#3823 | |
Drives: 2020 DGM BRZ Limited
Sent from my Nexus 5 using Tapatalk |
#3824 |
Drives: Flat grey Toyota 86
Take the rear elbow off. Then you can get to it, but leave it on till you get a replacement from sprintex, they have some in stock in the states. Once you get the new one, carefully remove the old one paying attention to the placement and amount of preload on the bypass, then reinstall using the same placement and amount.
I had to replace mine, not a big deal. |
| The Following User Says Thank You to Lawnik For This Useful Post: | mikalem (03-08-2014) |
#3825 |
http://www.sprintex.com.au/wp-conten...tober-2013.pdf
Call the number at the bottom, the actuator is listed as the last item for the FT86 |
#3826 |
Drives: 2013 SWP BRZ
I've developed a squeak under the hood. Might have to add me under the idler pulley squeak. Of course NAPA isn't opened tomorrow so I can't go buy a new one and test it out. Will have to wait until monday.
For those who developed the issue, how much longer did it last after it started squeaking? I am going to get tuned monday, last thing I need is for that thing to blow up on the dyno.. haha. |
#3827 |
Drives: Raven FR-S
Mine only squeaks while it's cold so far. Just came in from work and I'll probably change mine out tomorrow.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3828 |
#3829 | |
WUB WUB
Drives: 2013 Firestorm
#3830 |
Drives: Scion FR-S
Sorry for the delay! dyno is in!
My build thread, slowly but surely http://www.ft86club.com/forums/showthread.php?t=40509
| The Following 3 Users Say Thank You to phloozy For This Useful Post: |
#3831 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Great results wow. What fuel did you use
#3832 |
#3833 |
Road Warrior
We had a dyno day today, @DeliciousTuning gave me a map to try out.
70mm on 91 Oct with can can of Torco. 263 whp 221 Ftlb Car is Frikkin badass.
| The Following 2 Users Say Thank You to Ryan86 For This Useful Post: | DarrenDriven (03-09-2014), DeliciousTuning (03-10-2014) |
#3834 | |
Drives: Scion FR-S
and it is a ton of fun.
#3835 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Lousy e65 winter mix, but 292 uncorrected whp non-intercooled!
![]() Ton of fun though indeed! BTW looks like we had a bad #1 coil on our car...should be fixed next week and back on the dyno within a week or two after that. tendogy can add our name to the bad coil after IC list. Leaning it out worked wonders and now running pretty well again. Think the IC just creates enough of a restriction that it pushes the AFR rich enough to show the bad coil if it is there. |
| The Following User Says Thank You to Xero-Limit For This Useful Post: | evo4g63 (03-09-2014) |
#3836 |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
| The Following User Says Thank You to evo4g63 For This Useful Post: | phloozy (03-09-2014) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
