Old 03-03-2014, 02:25 PM   #29
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by blkwrxwag View Post
Utter rubbish.
maybe for autocross
but on the track, slapping slicks (like an R6) on an otherwise stock car ain't the best move.
our local time attack series assigns modification points based on tire use, with 3 categories (street, R-Comp (like a NT01 or R1/R888) and "ubers" (R6 +))
when we introduced this, most people jumped on the street tires, those that stayed on r-comps had some form of suspension work done, those who decided to stick with the R6s and the like all had major suspension work done or came on full blown race cars.
point is, no one felt they'd be competetive in stock vehicles on slicks.
certainly they're faster than streets, but marginally, and generally not worth the hassle, especially given todays street tire technology.
Old 03-04-2014, 09:45 AM   #30
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by 7thgear View Post
maybe for autocross
Well, autocross is specifically what the OP asked about.
Relax, @Thrustin, you'll be fine. The first run or two might be a little entertaining, but that's about it. Just like anything else, you'll need to figure out pressures...don't be surprised if it's significantly different from a street tire setup. If you get them working properly, the grip can be addictive.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-04-2014, 02:36 PM   #31
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
they're an autocross tire, so i wouldn't use them for lapping
Why?
And Hoosier wants to help you with this: http://www.tirerack.com/images/pdf/warranty/HOOSIER.pdf
dradernh is offline   Reply With Quote
Old 03-04-2014, 02:48 PM   #32
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by dradernh View Post
Why?
they'll overheat and melt. Might not even last you a single session if you stay out for 20 minutes or something.
if you use them at the track for a lap record attempt or something, then 2-4 sessions max depending on track temps, but even then, they might not last past a 2nd outing.
Old 03-04-2014, 03:25 PM   #33
dradernh
Has this been your experience?
Old 03-04-2014, 03:59 PM   #34
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no, i have never ran A6s on the track.
but if my word sounds dubious for you, perhaps a blog from the tirerack will settle your doubts.
http://blog.tirerack.com/blog/choose...for-your-needs
a tire that is designed to heat up in the first seconds of a standing start arn't gonna last you a lapping session on a multi-minute track.
Old 03-04-2014, 04:09 PM   #35
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
An A6 won't "overheat and melt" when used on a track over significant duration. They will get hot and become "greasy" over time. It is true they will degrade much faster, I dont think "melt" is the appropriate verb... they will degrade and start chording much faster when driven hard at a higher sustained temperatures. With all that said, A6's are very commonly used in club racing as a qualifying tire. On the solstice we used to buy take-offs from road racing corvettes all the time and they'd easily last 30-40 autocross runs for us before they were garbage... great as a cheap way to supplement the local events and save the big ticket sticker tires for use at national events and the championship.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post:
neurokinetik (03-04-2014), Thrustin (03-04-2014)
Old 03-04-2014, 04:09 PM   #36
dradernh
Thank you.
Some of us have, and our experiences are quite different than those you suggest should be the case. As always, YMMW.
Old 03-04-2014, 06:26 PM   #37
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Let this thread die before I blow my brains out. LOL!
Element Tuning is offline   Reply With Quote
Old 03-04-2014, 06:31 PM   #38
dradernh
No, no, no!!! Some of us would dearly love to hear what a hotshot like yourself thinks about this subject. Seriously.
Old 03-04-2014, 08:02 PM   #39
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I really hope it's not assumptions like these that led to the mass appeal of banning R-comps in stock class.
This is why we can't have nice things.
The Following User Says Thank You to Sccabrz192 For This Useful Post:
TrqlessWonder (03-04-2014)
Old 03-05-2014, 09:05 AM   #40
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by Sccabrz192 View Post
An A6 won't "overheat and melt" when used on a track over significant duration. They will get hot and become "greasy" over time..
semantics
It is true they will degrade much faster,..
you say degrade and cord, i say melt, i appologize for not using the industry technical terms.
With all that said, A6's are very commonly used in club racing as a qualifying tire..
yes, a qualifying tire, not a lapping tire
i see no disagreement with anything that i've said. Unless "a hot and greasy" tire is a good thing? The question was "using the tire for a test and tune", which in my neck of the woods is another word for lapping days
using an A6 for lapping is stupid, you'd be better off smoking actual crack.
unless of course the OP meant drag racing? meh.
Old 03-05-2014, 09:21 AM   #41
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not sure if troll?
a (long overdue) move to street tires has no relationship to their use as a lapping tire.
the move to street tires allows a far greater amount of casual competitors to come out to have fun and actually be competetive. Being forced to bring a second set of wheels and tires for what is supposed to be a grassroots activity is not efficient.
those that want to be the best will still bring special, unused sets for their top times, but there are gonna be much less of those people.
A6's don't make YOU fast, they make the car fast.
if you want breakneck cornering speeds, just hit up the track, a nice, cambered bend at 180kph or so should russtle your jimmies nicely.
Old 03-05-2014, 09:47 AM   #42
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
semantics
The OP meant autocross, just as the OP stated. We have autocross style test and tunes locally.
Thrustin is offline   Reply With Quote
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
07 WRX wheels & 225/45 Dunlop ZII Stock autocross set up -max- Wheels and Tires 0 04-29-2013 04:26 AM
Completely stock BRZ / FR-S needed AMR Engine, Exhaust, Transmission 11 04-03-2013 10:01 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
