Old 03-04-2014, 12:25 PM   #1
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
If I use royal purple oil will it void warranty?
[ame="http://www.amazon.com/Royal-Purple-51020-API-Licensed-Performance/dp/B005SEK9IQ/ref=sr_1_1?ie=UTF8&qid=1393953800&sr=8-1&keywords=0w20+royal+purple"]Amazon.com: Royal Purple 51020 API-Licensed SAE 0W-20 High Performance Synthetic Motor Oil - 5 Quart Jug: Automotive[/ame]
that's the oil, will it void the cars warranty? its Royal Purple 51020 API-Licensed SAE 0W-20 High Performance Synthetic Motor Oil thanks for the help
brzadrian is offline   Reply With Quote
Old 03-04-2014, 12:33 PM   #2
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Maybe if you mix it with sugar.
Anthonytpt is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthonytpt For This Useful Post:
brzadrian (03-04-2014), SuperDave (03-14-2014)
Old 03-04-2014, 12:49 PM   #3
brzadrian
I'm Batman
brzadrian's Avatar
i will also be using the royal purple oil filter
Old 03-04-2014, 12:53 PM   #4
z3ro
Can someone make the search tab bigger?
z3ro is offline   Reply With Quote
The Following 5 Users Say Thank You to z3ro For This Useful Post:
Anthonytpt (03-04-2014), Creole (03-04-2014), suaveflooder (03-04-2014), SuperDave (03-14-2014), Tim_Asphalt_FRS (03-04-2014)
Old 03-04-2014, 12:55 PM   #5
Anthonytpt
Anthonytpt's Avatar
FT86Club should be like the Google homepage: a lone search bar.
Old 03-04-2014, 01:01 PM   #6
Malt
Drives: 2015 WRX
Why would you think using the specified weight and rating oil would void the warranty?
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Old 03-04-2014, 01:02 PM   #7
brzadrian
I'm Batman
brzadrian's Avatar
the reason I'm asking is because on the back of the container i read this "for vehicles no longer under warranty" so I figured I'd seek help on this forum... ive seen some people run this oil, but idk if they are still under warranty, thanks, sorry couldn't find the specific information I was looking for, so i created a thread.
Old 03-04-2014, 01:03 PM   #8
brzadrian
I'm Batman
brzadrian's Avatar
the wording in the back was making me doubt myself
Old 03-04-2014, 01:05 PM   #9
TONY_BRZ
Drives: 2015 BRZ
You're fine. Read it again because it's suggesting you use a different type of oil if the vehicle is not under warranty
TONY_BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to TONY_BRZ For This Useful Post:
Old 03-04-2014, 01:13 PM   #10
TM
TM's Avatar
Drives: DGM BRZ 6MT
The description says that the oil meets warranty requirements...
TM is offline   Reply With Quote
The Following 2 Users Say Thank You to TM For This Useful Post:
strat61caster (03-04-2014), SuperDave (03-14-2014)
Old 03-04-2014, 01:17 PM   #11
brzadrian
I'm Batman
brzadrian's Avatar
sorry guys i just get a lil anxiety when it comes to warranty and needed to be 100% on it
Old 03-04-2014, 01:19 PM   #12
brzadrian
I'm Batman
brzadrian's Avatar
and now I remember why I never asked for help in math class...
Old 03-04-2014, 01:25 PM   #13
Malt
Drives: 2015 WRX
A lot gets lost in translation in a text based form of communication. I was just confused as to why you thought your warrenty would be voided. There's nothing to worry about and you should be fine using that oil.
Old 03-04-2014, 01:59 PM   #14
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
And that is why I failed math
Carlitoz3 is offline   Reply With Quote
The Following User Says Thank You to Carlitoz3 For This Useful Post:
Any Issues with Royal Purple? akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 46 08-03-2015 04:06 PM
Royal Purple Max Boost Octane Booster brillo Engine, Exhaust, Transmission 2 02-28-2014 07:12 PM
FS: Royal Purple API-licensed SAE 0W-20 Synthetic Motor Oil Sportsguy83 Mechanical Maintenance and Tools 7 12-21-2012 08:10 PM
Royal Purple Oil - Possible GB (Vic Only) fuddbutter Australia Classifieds 0 11-14-2012 07:48 PM
Oil Change - Perhaps Royal Purple? RowTarEEE Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 11-01-2012 05:47 PM
