Old 03-06-2014, 01:21 PM   #15
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Originally Posted by fourvalleys View Post
That is only red VHT.
I didn't think it would darken as much as it did with a second coat.
e: here are a couple other pictures. It's dark, but not super dark.
[IMG]snip[/IMG]
Here's how it looked (wet) after the first coat. When this coat dried it was noticeably darker.
[IMG]snip[/IMG]
This is what ONE coat of VHT Red looks like in direct sunlight:
[IMG]snip[/IMG]
Thats strange, do you think maybe the clear coat effected the colour because VHT typically turns out way lighter
Those are mine before clear coat.
headlikeahole is offline   Reply With Quote
Old 03-06-2014, 05:46 PM   #16
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
It's VHT Nite-Shades. In retrospect, I think I should have used DupliColor MetalCast, as VHT looks to be a bit darker. I prefer the candy-apple red look over the almost-smoked look, but that's just my preference.
In this order:
- Sprayed 2-3 coats of VHT (light 2000 grit wet-sand between each coat to scuff)
- Sprayed 2 coats of clear (light wet-sand between coats - you may want to do more than two coats)
- wet sand clearcoat once hardened
- 3M hand glaze
If it still isn't perfect...
- went sand again if there are remaining imperfections in the clear
- 3M Hand Glaze
Just give the 3M a day or two to set. If you touch it an hour or two after you hand buff, it will still scratch easily and leave marks. Even a microfiber can leave marks when it's fresh. Just be patient. At least leave it overnight before installing them.
So I started and after sanding and the first coat I have a lot of fine scratches. Is this something that will dissapear with more coats or will it still be seen after everything is done?
Name:  tailight scratch.jpg
Husker BRZ is offline   Reply With Quote
Old 03-06-2014, 05:49 PM   #17
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Anyone know any good shops in SoCal that do this ? I feel like id mess it up.
Old 03-06-2014, 05:53 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
does anyone know if using a spray gun is better?
what kinda paint do i use for candy red?
Old 03-06-2014, 06:32 PM   #19
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Clearcoat them well or they will look like hell in a few years. One of the local guys up here did the redding out and sanding himself, and then took the lights to a shop for the clear coat. They look OEM
OjiGeorge is offline   Reply With Quote
Old 03-06-2014, 06:40 PM   #20
CB390248
Drives: Asphalt FR-S
Togue Factory just did mine. I shipped my tails to them, they painted them and sent them back in less than 10 days. They could have done it faster if I wanted ones they had already painted but I was nervous that they might have unknown condensation problems as mine did previously. I haven't yet installed them but they look good. I would recommend them as mine were previously redded out with overlay that looked crappy though professionally done and I was to scared to paint mine myself.
CB390248 is offline   Reply With Quote
Old 03-06-2014, 07:52 PM   #21
soundman98
ProCrastinationConsultant
soundman98's Avatar
Attachment 69422
yes, it will disappear with further coats.
and when you do the final clear coat polish, you will end up with the same type of light scratches-- use polishing compound to remove those, and then follow up with the wax/sealer of your choice.
Husker BRZ (03-06-2014)
Old 03-06-2014, 07:55 PM   #22
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I got a set if you want to buy
professional painted
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
Jolaessss (03-10-2014)
Old 03-10-2014, 06:25 AM   #23
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
How much?
Jolaessss is offline   Reply With Quote
Old 04-01-2014, 05:10 PM   #24
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
@vincent201089 @fourvalleys what clearcoat did you guys use? thanks!
asdf is offline   Reply With Quote
Old 04-01-2014, 05:28 PM   #25
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
I just used a clear lacquer. Nothing special.
fourvalleys is offline   Reply With Quote
Old 04-01-2014, 06:17 PM   #26
headlikeahole
Anyone have any experience using acrylic enamel clear over VHT? I know they can react to paints sometimes and ruin your work, but its also the strongest. I find acrylic laqueur never hardens quite hard enough.
Powder coating vs painting Rims Giccin Other Vehicles & General Automotive Discussions 36 01-28-2015 08:44 PM
WTT: Buddy Club Tails for Clear Toms CreinCrein Canada Classifieds 25 10-15-2014 01:56 PM
*LEGIT USDM TOM'S TAILS US LEGAL! RED LENS & CLEAR LENS $450 AUTHORIZED DEALER!!!* Vicious LED Exterior Parts - Lighting 121 04-19-2014 05:13 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 02:51 PM
Wet sanding curves qoncept Cosmetic Modification (Interior/Exterior/Lighting) 3 07-02-2013 03:50 PM
