Old 02-27-2014, 10:12 PM   #253
shawnhayes
Drives: 2013 Pearl White BRZ Limited
Originally Posted by CARNZ View Post
You would have to replace the upper oil pan/lower engine block section to be able to have the pipe that comes out of the upper oil pan there on the AT cars. A whole lot of work vs installing a fitting!
Dude, did I tell you how much I appreciated all the work you did on this DIY and install? The world is a better place. Even though I had a lot of trouble, I couldn't have done it without you. Good job.
Shawn
shawnhayes is offline   Reply With Quote
Old 02-28-2014, 01:10 PM   #254
CARNZ
CHECK ENGINE
Drives: 2004 STi
No problem, glad you found it useful.
The goal was to find a good OEM solution and this was exactly what I wanted.
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following User Says Thank You to CARNZ For This Useful Post:
jcw99 (04-21-2016)
Old 03-05-2014, 10:54 AM   #255
Guillaume
Guillaume's Avatar
Drives: Exige S 240
3. Install the feed water hose(faces passenger side of engine), Hose (99078AB330) with 2 hose clamps (805918010).
4. Bolt the oil cooler pipe(21328AA220) to the front chain cover of the engine using the 2 purchased bolts (808206010).
Picture is for step 3 and 4
My Subaru dealer tells me that the part #99078AB330 is on back order for another month. Is it replaceable by a regular hose? If yes, which diameter and length?
Guillaume is offline   Reply With Quote
Old 03-05-2014, 12:30 PM   #256
CARNZ
CHECK ENGINE
Drives: 2004 STi
There are currently 18 of those hoses in the warehouses throughout the country and they are ready for immediate delivery.
The hose is 1/2 inch hose, you could use any random hose from the store, the subaru one is pre-shaped for the bends.
EDIT: just noticed your locations says Europe...oops
Guillaume (03-05-2014)
Old 03-05-2014, 12:35 PM   #257
CARNZ
CHECK ENGINE
Drives: 2004 STi
Update on Parts Availability:
21311AA170 - OIL COOLER - Immediate Availability
14050AA970 - WATER PIPE - Immediate Availability
14050AB090 - WATER PIPE - Immediate Availability (interchanges with 14050AA970)
21328AA220 - PIPE,OIL COOLER - Immediate Availability
99078AB330 - WATER HOSE - Immediate Availability
21317AA070 - CONNECTOR, OIL COOLER - Immediate Availability
Looks like the large backorders we originally experienced are gone, so everyone should be able to get these parts fairly quickly.
Old 03-05-2014, 12:36 PM   #258
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks for the answer, I'll try to find a US supplier that ships to Europe for a reasonable fee.
How long would you say the hose is?
Worst case, I am considering using a standard straight hose until the stock replenishes in Europe. Doesn't that sound reasonable (mechanically)?
Old 03-05-2014, 12:41 PM   #259
CARNZ
CHECK ENGINE
Drives: 2004 STi
The hose isnt terribly long, i'd just get a foot and cut it to length. Always better to have more then needed then not enough.
Using generic hose will work, since it's not pre-shaped it won't look as clean but it will get the job done
Old 03-05-2014, 12:49 PM   #260
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Okay thanks
Old 03-05-2014, 07:57 PM   #261
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
My pipe just showed up at the dealer yesterday off backorder. Have all my parts now except for some hose. Probably be a minute before I install them but at least they are here.
Considering doing an aftermarket radiator but will probably just wait and measure temps when at the track this summer. No reason to buy it if its not needed. And I hear they are a PIA to install anyway.
cruizin01 is offline   Reply With Quote
Old 03-05-2014, 08:24 PM   #262
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by normancw View Post
Where did you get the M14x1.5 > -8AN fitting and -8AN heater hose? Looking forward to you install post/pics.
My friend's shop in Ontario, California (not the other Ontario )
As I mentioned previously, this is mostly inspired by other turbo water lines available for other cars.
Something like this:
-alex
Old 03-05-2014, 10:22 PM   #263
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Is there anyone reading who can help me get some part numbers?
I want to (if possible) use the auto trans cooling nipple shown in the top figure, see 11060, Fig 154 <AT>. My car is MT, so I am hoping that I can swap this out for the blank off plate shown for <MT>. What is the part @ 21210?
Cusco appears to be doing this too. See below.
Ralph Spoilsport is offline   Reply With Quote
Old 03-05-2014, 11:41 PM   #264
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
What is the difference between the two part #'s?
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 03-06-2014, 12:05 AM   #265
DM7
Drives: '13 FR-S Argento
http://www.ft86club.com/forums/showp...&postcount=236
They are the same.
DM7 is offline   Reply With Quote
The Following User Says Thank You to DM7 For This Useful Post:
Turkish (03-06-2014)
Old 03-06-2014, 12:28 AM   #266
Turkish
Serial Cone Killer
Turkish's Avatar
Originally Posted by DM7 View Post
Ah, thanks. I missed that post somehow!
... his name is...
C'THULHU
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
