Old 03-03-2014, 06:55 AM   #43
Poodles
Drives: 2015 Series.Blue
I disagree.
Brake dynos measure torque and power is calculated.
Inertia dynos measure time and power is calculated.
Define real power gain. You drive onto a dyno. Get a reading. Go away and do some mods. Come back and do another dyno run (on the same dyno). If the increase is 10 power units can you tell me if I have increased the "real" power or the pretend power?
It's pretend because theoretically in a drag race with a car without said mods you wouldn't be faster (MAYBE be faster shifting, and that's a big maybe)
Road course it's a different ballgame because of the need to rev match and removing rotating mass helps that. You might be "faster" simple because of that.
Old 03-03-2014, 06:55 AM   #44
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Poodles View Post
Hence why inertia dynos have their issue One could also use lightweight wheels to get the same effect, or remove the rear rotors (I don't recommend it, but I remember this being tested somewhere).
As all power ratings are rated essentially on torque and horsepower is calculated from RPM, there's no "real" power gain.
Maybe so (and most everyone that makes them is going to say they're just fine as they're selling it), but it would be much cheaper for an OEM to NOT use a dampened pulley if there really wasn't an issue. This is much like the 1-piece driveshaft vs 2-piece driveshaft (read up on driveshaft critical speeds). It's not a NVH issue...
Regardless, it's a hell of a lot of money to spend on a part that's not making power or looking pretty...
Threads are there with quoted emails from Subaru themselves that the pulleys being dampened/non dampened makes no diff in regards to (worry). So not just from vendors as you state.
In regards to lighter driveshafts. I've done this and for "feel" one piece on this car is a lot nicer feeling, no clunkyness feel and yes a feel of being more peppy. Much more on a dyno? Don't know don't care either. I will get a one piece again soon and in cf.
Old 03-03-2014, 07:22 AM   #45
Poodles
Haven't seen anything from Subaru themselves...
1-piece driveshaft is only really an issue at high speeds (then again, having a driveshaft failure at high speeds could be...bad). It's a pretty easy thing to calculate (tons of calculators online for it), but I've seen what failures do on Supras (which run a 3.73 or 3.93 final drive usually compared to this car's IIRC 4.10). Stock power wouldn't be an issue as I don't think you'd get going fast enough, but if you're super/turbocharged it could be an issue to watch out for.
Old 03-03-2014, 09:19 AM   #46
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
What I'm taking good away from this is that Headers is the logical next step. Thanks all!
Sent from my SGH-I317M using Tapatalk
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
raven1231 (03-03-2014)
Old 03-03-2014, 09:27 AM   #47
raven1231
ud
As you should bud!
Old 03-03-2014, 09:48 AM   #48
Malt
Drives: 2015 WRX
Headers AND a tune. They should be done together.
Malt is offline   Reply With Quote
Old 03-03-2014, 09:54 AM   #49
1Cor10:23
1Cor10:23's Avatar
Yup, already got OFT. Likely looking into OFH
Malt (03-03-2014)
Old 03-03-2014, 09:57 AM   #50
raven1231
Good choice! Great products with even better support!
Old 03-03-2014, 10:26 AM   #51
stugray
Drives: 2013 GBS BRZ Limited
Best advice I can give:
Do the opposite of whatever NYCsubaruBRZ says
The Following 5 Users Say Thank You to stugray For This Useful Post:
Boofneenee (03-03-2014), mwjcyber (03-05-2014), mxsled (03-03-2014), raven1231 (03-03-2014), Victor Draken (03-03-2014)
Old 03-03-2014, 04:00 PM   #52
tennisfreak
Drives: 2018 BMW M240i
Regardless of what gives the best gains I say sure do the pulleys.
A 3 pulley set is less than $150, takes 10 minutes to install, and can be done in your garage with no jack stands or power tools.
Sure it is not a game changer for the car but you will feel a difference in the responsiveness.
Headers and exhaust are great if you have the money. A exhaust with headers is going to cost you $2-3K and that is if you install it yourself. Then you need jack stands and ample time to do it.
I have already done the catback myself and will eventually get around to doing the headers and down/front pipe. Just need to get ready to spend $1k+ more on my car to do it.
Old 03-03-2014, 07:30 PM   #53
jc1993
Drives: 2013 all stock frs
You'd suggest an Intake then pulleys before a header?!
Most intakes are absolute crap and pulleys and very little. Headers and a tune should be the very first mod for anyone looking for power gains. Both a header and tune can be had for around the price of a decent CBE with shiv's OFT/OFH combo.
bro do u know if that will fix the problem wit cel? i mean oft would it di it or would i still need a tune
jc1993 is offline   Reply With Quote
Old 03-03-2014, 07:33 PM   #54
Malt
Drives: 2015 WRX
The OFT (open flash tablet) is a device used to flash tunes to the ECU. Shiv provides off the shelf tunes free of charge and yes it will fix the CEL from running a catless header.
The Following User Says Thank You to Malt For This Useful Post:
jc1993 (03-03-2014)
Old 03-03-2014, 07:48 PM   #55
jc1993
thank you sir!!!
Old 03-03-2014, 07:53 PM   #56
jc1993
also i live in tthe worst state possible for emission(cali) when the time comes to smog my frs would i be able to flash it by to stock ? of course with the oem headers bolted back on, any issues i should know about..
Done modding until its lowered...anyone else in the same boat? BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-10-2013 05:03 PM
Modding stock muffler Ghost 86 Engine, Exhaust, Transmission 6 07-15-2013 05:11 AM
Modding your car and the law GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 50 06-02-2013 02:57 AM
EU to Ban Modding frosty86 Scion FR-S / Toyota 86 GT86 General Forum 29 11-04-2012 01:56 AM
Not modding - wheels and suspension available Z86 AUSTRALIA 0 10-08-2012 10:48 PM
