Southern California SoCal
Old 03-03-2014, 05:22 PM   #1
jonbonazza
lift rental
Anywhere near Aliso Viejo that I can rent a lift for a couple hours?
Got an FT86SF catted header and motiv OP to install and don't want to do it with the car on jacks.
jonbonazza is offline   Reply With Quote
Old 03-04-2014, 08:00 AM   #2
YDNA
YDNA's Avatar
Drives: Raven FR-S
im stuck in your boat as well. there's a spot in hollywood or something like that but that's way too far for my liking. i too have to install a header and overpipe hahah
YDNA is offline   Reply With Quote
Old 03-04-2014, 08:07 AM   #3
NorCal_Guy
It's turbo time!
NorCal_Guy's Avatar
Drives: 2013 Scion FRS
Why not save some money and use a jack and Jack stands
NorCal_Guy is offline   Reply With Quote
The Following User Says Thank You to NorCal_Guy For This Useful Post:
Plxdjake89 (03-04-2014)
Old 03-04-2014, 09:48 AM   #4
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
+2 use a jack and jack stands, these are the easiest to install.
Build Thread
Instagram
Old 03-04-2014, 10:15 AM   #5
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I don't think any rental spots are around here. 4 stands would be your best bet to keep the car level. I'm near you if you want to see how I go about the lifting process safely. I did a whole clutch job and turbo install like this, works fine.
You the white BRZ/FRS?
rb6freak is offline   Reply With Quote
Old 03-04-2014, 01:45 PM   #6
jonbonazza
I was under the impression that most headers were a pita to install on jack stands for these cars. Is this not true? At the very least, is the FT86SF unit installable from jack stands?
Old 03-04-2014, 10:01 PM   #7
Jefffrs
Jefffrs's Avatar
Drives: FR-S Turbo 10 Series
If you're willing to drive to the San Gabriel Valley, theres a pretty cool place called "Your Dream Garage". http://www.urdreamgarage.com/
Jefffrs is offline   Reply With Quote
The Following User Says Thank You to Jefffrs For This Useful Post:
jonbonazza (03-04-2014)
Old 03-04-2014, 10:27 PM   #8
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I'm like 2-3 minutes away from this place!
Going to check it out.
Carlitoz3 is offline   Reply With Quote
Old 03-04-2014, 10:47 PM   #9
jonbonazza
Damn... $25/hr?? That's cheap! And it isn't TERRIBLY far away, either!
Old 03-04-2014, 11:29 PM   #10
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
If you need help I'm down to help you. I've changed the over pipe and front pipe. Havent done a header yet tho! It'd be a good one to learn cause i plan on getting headers too!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 03-04-2014, 11:31 PM   #11
jonbonazza
Thanks! I am still waiting to hear how difficult it would be to install this header on jack stands to make my decision on weather to make the drive up to yourdreamgarage or not.
Suppose I should take things right from the horse's mouth and PM FT86SF. I'll let ya know what I find out.
Old 03-04-2014, 11:39 PM   #12
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
I might be able to hook you up with a lift but I'm over here in 626 as well...
jebuwh is offline   Reply With Quote
The Following User Says Thank You to jebuwh For This Useful Post:
Old 03-05-2014, 12:19 AM   #13
Jefffrs
Jefffrs's Avatar
Yeah, and they provide all the tools that you need.
jonbonazza (03-05-2014)
Old 03-05-2014, 12:32 AM   #14
Hachiroku14
Drives: 2014 BRZ World Rally Blue
+1 with http://www.urdreamgarage.com
Hachiroku14 is offline   Reply With Quote
The Following User Says Thank You to Hachiroku14 For This Useful Post:
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 09:51 AM
Lift rental Calidrifter Southern California 15 06-04-2013 11:23 PM
DIY Automotive (Garage/Lift/Tool Rental) Chewie4299 New England 9 02-13-2013 10:17 AM
DIY Automotive (Garage/Lift/Tool Rental) Chewie4299 NY / NJ / CT / PA 2 02-10-2013 08:15 PM
