Old 03-10-2014, 11:58 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Wheel Directory: TWS T66-F 18x9.5 +45
Tires: Hankook Ventus V12 evo 255/35ZR18
Suspension: ST Coilovers
Info on wheels: TWS T66-F site. 15.8 lbs and hubcentric to our cars' spec so no centering rings required. Ordered here from Japanparts. About $2460 for wheels + $500 shipping to CA + $69 customs fee. $80 optional center caps. According to TWS, standard spec orders such as what I ordered can take 90 days. I ordered on 12/9/2013, Japanparts received them from TWS on 3/2/2014, and I received them on 3/4/2014 so 85 days overall. Custom spec orders can take 90+ days and require a minimum order quantity of 20 wheels. There's speculation that CounterSpace Garage is working to make these more attainable stateside.
Suspension settings: Lowered 1.4" (35 mm) all around. Front camber set to max negative w/ pre-slotted holes and stock 16mm bolts and rest of suspension is stock. I've driven it moderately spiritedly through canyons (I'd say at 5/10ths to 7/10ths of the limit since limits are raised with this rubber) so far no rubbing including at full lock.
@DarrenDriven, @CSG David, @CSG Mike
The Following 26 Users Say Thank You to switchlanez For This Useful Post:
adprokid (03-11-2014), akahenry (03-11-2014), Bcarlos (03-26-2014), charged86 (09-21-2014), Clipdat (03-11-2014), coyote (03-11-2014), CSG David (03-11-2014), diss7 (03-11-2014), ericmpena (07-15-2014), Giccin (07-16-2014), gkubed (03-26-2017), Guff (03-13-2014), humanshield (03-11-2014), JoeHK (07-16-2014), JonAvalon (03-11-2014), LRNAD90 (08-03-2023), LXXXV1 (09-05-2014), MAPerformance (03-11-2014), Metabrz (03-11-2014), No Brakes (03-15-2014), PRORICAN (03-11-2014), pumice (03-12-2014), saltywetman (03-14-2021), SuperDave (03-15-2014), supra2nv (04-20-2015), WhiteLightning (03-12-2014)
Old 03-11-2014, 12:32 AM   #2
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Very nice.
I like that the offset tucks the wheels in a little. I'm on 18x9.5+38 and its "pokey to flush" front to rear.
Whats the weight on those bad boys?
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following User Says Thank You to Metabrz For This Useful Post:
switchlanez (03-11-2014)
Old 03-11-2014, 12:33 AM   #3
CSG Mike
CSG Mike's Avatar
I can't comment.
Take that for what you will
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
gkubed (04-26-2016), SkAsphalt (03-11-2014), switchlanez (03-11-2014)
Old 03-11-2014, 12:47 AM   #4
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Congrats, the spokes make them look like 19", they look beautiful on the car
adprokid is offline   Reply With Quote
The Following User Says Thank You to adprokid For This Useful Post:
Old 03-11-2014, 12:51 AM   #5
Ro_Ja
Drives: TOYOTA
Excellent.
Ro_Ja is offline   Reply With Quote
The Following User Says Thank You to Ro_Ja For This Useful Post:
Old 03-11-2014, 01:02 AM   #6
switchlanez
15.8 lbs. I added it to the description. And tires are 23 lbs. On an analog scale they weighed about 39 lbs together.
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
Metabrz (03-13-2014), OICU812 (03-11-2014)
Old 03-11-2014, 01:44 AM   #7
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
39lbs with that much grip that's well (EPIC)
Btw sure looks lot lower then 1.4" pics are so deceiving.
Btw @DarrenDriven for add to wheel directory as these wheels are rare.
The Following 3 Users Say Thank You to OICU812 For This Useful Post:
CSG Mike (03-11-2014), SkAsphalt (03-11-2014), switchlanez (03-11-2014)
Old 03-11-2014, 01:59 AM   #8
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Very good looking set of wheels you have there!
Drift&Drag is offline   Reply With Quote
The Following User Says Thank You to Drift&Drag For This Useful Post:
Old 03-11-2014, 02:10 AM   #9
mfbmike
Drives: 2013 FRS, 2008 R32
And here I am thinking my new wheels that are 17 lbs in 18x9.5 are lightweight.
Nice setup sir.
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Old 03-11-2014, 10:31 AM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mess pants so hard
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
switchlanez (03-11-2014), Zach3794 (04-05-2014)
Old 03-11-2014, 11:24 AM   #11
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Suspension settings: Lowered 1.4" (35 mm) all around. Front camber set to max negative w/ pre-slotted holes and stock 16mm bolts and rest of suspension is stock. Have yet to drive it harder than in city driving but so far no rubbing including at full lock.
So you dont have top mount front?
did you run 16mm crush bolt in the slotted upper holes? sounds kinda dangerous...
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 03-11-2014, 11:32 AM   #12
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
These are my next wheels..
how long was the wait time
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 03-11-2014, 12:13 PM   #13
switchlanez
Nah, rest is stock like I tried to clearly state. And these are the 16mm stock bolts that come stock on everybody's car, not the 14mm crash/camber bolts you might be thinking.
I tried to state it clearly in the OP because I figured people would ask but 85 days.
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
Figo (03-11-2014), leicaboss (03-15-2014), SkAsphalt (03-11-2014)
Old 03-11-2014, 12:19 PM   #14
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
My bad, i scrolled down to quick to view the pics. lol
Wheel Directory: STR 603 18x9.0 +40 malubawla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-06-2015 01:05 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 04:09 AM
Wheel Directory: ESM 004 18x9.0 +38 beebo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 06-13-2014 01:34 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
Wheel Directory: XXR 531 18x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-10-2013 02:41 PM
