hopefully it'll have a little better dynamic contact patch than the more stretched 40 A/R... I'm not real convinced myself, but it's a theory, and I figure someone might as well give it a shot!
Old 03-10-2014, 06:31 PM   #788
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Anyone trying 245/40/17s on stock rim?
cactus is offline   Reply With Quote
Old 03-10-2014, 07:42 PM   #789
itzmik3
DBC Racing
itzmik3's Avatar
not on a stock rim, but yes on a 17x7
#194 SM
itzmik3 is offline   Reply With Quote
Old 03-10-2014, 07:52 PM   #790
vroom4
And I thought the 225 rivals felt spungy compared to a 215... I cant even imagine a 245.
vroom4 is offline   Reply With Quote
Old 03-10-2014, 09:06 PM   #791
itzmik3
DBC Racing
itzmik3's Avatar
well we run higher pressures to compensate for the "spungy" feeling.
#194 SM
Old 03-11-2014, 09:52 AM   #792
SeanRTR
C-Street AutoX
SeanRTR's Avatar
What did you run on the 225, compared to the 245?
I'm going to keep my 225/45/17 in the front, but run the 245/40/17's in the rear. My car was always fairly loose on concrete. I'm hoping this new setup helps that, and allows me to run a bit more rear shock.
SeanRTR is offline   Reply With Quote
Old 03-11-2014, 10:01 AM   #793
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
I just installed 215/45/17 ZIIs, and now I'm kinda wishing I had put on some bigger tires.
Thrustin is offline   Reply With Quote
Old 03-11-2014, 12:14 PM   #794
itzmik3
DBC Racing
itzmik3's Avatar
if i remember correctly we ran in the mid to low 30's on the 225 set up.
currently running high 30's on the 245
what kinda of set up are you running right now?
shock? bar?
#194 SM
Old 03-11-2014, 12:17 PM   #795
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I think Sean may just have to retrain his right foot to not pedal it like it's a Neon on giant Hoosiers
Old 03-11-2014, 12:23 PM   #796
itzmik3
DBC Racing
itzmik3's Avatar
i would definitely just say to run on that set up and see how you like it
from there decide if you need to go wider.
#194 SM
Old 03-11-2014, 12:44 PM   #797
SeanRTR
C-Street AutoX
SeanRTR's Avatar
shock? bar?
FR-S: 22mm perrin front bar, on soft. Koni yellows, generally 1/2 - 3/4 from full stiff up front 1/2 - 3/4 from full soft in rear. This setup was good enough for one of the final trophy spots at nationals, on Rivals.
I'll probably do the 235/40/17 Dunlops if I make the trip to Nebraska again....but I don't see the sense in running a tire that doesn't offer contigency for the tours/pro's/match tours when the BFG was just as good/better at what seems like every surface other than a well rubbered in Lincoln airport.
Old 03-17-2014, 06:48 PM   #798
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Originally Posted by chucky12012 View Post
Not to change the topic of discussion, but I got my Bilstein HD (B6) struts/shocks today! They'll be going on this Saturday so that I can try them out at my local autocross this Sunday.
Were you able to get these installed? If so how do you like them?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
