Old 02-17-2014, 02:47 PM   #57
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, anyone interested doing this mod with LEDs will need these LEDs if you want the lights to act stock when not blinking, blink with blinkers when no lights are on, and alternate blink with current blinkers when lights are on. These are non-polarized LEDs, so they work just like normal incandescents, plugged in either direction, and can receive power flowing either way.
http://www.superbrightleds.com/morei...se-tower/1127/
They are just about as bright as your normal incandescents, but of course are instant on and off like all LEDs, and will last much longer than incandescents, and use less power.
Deathalo is offline   Reply With Quote
Old 03-04-2014, 12:00 AM   #58
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Originally Posted by Danklvr View Post
any time you use LED for blinkers, you will get hyper flash if you dont change your flasher relay due to the lower resistance of the LED bulbs.
what if you use led for the parking lights and halogen for the blinkers?
will you still get hyperflash?
subiestyle is offline   Reply With Quote
Old 03-04-2014, 12:37 AM   #59
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
anyone with led in the sidemarkers and stock bulbs in the blinkers want to chime in? this has been asked a couple times in this thread but hasnt been verified yet.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 03-04-2014, 12:44 AM   #60
Zen86
Run, Reach, Fly
Zen86's Avatar
Drives: Monogram Firestorm
I have that setup. It doesn't hyper flash for me but I have polarized led markers so the marker doesn't flash without my parking lights on. Ordering non-polarized ones, will let you know when they come in.
Edit: Got the non polarized LED side marker bulbs and there is no hyperflashing.
My setup is stock turn signal bulbs with LED side marker bulbs
Turn signal and side marker flashes at the same time when the parking/headlights is off
Turn signal and side marker alternates when the parking/headlight is on
Zen86 is offline   Reply With Quote
Old 03-04-2014, 01:45 AM   #61
subiestyle
subiestyle's Avatar
Maybe some more experienced modders can comment on my scenario. I want to have my side markers to turn on with parking and headlights on, and to constantly blink at the same rate as my normal blinkers at all times.
1. Use 2 wires to tap into the green and red wires on the turn signal.
2. Take those 2 wires and splice them onto the red or white wire leading to the side marker.
Now the side markers get the power from the turn signal parking light and then when the turn signal blink, they get the power for the blinkers.
The only question is when the car powers up the blinkers on the red wire, does it cut power on the green wire because that may interfere with my setup.
I don't see why this can't work?
Old 03-17-2014, 08:23 AM   #62
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Does anyone know if its possible to get new metal clips to hold in the side markers? Looks like one of mine fell out after I swapped out mine, and now the driver side marker pops out. If so, anyone know a part number?
milhouse is offline   Reply With Quote
Old 03-17-2014, 11:13 AM   #63
Zen86
Run, Reach, Fly
Zen86's Avatar
They don't sell the clips separately. You have to get the whole side marker housing. Or fabricate your own clips.
The Following User Says Thank You to Zen86 For This Useful Post:
milhouse (04-25-2014)
Old 04-08-2014, 01:51 AM   #64
boonFRS
Drives: 2013 Scion FRS whiteout
Got some switchbacks install in the turn signals and also got some led for the side. With the flasher relay install the led side doesn't hyper flash. The only downside is the turn signal is yellow while the sides are white. Will try some switchbacks next week.
[ame="https://www.youtube.com/watch?v=DGg6p2BpIoU"]Led side + turn signal - YouTube[/ame]
boonFRS is offline   Reply With Quote
The Following User Says Thank You to boonFRS For This Useful Post:
SkAsphalt (04-19-2014)
Old 04-08-2014, 01:58 AM   #65
Zen86
Run, Reach, Fly
Zen86's Avatar
Gonna get switchbacks soon. Let me know which ones you finally decide
Old 04-18-2014, 10:51 PM   #66
TofuAE86
Drives: NA runners
I did this mod with a switchback turn signal and changed the relay and a stock side marker, after doing this I noticed my clock and head unit also blinks when i signal, does anyone know the problem?
TofuAE86 is offline   Reply With Quote
Old 04-25-2014, 02:57 AM   #67
boonFRS
Not sure. You might have cross something something, I'm not too bright in the electrical field.
On the other hand, I did install some diode dynamics fog light kit and wired it to my parking lights instead of the headlights. I just tapped into the front turn signal. I was having problem with using the power wire from the original wire (might be because the gauge is so small and not enough to power the fog lights. So luckily when I did my side markers, I used a larger size wire (forgot the gauge size) and tapped my power wire there.. All and all I'm pretty happy now that the fogs come on with the parking lights instead of the headlights.
[ame="https://www.youtube.com/watch?v=3ppMBlHdAB4"]Frs fog parking light mod - YouTube[/ame]
TSC19 (04-27-2014)
Old 05-01-2014, 07:57 PM   #68
dvs1270
Drives: 86 shopper, future owner?
Another way to mod the stock parks to flash is to connect the negative wire from the park light to the positive wire on the front flasher with a single wire & tap.
Cut negative wire at the bulb connector, tape end going back to car, connect wire to cut negative bulb connector end, run it to the blinker, tap blinker positive.
Headlights off, they will flash together. Juice comes from blinker juice.
Headlights on, they will alternate. Side maker grounds out when blinker gets juice.
Parks will work like usual otherwise. Car doesn't give a shiggity.
dvs1270 is offline   Reply With Quote
The Following User Says Thank You to dvs1270 For This Useful Post:
SkAsphalt (07-22-2015)
Old 05-24-2014, 06:09 PM   #69
bfsnail
bfsnail's Avatar
I just did this and it works awesome. Unfortunately, now I want brighter side markers!
bfsnail is offline   Reply With Quote
Old 07-15-2014, 10:31 AM   #70
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by zoomzoomers View Post
You're telling me! From the profile other drivers can't see that we've got the blinkers on. On top fo that our blinkers aren't in the corners. One savings grace is that in the dark the blinkers are bright, but that doesn't help during the day.
I was highly disappointed when I bought the car that they didn't blink (not enough to keep me buying her though). When I test drove the car, and did my walk around and that was the one thing that stuck out at me was that people would only be able to see the turn signal head on.
I was really shocked with the turn signals being as low as they are, without being installed in the headlight assembly, that the USDOT would find that acceptable and not mandate the markers blink.
I do have to ask though, what the hell is the purpose of the side markers if they don't blink? Anyone?
Frishkorn is offline   Reply With Quote
The Following User Says Thank You to Frishkorn For This Useful Post:
zoomzoomers (07-29-2014)
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 09:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 03:41 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:52 PM
