Old 03-10-2014, 12:57 PM   #15
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by YMAA View Post
It's irrelevant whether the intake helps the car or not. I don't want to take the intake off because I don't believe it's the direct cause of the problem, ergo it's not worth the time to take it off. In any case, once I got the car back home I flashed to the most recent Vishnu OFT tune since the dealer seems content to do nothing. The tune may help.
However, I do have another theory. Since I got the car I've been filling the tank at the employee-only gas station at my work because we get a 10-cent discount per gallon. The station does have 93 octane, but contains ethanol. I'm starting to wonder if the station just has lousy gas. I've filled up twice at a station in town that has ethanol-free 91 just because it's been more convenient recently to fill up there, and I've noticed my gas mileage has gone up by almost 3MPG with no changes in driving style. So, for the next few weeks I'm going to fill up there exclusively and see if that helps at all. Unfortunately I haven't found a conveniently-located station with ethanol-free 93.
I don't think your intake or the fuel quality would set this code. This code is caused by an electrical issue. The ECM is seeing over 3800 psi of rail pressure to set that code, and the high pressure pump is simply not capable of delivering that. It's either a faulty sensor, faulty circuit inside the ECM, or a damaged wire harness.
andrew20195 is offline   Reply With Quote
Old 03-10-2014, 08:41 PM   #16
sqbrz
Drives: Dark Gray Metallic BRZ LIMITED
Man it would be nice to get it back. Its starting to get warm outside. If anyone has any ideas it would be great for some input .
sqbrz is offline   Reply With Quote
Old 03-11-2014, 11:58 AM   #17
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Actually, my theory on the fuel appeared to be correct. For over a month on the different gas I haven't had a single CEL thrown on the car.
So all is well.
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 04-16-2014, 12:35 AM   #18
sqbrz
Well they replaced the fuel pressure regulator and all is good for now
I don't think the gas quality had any thing to do with it.
Old 07-31-2014, 05:18 PM   #19
brad fischer
Drives: 2013 BRZ Premium Blue Manual
I had a code P0191 months ago, dealer said it was a Fuel pressure sensor. They ordered it, took a month to arrive. I have been driving without issue for many month and it hasn't been changed yet. Stock car in all aspects. Not sure if I should let them change it now ???
brad fischer is offline   Reply With Quote
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
Why does this forum mark message as read randomly? mike_ekim1024 Site Announcements / Questions / Issues 14 01-28-2014 04:26 PM
Car Alarm Randomly Triggers nathanR Electronics | Audio | NAV | Infotainment 2 09-03-2013 11:41 AM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 09:38 AM
Car randomly doesn't start on slight hill Craig Issues | Warranty | Recalls / TSB 7 02-01-2013 02:48 PM
