Old 03-09-2014, 04:51 AM   #1
notout86
Drives: GTS 86 auto
cornering-on-rails feeling
Now and again when cornering (not hard but a little bit vigorously) I get a cornering-on-rails feeling. It feels great and the wife will comment on it spontaneously.
What is the secret?
GTS86 Auto (Australia)
Old 03-09-2014, 04:55 AM   #2
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
are you talking about driving? or something else?
Atticus808 is offline   Reply With Quote
The Following 8 Users Say Thank You to Atticus808 For This Useful Post:
brandonblt2 (09-16-2015), calmtigers (09-15-2015), fatalelement (09-15-2015), GT86_PRAGUE (09-15-2015), ix2vi (03-19-2014), jonkim2 (03-17-2014), Ramster (03-20-2014), sprintertrueno86 (03-09-2014)
Old 03-09-2014, 05:09 AM   #3
lsxiong
Drives: 92 Integra
You might be trying to describe the feeling you get when you maintain a good constant speed around the corner while accelerating just when you're about to finish the turn around the corner. Being the in correct gear helps to maintain the momentum and being close to the corner maximizes the effect. Done right, it feels like you're slinging your car around and out of the corner.
lsxiong is offline   Reply With Quote
The Following 4 Users Say Thank You to lsxiong For This Useful Post:
axelo (09-20-2015), dnieves (09-15-2015), notout86 (09-15-2015), stock (03-16-2014)
Old 03-09-2014, 08:12 AM   #4
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
Agreed. Accelerating through a corner feels as if there is less body roll vs laying of the gas. It is a glorious feeling.
hamzam is offline   Reply With Quote
Old 03-09-2014, 09:28 AM   #5
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
What is the secret?
I get that feeling all the time thanks to camber and R comps (1.2 G's)
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 03-09-2014, 09:40 AM   #6
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
That is when you are approaching the threshold without sliding. If you go to the point where you slid the rear (drift or oversteer) or the front (push or under steer), you are loosing traction and actually exiting the turn slower.
John
jdcorbitt3 is offline   Reply With Quote
Old 03-09-2014, 09:49 AM   #7
Mikem53
Drives: FR-S 6MT
What is the secret?
The car is low and wide.. Low COG, lightweight so less mass for inertia to deal with.. All this on skinny tires too!
Which is why I enjoy this car so much! This car has a one piece feel to it because the wheels and tires are not fat and heavy.. So the car moves as one piece and doesn't feel heavy and dull at the corners..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Bristecom (03-19-2014)
Old 03-09-2014, 01:44 PM   #8
FRStock
Drives: 13 FRS
I had that feeling yesterday...then the rear end started sliding out. TC caught it. IT wasn't scary, just a gradual slide.
FRStock is offline   Reply With Quote
Old 03-10-2014, 12:10 AM   #9
notout86
Drives: GTS 86 auto
Thanks... I reckon you have nailed it. I have noticed that it helps to be down a gear or two as extra responsiveness often seems a necessary ingredient. I wonder if sometimes when I do not get the feeling it is because the revs are somewhere in the dreaded torque dip.
Such a sensitive creature this car and I'm a clumsy bastard. I'm off to practise.
Old 03-10-2014, 12:23 AM   #10
Tromatic
The whole purpose of this car. They did a stellar job on it.
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
Drive (03-10-2014), Impureclient (09-15-2015)
Old 03-10-2014, 12:26 AM   #11
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
It's called rear wheel drive.
Wise is offline   Reply With Quote
Old 03-10-2014, 12:36 AM   #12
fatoni
i think its really a function of the cog being relatively close to the roll axis. i think that distance is proportional to the amount of roll given a particular cornering force. i dont think that cornering speeds are directly related to the feeling though.
Old 03-10-2014, 12:37 AM   #13
fatoni
how do you figure?
Old 03-10-2014, 01:14 AM   #14
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Pretty sure he's just trolling about railing his wife... Although I may be wrong
The Following 14 Users Say Thank You to Turbo95eg6 For This Useful Post:
Akari (03-16-2014), Ammonia (03-19-2014), Brianjoy77 (03-16-2014), calmtigers (09-15-2015), DarthNads (03-19-2014), EsoBOFH (09-15-2015), FRSure (03-16-2014), JB86'd (03-10-2014), Marchy (03-20-2014), MisterSheep (09-15-2015), MokSpeed (09-15-2015), P@ul (03-10-2014), pushrod (09-15-2015), zenki_levin (03-20-2014)
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 09:04 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 01:49 PM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 09:06 AM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 05:20 PM
