Old 03-09-2014, 11:01 PM   #267
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by akyp View Post
Correct. Stage 1 1.55b OTS map.
Shiv@Openflash is offline   Reply With Quote
Old 03-10-2014, 06:38 AM   #268
s2d4
s2d4's Avatar
@shiv@vishnu
I did ask in a different thread where others were reporting/documenting the tip in knock problem/phenomenon. There were a couple of suggestions which I'll get around to when I am back home next week.
What would you do to mitigate it? Have you looked for this on your car?
No reports of this on US cars or do people just not log it?
The new firmware just came out and it seems weird that only a couple of aussies are looking at this and we are both on much higher quality fuel.
http://datazap.me/u/s2d4/ofh-stock-i...zoom=3784-4790
The Following User Says Thank You to s2d4 For This Useful Post:
steve99 (03-10-2014)
Old 03-10-2014, 02:22 PM   #269
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Hey @shiv@vishnu, quick question on gas used to create the OTS tunes - I'm assuming your 93 in California is a 10% ethanol blend?
Currently using 91 oct Shell V-Power in Canada (to keep crickets away) but thinking of upping to a 94 Octane / E10 blend for more aggressive driving this summer.
Thanks.
1Cor10:23 is offline   Reply With Quote
Old 03-10-2014, 02:26 PM   #270
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Thanks.
He actually tuned using 91 octane is that is the only piss fuel that California is able to provide without buying 100 octane race fuel (unless you get some e85 that is).
Luckrider is offline   Reply With Quote
Old 03-10-2014, 08:20 PM   #271
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Originally Posted by shiv@vishnu View Post
He is in the middle of the custom tuning process. He is running an FA20 CAI which is throwing off the MAF calibration quite a bit. So we are taking things step by step.
Hmm I'm also running with a FA20 CAI. With the uel stage 2 tune, I'm getting an Afr of 11.25 under WOT as well T.T
Silly question but is it counter productive to leave the CAI on? Would stock intake be better and would a custom tune make a huge difference?
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 03-10-2014, 08:29 PM   #272
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Not counterproductive, throwing away a CAI is not easy
Stock is proven to work very well
Huge difference in terms of driveability, performance is the unknown
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
ray7792 (03-10-2014)
Old 03-10-2014, 09:57 PM   #273
Malt
Drives: 2015 WRX
What should we be seeing of knock correction factor on our logs?
Malt is offline   Reply With Quote
Old 03-11-2014, 12:34 AM   #274
steve99
Drives: FT86
on 93 or better fuel I would expect
IAM = 1
Knock correction 0.02 (ie no correction ideally)
But this car seems to be destined to have some tip in knock (just as you apply accelerator) in the 1500 - 3000 rpm area especially in the 0.7 to 1.1 engine load range.
This was causing my IAM to dip to 0.8 occasionally even on 100 RON (94 AKI US) fuel if you did a fair bit of driving in this range ie traffic.
Currently I am running a ROM with 0.35 degrees pulled from advance in this RPM/load area . I still get the odd knock correction (-0.67 or -0.33) but much less often and less severe (was occasionally -2.1 or -1.3) and as yet it isn't enough to drop my IAM, it staying pegged at 1. But it only been a couple of days.
Old 03-11-2014, 03:35 AM   #275
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
OFT OTS 1.55b stage 2 dyno
JDL UEL header
Perrin resonated CBE
KN filter
+ OFT OTS 1.55b stage 2 + 98RON pump gas
I did dyno after flashing. so it's not post learned
1. all stock vs
[IMG]
Flickr에서 Yobi-Wan님의 사진 2014. 3. 11. 오후 3 27 44[/IMG]
2. stage 1 ( without JDL UEL header, and It's post learned ) vs
there was FLKC at 7300 RPM . I think that cause torque depression at 7300rpm
http://www.datazap.me/u/yobiwan/oft-...-19&zoom=0-314
[IMG]
Flickr에서 Yobi-Wan님의 사진 2014. 3. 11. 오후 3 27 31[/IMG]
3. and I ordered OFT . I received tracking no. but not shipped yet.
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
Shiv@Openflash (03-13-2014)
Old 03-11-2014, 01:17 PM   #276
Drofnum
Drives: CBS Subaru BRZ
Got my OFT yesterday, flashed and did a little bit of driving. Heres a 3rd gear pull, I think it looks pretty good, may need a bit more learning i've only done about 25 miles or so on it.
http://www.datazap.me/u/drofnum/0311...ata=1-7-8-9-12
Drofnum is offline   Reply With Quote
Old 03-11-2014, 06:24 PM   #277
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Originally Posted by Yobiwan View Post
JDL UEL header
KN filter
Damn that looks like it would feel great. I got the USPS shipping notice for mine, so I hope yo have it in my hot little hands by Friday at the latest. Might have to find an awful lot of excuses to run errands for my wife this weekend.... :-)
Sirsimon is offline   Reply With Quote
Old 03-11-2014, 07:30 PM   #278
wparsons
wparsons's Avatar
@shiv@vishnu, is it safe to use the xdf files from the 1.42 tunes to edit the 1.56b tunes?
flickr
Old 03-11-2014, 09:15 PM   #279
Shiv@Openflash
Drives: 2013 FRS
Yes, but I wouldn't bother using Tuner Pro at this point. Rom Raider is more defined and supports more ROM types.
Old 03-11-2014, 09:26 PM   #280
wparsons
wparsons's Avatar
Even better, thanks!!
flickr
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
