Old 03-08-2014, 02:09 PM   #71
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Td-d View Post
Care to share which tables?
Sure thing.
MAF Correction After Start x2- In Gear and Neutral (3d)
Target Idle Maps x9
Ignition Timing after Starting
Ignition Timing Idle x4 - 2x In Gear Above Threshold, In Gear Below Threshold, Neutral
I've not touched the Idle air flow map or engine load map although I'm sure these should be dialled in. I just can't tie in the load to the air flow.
.: Stealth 86 :.
Kodename 47 DJ:
troek (03-08-2014)
Old 03-08-2014, 02:34 PM   #72
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Kodename47 View Post
Sure thing.
Target Idle Maps x9
Those are all available in romraider. However, I am willing to bet a number of codes are turned off that would be thrown otherwise.
I only played with the after start timing (set it to 0 rather than -15) and the 9 target idle tables. What I observed is that it overshoots the cold start idle by a large amount due to the extra 15 degrees of timing advance and then has to fight to bring the idle back down to where it should be, it may stabilize after a couple of cold starts.
However, the Start of Injection table used during the cold start is NOT available yet with opensource tools and I suspect not in EcuTek either so the idea of just throwing an extra 15 or 30 degrees (if you set the after start to the post cold start base of 15 degrees advance) of timing advance with very late start of injection is not appealing to me.
What we need is an on / off bit to flip to cancel the cold start routine. I suspect there is one, but if not we still need a couple more tables to have full control.
Old 03-08-2014, 02:39 PM   #73
mad_sb
Originally Posted by regal View Post
yes 900 from the get-go. The only thing not stock are 16" WRX winter tire wheels sans the air pressure senders. I think I may buy the equipment to flash to the latest factory tune as my only trip to the dealer was for that early CEL flash that had to do with idle. I want to be able to DIY as much as I can anyway.
That's broke for sure man, I can't imagine why you don't have any codes. I would suspect the dealer borked something when you had it in last time (the only time) as I don't think a reflash would cause that behavior.
Pick up a tactrix open port 2 cable and a free copy of techstream as a start, you can at least pull codes, code history, customize a few settings like drl's, seatbelt warnings etc, log all the obdII params etc etc. OP2 will work with all the opensource stuff, brzedit, and tech stream.
You could also go the ecutek route if you want but the initial cost is MUCH higher.
I also know someone selling their brzedit personal license, pm me if you want the details.
Old 03-08-2014, 02:42 PM   #74
Kodename47
Kodename47's Avatar
Drives: UK GT86
The MAF correction after start is the table that makes the real difference it seems. No codes have been turned off.
.: Stealth 86 :.
Kodename 47 DJ:
mad_sb (03-09-2014)
Old 03-08-2014, 08:52 PM   #75
troek
troek's Avatar
Drives: 2012 Toyota 86
Do u still see injection at 45 degrees after youve modified this?
i also havnt been able to find the "maf correction after start" tables.
anyone messed with the catalyst warm up tables under ignition ignition timing- compensation?
troek is offline   Reply With Quote
Old 03-08-2014, 11:58 PM   #76
steve99
Drives: FT86
nope have not messed with them. If you give the accelerator a couple light taps it seems to speed up the process and it get out of the 1500rpm / ignition retarded idle faster. Although its pretty warm where I am so might not work in cold places.
Old 03-09-2014, 10:47 AM   #77
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Are we talking about these tables?
Td-d is offline   Reply With Quote
Old 03-09-2014, 11:34 AM   #78
Td-d
Or are talking about these tables (referenced by coolant temp and idle mode)
Old 03-09-2014, 07:25 PM   #79
Kodename47
Kodename47's Avatar
Drives: UK GT86
This one.
Mode 1 is with the engine not running, 2 is the engine during cold start procedure.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-09-2014, 07:46 PM   #80
troek
troek's Avatar
What values have u tried?
EDIT: I cant seem to find that table in RomRaider.
Old 03-10-2014, 07:25 AM   #81
Td-d
I still need to implement these two tables. Will try today.
Sent from my iPad using Tapatalk HD
The Following 2 Users Say Thank You to Td-d For This Useful Post:
mad_sb (03-10-2014), Sportsguy83 (03-11-2014)
Old 03-10-2014, 10:01 AM   #82
Td-d
Ok, I've implemented into ZA1JA01C, download this definition:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml
Old 03-10-2014, 10:01 AM   #83
Td-d
They are in the Mass Airflow / Engine Load section.
The Following User Says Thank You to Td-d For This Useful Post:
mad_sb (03-10-2014)
Old 03-10-2014, 10:20 AM   #84
Td-d
@troek - what's your CAL id?
Nevermind, I've added to ZA1JA01A, here:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01A.xml
troek (03-10-2014)
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
