Old 08-21-2012, 01:03 AM   #1
boonFRS
Drives: 2013 Scion FRS whiteout
DIY side marker blinkers
Ok, finally took the time to do this tonight. This is my first write-up so bare with me here. First you'll need Electrical tape, automotive wires, screw end caps, wire stripper, sharpie, and patience.
DO THIS AT YOUR OWN RISK
First off, you'll need access to your side markers and front blinkers. you can do that by visiting this thread here
http://www.ft86club.com/forums/showthread.php?t=11276
Once you've gained access to the side markers, you'll need to do this
Unplug the side marker bracket from the car, you should end up with this piece
Now cut 2 wires about 1 feet long and connect it to the two that are on the bulb end
Locate your blinkers. Once you disconnect the plug, cut the GREEN and RED wires.
Then connect the automotive wires from the side marker to the blinker unit.
Plug the blinker harness back in and test your blinker before put everything back together
Ziptie all the loose wires together including the original harness that was connected to the side markers
If you look up from the blinkers, you'll see a hole that you can zip tie the wires to
Put everything back and viola
[ame="http://www.youtube.com/watch?v=ZwBIalGl_64&list=HL1345525464&feature=mh_l olz"]SCION FRS SIDE MARKER BLINKER - YouTube[/ame]
Hope this helps. Enjoy.
Last edited by boonFRS; 01-20-2015 at 04:00 PM. Reason: don't know how to embed video sorry. nvmind
boonFRS is offline   Reply With Quote
Old 08-21-2012, 01:08 AM   #2
ayau
Drives: Some rust bucket
did you notice the blink rate was faster/slower?
Old 08-21-2012, 01:15 AM   #3
boonFRS
I didn't notice any difference. I thought it was going to be JDM TYTE fast but no, which was a relief IMO.
Old 08-21-2012, 01:32 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Will be doing this, thank you . I love how they blink at intervals and not together
mashal is offline   Reply With Quote
Old 08-22-2012, 03:17 AM   #5
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 08-24-2012, 02:26 PM   #6
rawbz
Drives: 2013 Subaru BRZ
great write up! I think I'll be doing this as well, I was sort of disappointed with no side marker on the side view mirrors but this should definitely help
rawbz is offline   Reply With Quote
Old 08-24-2012, 04:49 PM   #7
xcelir8brz
Drives: 2013 BRZ Limited
subscribed
xcelir8brz is offline   Reply With Quote
Old 08-24-2012, 06:06 PM   #8
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
You're telling me! From the profile other drivers can't see that we've got the blinkers on. On top fo that our blinkers aren't in the corners. One savings grace is that in the dark the blinkers are bright, but that doesn't help during the day.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-14-2012, 02:14 AM   #9
Goodguy889
Goodguy889's Avatar
Drives: Hyundai genesis 2.0t
So on the side marker, did you take off tape to the plug and plug it back in or leave it unplugged? Same goes for the other end of wires that you cut opposite of bulb, did you leave those taped or did you connect them with bulb and automotive wire?
Goodguy889 is offline   Reply With Quote
Old 09-17-2012, 05:53 PM   #10
d1ck
Drives: Black 2013 FRS
Why not solder / heatshrink the wires?
d1ck is offline   Reply With Quote
Old 09-18-2012, 02:49 AM   #11
boonFRS
I don't really understand what you really mean?
Didn't have a solder iron at hand and didn't want to other with heatshrink. That wanted to do a quick and ez mod.
Old 09-18-2012, 05:46 PM   #12
Jason952
nice change but the wire caps....will corrode
Jason952 is offline   Reply With Quote
Old 09-19-2012, 10:23 AM   #13
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I think it would be cool to use the side marker as the turn signal and convert the turn signal housings into fog lights somehow.
kmbkk is offline   Reply With Quote
Old 09-19-2012, 10:24 AM   #14
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Great writeup though!
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 33 07-13-2026 10:18 PM
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 09:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 06:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 10:52 PM
