Sam Strano
Old 03-07-2014, 10:28 AM   #771
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by AustinTX View Post
The CS winning 370Z from last year was in the 3250lb range.
Interesting. I don't know what folks are running for street, but out of several options I think I'd start with 285/30-18 ZII's all around. Spec tread width on those is 10.7" vs 8.7" on 235/40-17's. 3250/10.7 ~= 2630/8.7
Now I know this is way simplistic and analyses with sprung/unsprung masses, cg and roll center positions, etc are required to really compare. Hopefully that would show a decent advantage for the 86, because 3250/332hp is no question way better than 2630/200hp! ;-)
jdrxb9 is offline   Reply With Quote
Old 03-07-2014, 10:50 AM   #772
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Did your co-driver from nationals Mr. Laughlin jump ship to a different car?
I see he's registered for the Match tour in an Rx8....
I'm on the fence for that event, I love Wilmington, but I really prefer the traditional National Tour 3 + 3 format over Match tours and even Pro's.
4+2 runs on the same exact course doesn't really do much for me, especially given our current index #'s.
SeanRTR is offline   Reply With Quote
Old 03-07-2014, 11:39 AM   #773
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I hope someone figures out that it would be better to use the new Pro index for Match tours instead of Rick Ruth's asinine index.
Almost makes me not want to drive to Atlanta for the Match tour.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 03-07-2014, 11:57 AM   #774
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
For Match Tours, it really only matters for making the cut, after that you're on your dial-in. It's really not a bad compromise compared to last year.
TomR
ABQautoxer is offline   Reply With Quote
Old 03-07-2014, 12:28 PM   #775
Kido1986
Dodging cones
Kido1986's Avatar
Gotcha. I was thinking in terms of last year's setup. Though Im not good enough to get high enough for the knee-capped Pax to allow me to stay in
Old 03-07-2014, 12:45 PM   #776
jdrxb9
jdrxb9's Avatar
Well, you'd have to ask him, but I think he's still deciding - see above.
As alluded to by ABQ, if street can collectively get enough entries (roughly 25%), hopefully they will all get put in their own heat. Then, it won't matter how the street indexes compare to the non-street class indexes. You can count me out for making numbers, though, as I won't be there.
from: http://www.scca.com/assets/2014%20Ma...r%20Rules1.pdf
"k) Pro Shootout
Qualifying: The top in index per heat will qualify for the Pro Shootout with the following schedule for each number of heats.
4 Heats:
• For the Top 32, the top 8 drivers in index from each heat."
(my bold)
Old 03-07-2014, 01:01 PM   #777
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
"k) Pro Shootout
4 Heats:
(my bold)
Not looking very likely... as of today there are 118 entries and 17 in Street (14.4%)... Street R currently has 17 no including ladies classes as well.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-07-2014, 01:12 PM   #778
jdrxb9
jdrxb9's Avatar
Well, you only need 17 more then (with no other non-street entries)! ;-)
Or, start lobbying whoever is going to setup the heats as to what other classes with 'tough' indexes should be grouped with street #-o
Old 03-07-2014, 01:53 PM   #779
mrazny
Drives: BMW 135i, soon to BRZ
reverse conspiracy theorizing (or Self-fulfilling prophecy syndrome):
Don't you think that the vociferous complaints about PAX-capping is contributing to the lesser entries? Beyond just the normal scope of those particular PAX values meaning anything to the potential entrants?
Also, wilmington last year gives a much more interesting data point. Campbell entered his DSP bmw in SM because DSP wasn't going to make a class. And still Pax'd 12th out of 258. That PAX handicap he chose to give himself? .012
And if he raced on a DSP index? he'd have gotten 6th.
And above all of this, Wilmington is awesome, and any excuse is easily outweighed by how awesome the site is.
mrazny is offline   Reply With Quote
Old 03-07-2014, 02:18 PM   #780
Rexpelagi
Drives: 2013 Subaru BRZ
I'm undecided, but I may use Wilmington to decide which car to focus with this year. On paper I think the RX-8 may actually be a little quicker but if I can arrange it I'm going to try to run both of my cars at the same event (local) and compare.
Don't worry though, I'm posting from the garage in the middle of installing Konis on my BRZ, and my 235 ZII's should arrive in a few hours. :-)
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
The Following 2 Users Say Thank You to Rexpelagi For This Useful Post:
AustinTX (03-07-2014), Kido1986 (03-07-2014)
Old 03-07-2014, 03:13 PM   #781
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I'm having a hard enough time deciding on tires, I can't imagine trying to choose between 2 cars in the same class
Old 03-07-2014, 03:50 PM   #782
Kido1986
Dodging cones
Kido1986's Avatar
I have your answer; order Z2s, mount on the Volt, eat Mini Coopers alive?
Old 03-07-2014, 03:54 PM   #783
vroom4
you forgot the step about waiting for rain!
vroom4 is offline   Reply With Quote
Old 03-08-2014, 08:54 AM   #784
Rexpelagi
Tell me about it!
-John L.
2011 BMW M3 - 57 FS
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
