go_a_way1
Old 03-03-2014, 04:45 PM   #2171
ft86me
ft86me's Avatar
Drives: 2013 FRS
Will this fit? (width, offset and tire size Qs)
Nevermind. My bad
ft86me is offline   Reply With Quote
Old 03-03-2014, 06:23 PM   #2172
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Someone help me decide!
255/35/18 Federal 595 vs 265/35/18 Achilles ATR Sport.
Will be going on 18x9.5. Not too familiar with either, but both fit my budget and are in stock. I've read a couple reviews of both, and it seems that Federal has a longer lasting reputation. Ive seen people mount 245/40, but they seem a bit tall.
Suggestions?
Joe-G is offline   Reply With Quote
Old 03-03-2014, 06:54 PM   #2173
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by IAmNotTheDriftKing View Post
Alright, so I have decided on a 17x9 wheel with a 42mm offset. I was wondering on stock suspension how much camber can you add before rubbing. I was hoping to get -1.5 degrees.
Probably -1.0 or up to -1.5 max, hard to know for sure.
On stock springs, how do you plan on getting that much camber? Crash bolts will only get you not quite -1.0.
Btw, the twins don't need a ton of camber (for optimum handling).
Slick is offline   Reply With Quote
Old 03-03-2014, 06:57 PM   #2174
Slick
Slick's Avatar
Originally Posted by terenshu View Post
Hey guys! 18x8.5 with 245/35 tires 1.5 inch drop, Safest offset? Just would like to know.
Sent from my Diamond V7 using Tapatalk
Old 03-03-2014, 07:00 PM   #2175
Slick
Slick's Avatar
Stick with 35 series tire for anything 245 or wider (245-265)
255/35R18 is a great size for 9.5" rim.
Never heard of Achilles.
Suggestions?
Old 03-03-2014, 07:49 PM   #2176
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
17x9 +35
245/40/17 or 255/40/17 I am looking at.
Lowered on KW V3's. Looking for a track setup.
Outlawstar98 is offline   Reply With Quote
Old 03-03-2014, 08:17 PM   #2177
Slick
Slick's Avatar
Perfect size track wheel and offset.
Tire size will be fine with either. 245's are probably what most guys run for track, but 255's are the ideal tire for that rim width. When I run track wheels, I'll likely run the 255 size. You won't rub with 255 especially since you're on coil-overs (you'd be be fine on coils too as long as there's no excessive camber.
Currently on 18's with 245s but enough room for 255 tires.
Originally Posted by Outlawstar98 View Post
17x9 +35
Old 03-03-2014, 10:00 PM   #2178
Outlawstar98
SLOW BRZ
Yeah getting track wheels, Im on 245/35/18's right now. Just trying to get a good setup for track
Old 03-11-2014, 07:52 PM   #2179
nunonuna
nunonuna's Avatar
Will 17x8 32mm with stock suspension & stock size tire fit?
Sent from my Galaxy Nexus using Tapatalk
nunonuna is offline   Reply With Quote
Old 03-11-2014, 11:33 PM   #2180
Slick
Slick's Avatar
Sure will, no issues.
Minor stretch for those tires, but nothing crazy.
Old 03-12-2014, 10:06 AM   #2181
MObrz5
Drives: 2014 Satin White Pearl BRZ
Im going to be ordering some ssr sp1s within the next month or so and I'll be running 18x9.5 squared. I'll have my ST coilovers by that time and plan on doing a 1.25"-1.5" drop. 1st question is what is the ideal offset to go with for more of a flush look. Second will I need front camber plates and rear LCAs? Oh also I'm planning on running 245/35r/18 Michelin PSS because I've read the tires won't be stretched very much at all! Thank you in advanced!
MObrz5 is offline   Reply With Quote
Old 03-12-2014, 01:22 PM   #2182
Slick
Slick's Avatar
No issues with fitting this combo since you have coilovers. I think the right offset is about +40 for a flush look. You could probably go between +35 to +45 since you have coilovers.
Here a few threads for you to check out and decide on the right offset:
(wheel directory thread)
http://www.ft86club.com/forums/showthread.php?t=7535
And also here:
(aggressive wheels thread)
http://www.ft86club.com/forums/showthread.php?t=25171
but be warned that some setups are pretty crazy (-10 camber) with the hella-flush and standed crowd.
You shouldn't "need" LCA's or tophats, you'll get around -1.8F/-2.0R camber just with the lowering. You can get a bit more (.5) with front crash bolts ($7 each x 2).
245's will be stretched more than you think, ideal size for a 9.5" wheel is a 265 or 275 wide tire. My 245's are already stretched a bit on my 18x9" wheels. Depends what you want for looks also. Michelin recommends a 8.5" wheel size for their 245/35R18 Super Sports.
The Following User Says Thank You to Slick For This Useful Post:
MObrz5 (03-12-2014)
Old 03-12-2014, 01:25 PM   #2183
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I'd like to get Gram Lights 57DR 18x8.5 +38 (Square) and I'd probably run a Michelin PSS 265/35/18 in the back and probably 235 or 245/35/8 in the front, will there be any rubbing on stock suspension, and will there be a lot of poke? The streets are too shitty around here to lower.. Thanks!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-12-2014, 01:40 PM   #2184
Slick
Slick's Avatar
Wheel fitment is fine although you may consider just running 245's all around. The 265 will clear but not an ideal tire size for a 8.5" wheel. (see my post above yours)
Shouldn't poke in the front, pretty flush with no rubbing.
Here's another guy running this size and offset, although he's lowered:
http://www.ft86club.com/forums/showthread.php?t=48112
Brody602 (03-12-2014)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
