Old 01-27-2014, 11:16 AM   #43
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Originally Posted by vincent201089 View Post
Doesn't work with switch back led
-parking light on, only side marker on, white led off
-headlight on, same
-turn signal on, side marker flashes, amber led flashes as well but weird strobe
put my stock bulb on and everything works perfectly
take stock one out because I like the switchback.
any time you use LED for blinkers, you will get hyper flash if you dont change your flasher relay due to the lower resistance of the LED bulbs.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 01-27-2014, 12:39 PM   #44
RFB
RFB's Avatar
Drives: FRS
Originally Posted by Danklvr View Post
there is a much easier way to perform this mod, i just did it 5 minutes ago.
No need to cut both wires from the side marker - black/white right side, black/red left side.
also no need to cut the red (blinker) wire and the green (parking light power) wires from the parking lights.
here is what i did to achieve the same effect, took 5 min per side..
using the DIY in this post locate the red (blinker signal) wires coming from your parking lights and splice a jumper wire onto it, either by splice connection, solder, tape, wire nuts, whatever your preffered method is... do not cut the green wire or splice anything to it, the green wires are your constant power wires for the parking lights.
next, locate the 2 wires coming from your side markers. i chose to get my wires before the harness going into the sidemarkers, whereas the OP chose to get them inside the sidemarkers themselves, do it my way, its better and easier to return to stock...for your referance - right side will be black/white, left side will be black/red.
The black wire on each side is the only wire that needs to be cut, NOT both wires going to the side marker. Again, for referance, the white wire on the right side, red wire on the left side is your constant power to the sidemarker, no need to cut or splice this one, leave it be. Yet i digress.. locate your black wires on each side of the sidemarkers, and cut the black wires. Take your jumper wire you spliced to the red blinker signal wire from the parking lights, and connect them to the sidemarker side of the black wires you just cut. tape off the remaining black wire ends that are leading to the engine side. if you ever want to reverse this mod, just splice the 2 ends of the black wires back together, and remove the splice connection to your red blinker wires.
test and enjoy if something doesnt work, you either didnt make a good splice connection, or you ran your jumper to the end of the black wires that do not lead to the sidemarkers...
no hyper flash, no warning lights, blown fuses, just like the OP method above this flashes and looks stock, the way the fr-s/brz should have come.
1. Parking lights on, the side marker will stay on and alternate with the front blinkers.
2. Headlights on, same as #1.
3. All lights off, the side marker will not be on but will blink in sync with the front blinkers.
Will this work the same way with front switchbacks and the correct non hyperflash relay under the dash ?
CERBERUS
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Blackrsx (04-08-2014)
Old 01-27-2014, 12:43 PM   #45
vincent201089
vincent201089's Avatar
Drives: frs
the marker flashes perfectly but the front turn signal doesn't (white led isn't on as well when headlight is on). I already had flasher relay when I changed my bulbs to led.
http://www.ft86club.com/forums/showthread.php?t=41027
this guy has his led marker and switch back turn signal but he had to make a new circuit for the side marker.
vincent201089 is offline   Reply With Quote
The Following User Says Thank You to vincent201089 For This Useful Post:
Papi (09-15-2015)
Old 01-27-2014, 12:55 PM   #46
Danklvr
Danklvr's Avatar
CERBERUS
i dont use LED bulbs or switchbacks for my blinkers, so i cannot say.
Old 01-27-2014, 09:04 PM   #47
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, did it your way last night to my BRZ while replacing my markers with Clear JDMs with Amber LEDs. Result: Markers blink in sync with front/rear blinkers... but do not ever stay lit, they are only on when blinking even when headlights are on, and, in fact, when the parking light is switched on the stock they don't do anything, no blinking and no constant light. So, essentially this mod turns the side markers into just blinkers for the auto and full on positions (and probably off but didn't test), but do nothing in the parking light position.
This is for the Limited BRZ mind you and while I don't really care about the side markers being on (I much prefer them as blinkers), I wonder why it turned out this way.
Would keeping the original black wire to side markers connected allow them to stay on? I'm guessing it has to be something to do with a broken circuit and the fact that the BRZ front blinkers only blink and are not on with parking lights?
