Old 03-08-2014, 06:16 PM   #3823
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by moto-mike View Post
It's a standard eaton type actuator. You can probably get one from Innovate, if not then search around. One of the guys here used a buick one to do a custom WMI bypass. Not the end of the world, but definitely no road trips until that's fixed.
Do you have access to the various parts, like a schematic or something? I don't see how I can take that off at first glance. Thanks for the info! (Also, would it be something you could special order? Or will I need to contact innovate directly?)
mikalem is offline   Reply With Quote
Old 03-08-2014, 07:49 PM   #3824
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Take the rear elbow off. Then you can get to it, but leave it on till you get a replacement from sprintex, they have some in stock in the states. Once you get the new one, carefully remove the old one paying attention to the placement and amount of preload on the bypass, then reinstall using the same placement and amount.
I had to replace mine, not a big deal.
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
mikalem (03-08-2014)
Old 03-08-2014, 07:58 PM   #3825
Lawnik
Lawnik's Avatar
http://www.sprintex.com.au/wp-conten...tober-2013.pdf
Call the number at the bottom, the actuator is listed as the last item for the FT86
Old 03-08-2014, 08:40 PM   #3826
xxscaxx
Drives: 2013 SWP BRZ
I've developed a squeak under the hood. Might have to add me under the idler pulley squeak. Of course NAPA isn't opened tomorrow so I can't go buy a new one and test it out. Will have to wait until monday.
For those who developed the issue, how much longer did it last after it started squeaking? I am going to get tuned monday, last thing I need is for that thing to blow up on the dyno.. haha.
xxscaxx is offline   Reply With Quote
Old 03-08-2014, 08:54 PM   #3827
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Mine only squeaks while it's cold so far. Just came in from work and I'll probably change mine out tomorrow.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-08-2014, 08:56 PM   #3828
xxscaxx
It could be associated with the cold on mine as well, as it just started recently.
Old 03-08-2014, 09:00 PM   #3829
wrxgoose
WUB WUB
Drives: 2013 Firestorm
should see if there's a pep boys near you. open 7 days a week, and if it's a speed shop, you may be in luck
wrxgoose is offline   Reply With Quote
Old 03-09-2014, 11:09 AM   #3830
phloozy
phloozy's Avatar
Drives: Scion FR-S
Sorry for the delay! dyno is in!
phloozy is offline   Reply With Quote
The Following 3 Users Say Thank You to phloozy For This Useful Post:
Calum (03-09-2014), DarrenDriven (03-09-2014), evo4g63 (03-09-2014)
Old 03-09-2014, 11:22 AM   #3831
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Great results wow. What fuel did you use
Ryan86 is offline   Reply With Quote
Old 03-09-2014, 11:27 AM   #3832
xwd
From his build thread that's E85 with the 70MM Raceseng pulley. Great dyno plot must be a blast to drive. If only Subaru had made it that way from the factory.
Old 03-09-2014, 11:34 AM   #3833
Ryan86
Road Warrior
Ryan86's Avatar
We had a dyno day today, @DeliciousTuning gave me a map to try out.
70mm on 91 Oct with can can of Torco.
263 whp 221 Ftlb
Car is Frikkin badass.
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
DarrenDriven (03-09-2014), DeliciousTuning (03-10-2014)
Old 03-09-2014, 11:41 AM   #3834
phloozy
phloozy's Avatar
Drives: Scion FR-S
what he said, e85 and it is a ton of fun.
Old 03-09-2014, 02:44 PM   #3835
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Lousy e65 winter mix, but 292 uncorrected whp non-intercooled!
Ton of fun though indeed!
BTW looks like we had a bad #1 coil on our car...should be fixed next week and back on the dyno within a week or two after that. tendogy can add our name to the bad coil after IC list. Leaning it out worked wonders and now running pretty well again. Think the IC just creates enough of a restriction that it pushes the AFR rich enough to show the bad coil if it is there.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 03-09-2014, 02:59 PM   #3836
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Very nice, congrats
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
The Following User Says Thank You to evo4g63 For This Useful Post:
phloozy (03-09-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
