Old 03-05-2014, 02:02 PM   #29
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by mxrider404 View Post
Yea based on the input you guys have given and some other research I think I may go with dunlops. Any idea of what the widest tire I can put on the stock rims? Without rubbing that is.
225/45/17 is the widest I'd go for a dual-purpose setup (daily and AutoX). Guys with separate wheels/tires, sometimes use 235/40/17 Dunlop Z2s on stock sized wheels, but I don't think that's ideal if you're going to use them for daily driving too.
jprice130 is offline   Reply With Quote
Old 03-05-2014, 02:03 PM   #30
vroom4
you can shove a 245/40 on there...but I would...and did...go with a 225/45 for the zii for autox this season.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
jprice130 (03-05-2014)
Old 03-05-2014, 02:43 PM   #31
wparsons
wparsons's Avatar
A 245/40 on the 7" wheel will be pretty mushy, the minimum recommended wheel width is 8".
I'm running 225/45's on an 8" wheel and wouldn't want to consider running wider tires on a narrower wheel.
For the stock wheels, I would go 215/45 or 225/45.
flickr
Old 03-06-2014, 04:30 PM   #32
Lisak6841
Lisak6841's Avatar
Drives: 2013 scion fr-s
Anyone doing autox running nittos?
Lisak6841 is offline   Reply With Quote
Old 03-07-2014, 04:47 PM   #33
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
How about Hankook V12 Ventus? I've heard great things, but not sure how they stack up.
leicaboss is offline   Reply With Quote
Old 03-07-2014, 10:25 PM   #34
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
They are good for the price but when compared with PSS or RE-11 there is no comparison. If you don't have the money for PSS priced tires V12s are a great choice!
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-07-2014, 11:57 PM   #35
leicaboss
Coffee Snob
leicaboss's Avatar
How do the PSS and RE-11 stack up in rain though? Would hope they are grippy enough to tackle that.
Old 03-08-2014, 10:31 AM   #36
Thorpedo
The SquadWhisperer
"Grippy-ness" is largely unrelated to how they perform in the rain. It is the tread design that determines that. The ZII and RE11A will have much more grip than the PSS or the v12 in dry conditions, yet in the rain the PSS would probably take the cake. I know the RE11A is pretty damn good in the wet though.
Thorpedo is offline   Reply With Quote
The Following User Says Thank You to Thorpedo For This Useful Post:
leicaboss (03-09-2014)
Old 03-09-2014, 09:51 AM   #37
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
I have 225 45 ZII's and like them. A bit Noisy but good for autoX and also good in rain. I would not use them in weather under 40 deg of course.
Gearhd79 is offline   Reply With Quote
The Following User Says Thank You to Gearhd79 For This Useful Post:
fstlane (03-09-2014)
Old 03-09-2014, 09:52 AM   #38
ZDan
ZDan's Avatar
Drives: '23 BRZ
Two aspects to tire performance in the rain: Wet grip and hydroplaning resistance.
A tire's grippiness has *everything* to do with how well it performs in the rain when there's little to no standing water (which is most of the time on most roads in most rain conditions). Most current Extreme Performance and even some DOT R-compound tires will give very good grip in warm/wet conditions as long as there is not a lot of standing water, even though they may sacrifice some wet grip due to the compound being more optimized for sustained high-temperature grip. A tire optimized for rain conditions like Hoosier H20 will have a *very* soft and grippy compound indeed!
Grippiness is extremely important in wet conditions! And some tires that are OK in the dry suck in the wet. Wet grip is the main thing I look for in a street tire. Tire Rack tests give a good indication of this.
Tread pattern determines how resistant the tire is to hydroplaning, and as suggested isn't related to the compound's "grippiness". It's just a mechanical function of how well the tread pattern is able to channel water. Once you reach hydroplaning speed, of course the "grippiness" of the tire in wet conditions doesn't matter any more!
You can have a tire with excellent "wet grip" but poor hydroplaning resistance, and you can have a tire with poor "wet grip" but excellent hydroplaning resistance.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
leicaboss (03-09-2014), WRB-DZA-BRZ (04-07-2014)
Old 03-09-2014, 10:12 AM   #39
wparsons
wparsons's Avatar
FWIW, I've been on a highway at 120-130km/h in POURING rain many times with my ZII's and they were just as stable as the all seasons on my wife's Camry. The only time I felt them hydroplane at all was driving through a couple inches of standing water on one side, it wasn't too scary because the other side of the car still had grip.
flickr
Old 03-09-2014, 04:18 PM   #40
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Do you have pictures of this? They are cheaper than the 235/40(not by much) and If I dont like how they feel on the 7in rim, I wouldn't mind running them on a wider wheel for DD duty.
cactus is offline   Reply With Quote
Old 03-11-2014, 02:22 PM   #41
mxrider404
mxrider404's Avatar
Drives: 2014 Scion FRS Pearl White 6 Speed
Do you have any pictures of this set up? Thanks!
mxrider404 is offline   Reply With Quote
Old 03-11-2014, 02:41 PM   #42
Thorpedo
The SquadWhisperer
You're absolutely right, i definitely should have been more clear. For whatever reason when i wrote my original comment I was thinking more on the lines of hyrdoplaning resistance when I said "wet grip". Hydroplaning resistance is key for me. So long as the pavement is just damp or with only a slight covering of water, these tires will perform great.
XXR 527_ Good or bad wheels for autocross karma003 Tracking / Autocross / HPDE / Drifting 42 05-22-2014 10:33 AM
Good wheel/tire set up for daily driver Oburn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-10-2013 03:21 PM
Autocross/18x8 wheels/what tires? rmz290 Tracking / Autocross / HPDE / Drifting 6 04-22-2013 01:34 PM
I slip my rear tires on a daily basis.... Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 16 07-28-2012 12:44 AM
Good sporty daily driver? Staticz Scion FR-S / Toyota 86 GT86 General Forum 79 03-01-2012 05:20 PM