Deathalo is offline   Reply With Quote
Old 01-27-2014, 09:25 PM   #48
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
Sounds like I'll encounter the same issue with my limited. Too many drinks into the evening to figure it out at the moment but perhaps we need a setup with some diodes for BRZs.
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Old 01-27-2014, 09:38 PM   #49
Danklvr
Danklvr's Avatar
For the BRZ/ Limited, you'll have to also cut the remaining wire coming from your sidemarkers, and run a second jumper from the "parking light constant", that way they will function as blinkers and markers. The BRZ limited wiring would be slightly different from the FR-s, but just trace down which wire is the "blink" wire, and which is the "parking light constant" from the BRZ headlamp&blinker assy.
The BRZ limited version of this mod would be similar to the OP's guide. Basically Identify your parking light constant power wire & your blinker "blink" power wire, and connect them to your 2 wires coming from the sidemarkers. I'd recommend using a multimeter or a test light, to verify the wires if you have a BRZ or BRZ Limited. The same would hold true if you have a 10 or monogram, the standard FR-S wiring is what the OP's Guide and my revision are based on.
Also i should note -and will amend my original post - I haven't tested this with LED bulbs, only incandescent.
Old 01-27-2014, 10:28 PM   #50
Deathalo
In the BRZ Limited I think that green parking light wire power the boomerang LED lights around the HIDs, because they come on when you put the parking lights on. I've already done the Boomerang DRL mod, so I guess I just need to splice on an extra wire before the diode. I'll test before soldering and post results this weekend.
Old 01-28-2014, 02:34 AM   #51
Danklvr
Danklvr's Avatar
if it works, post feedback, would be great to add the BRZ specifics here as well
Old 01-28-2014, 10:28 AM   #52
Deathalo
Might try it after work today just to wrap things up, I wish I hadn't painted on liquid tape over my DRL connection already, I could've just soldered onto what I already did... time to bring out the razor blade and cut some of it off I guess
Old 01-28-2014, 09:42 PM   #53
Deathalo
Ok, so I made the modification. I cut the other wire on the side markers (red on drivers white on the other) and ran a wire from there to the green wire going my Boomerang LED lights (which on the BRZ, act as the front parking lights). I also have the Boomerangs setup as Daytime Running Lights, so I have a wire running from the lower LEDs and a Diode hooked into the green wire. All I had to do was make the connection to the side markers BEFORE the diode, on the harness side, not the headlight side. At first, it didn't work and I was puzzled, but then I flipped my LEDs in the side markers around and the markers came on with the headlights and alternated, BUT there was still a problem, the blinkers wouldn't come on at all when the parking lights were off, meaning they wouldn't come on with the stock set to 'off' or 'auto' during daylight. So, I tried putting the regular bulbs back in and, sure enough, everything worked properly. So, it seems the amber LEDs I have an issue, I'm guessing it's some sort of polarity issue, can someone shed some light on this and are there any LEDs that may work like the standard bulbs, I'm sure LEDs that work flipped in either way will do nicely, does anyone know of any that will fit in our 168 socket?
Just for reference for any other BRZ owners:
You need a wire going from the red blinker wire to the black wire on your markers, and a wire going from the green wire hooked to your headlights (powering the boomerang) to the white/red power wire on your side markers. If you do or have done the DRL mod for your boomerangs make sure the diode is in between the splice to the marker and your headlight.
The Following User Says Thank You to Deathalo For This Useful Post:
codesplice (01-18-2015)
Old 01-29-2014, 12:21 AM   #54
Vis101
Vis101's Avatar
Did you try flipping the LEDs?
Old 01-29-2014, 12:22 AM   #55
Vis101
Vis101's Avatar
Disregard last comment.
Old 01-29-2014, 10:37 AM   #56
Deathalo
Lol, I did find these: http://www.superbrightleds.com/morei...edge-base/199/
It says they are not polarity sensitive, so I suppose they would work like incandescents, but I'm just worried that they aren't bright enough, they say they only output 30 lumens, which seems fairly lower than your typical 5 LED marker, thoughts?
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 09:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 03:41 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:52 PM
