Old 01-05-2014, 05:52 PM   #29
puravida
Drives: 14 brz, 97 nsx, 85 land cruiser
just an update . . . i tried placing a adhesive foam below the accelerator assembly . . . some forum members had luck solving the rattle with felt. unfortunately it hasn't solved the problem . . . i'm thinking the "buzzing" is coming from somewhere else . . .
any suggestions?
much appreciated
puravida is offline   Reply With Quote
Old 01-06-2014, 07:07 PM   #30
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
I have this same buzzing sound over certain road surfaces. It sounds like a frequency buzzing that only occurs when the road surface causes it tho vibrate at the right frequency. I would love to hear someone come up with a pinpoint of the problem or fix that works.
JSMIL is offline   Reply With Quote
Old 01-06-2014, 08:06 PM   #31
BRZprime
Drives: 2013 Subaru BRZ
I think I have the same exact thing, but I started noticing that It usually happens on rough roads (i.e. any road in Cali) when I'm driving at high speeds AND when I depress the accelerator just an inch or so (barely enough to actually give it any gas). I'm thinking the felt trick will fix it, but I'm waiting to find some free time to take it to the dealership.
BRZprime is offline   Reply With Quote
Old 01-08-2014, 02:07 AM   #32
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
THIS! I just noticed a similar pattern today when going over bumps. On the lookout now to see if it's a trend.
the new guy is offline   Reply With Quote
Old 01-08-2014, 02:16 AM   #33
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Everyone having this issue: when it is happening, grasp the top of the gauge cluster that's right behind the steering wheel. Here's a picture for reference.
This buzzing was cause by this. I still have it happening, and I think I've concluded that it is the plastic of the cluster hood hitting the clear plastic of the actual gauge cluster. So I unscrewed the one screw, popped it out of there with all the clips, shoved a little foam in between and in the creases, then put it back together. So far, so good (knock on wood).
husker741 is offline   Reply With Quote
Old 01-12-2014, 05:09 AM   #34
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
did this fix the buzzing sounds ?
Where was your buzzing sound coming from ?
Seems like from the left hand driver side, around the HID leveling headlights controller
ucsmfu is offline   Reply With Quote
Old 01-13-2014, 02:24 PM   #35
the new guy
This noise irritates me more than crickets when I hear it, would you mind highlighting in the picture where you put the foam?
Old 01-13-2014, 03:51 PM   #36
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I think this will solve our buzzing sound. I don't think the sound is coming from the cluster
http://www.ft86club.com/forums/showp...5&postcount=39
Old 03-04-2014, 10:00 AM   #37
AJ
Drives: ’13 Asphalt FR-S
I have this same problem. I have applied raammat and ensolite under the gas pedal, I have foamed and applied raammat to about 300 other surfaces inside the dash including the guage cluster, and still no joy. I sure hope they figure this one out pretty soon. This issue is hard to ignore when driving the car.
AJ is offline   Reply With Quote
Old 03-04-2014, 10:51 AM   #38
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
I tried the felt gas pedal too to no avail. It seems like mine is coming from behind the steering wheel, I just haven't had a chance to take the console apart.
I also put friction tape all over and in every seam of the instrument cluster with no meaningful difference.
fatherfork is offline   Reply With Quote
Old 03-04-2014, 11:47 AM   #39
chandz05
chandz05's Avatar
Drives: CBS BRZ limited MT
Mine has started doing this too, at around about 25k miles. However, I know that my driver side "buzzing" is the speaker on the dash. I think it's very slightly loose, and pushing it down for a few seconds completely stops the sound. It's only happened once or twice for me though, so not really a problem. Dunno if this helps you guys...
chandz05 is offline   Reply With Quote
Old 03-04-2014, 12:05 PM   #40
AJ
Worth a try, I haven't messed with the speaker yet..
Old 03-04-2014, 12:10 PM   #41
fatherfork
Fears Hiccups
fatherfork's Avatar
I put friction tape all around that grille too, so that's not where mine is coming from. Let me know if you find it.
I was able to reproduce what I think is the buzzing by tapping on the steering wheel at a certain angle. I couldn't reliably make it happen, but I could get it sometimes. This is why I think mine is behind the steering wheel somewhere. So frustrating on the road.
Old 03-18-2014, 03:03 PM   #42
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
My buzzing noise came back today
Buzzing / Compressor Sound from Gas Tank Area Spd229 Issues | Warranty | Recalls / TSB 14 12-06-2013 10:17 PM
WTB BRZ driver side headlight zex Canada Classifieds 0 07-21-2013 05:19 PM
FS: New OEM Driver-side Headlight retrosmiths Southern California 0 06-26-2013 01:44 AM
Buzzing sound(like hairclipper), gas tank region, car park for 4 hrs solma Issues | Warranty | Recalls / TSB 6 03-20-2013 02:04 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
