Old 01-13-2014, 11:46 PM   #155
Malt
Drives: 2015 WRX
This question has been answered at least half a dozen times over the past three months including a formal response from Subaru. The pulleys are just pulleys, not harmonic dampeners.
Malt is offline   Reply With Quote
Old 01-13-2014, 11:47 PM   #156
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Are you going to offer the red anodized S2 kit again?
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 01-14-2014, 07:04 AM   #157
Raceseng
Raceseng's Avatar
Yes, it is out of stock at the moment. We are doing another pulley production run.
Jarrett Seng
Raceseng | Owner
610.336.0206
Raceseng is offline   Reply With Quote
The Following User Says Thank You to Raceseng For This Useful Post:
*LongFella (01-21-2014)
Old 01-14-2014, 01:38 PM   #158
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
By Chance are you going to make individual pulleys available?
Kuri is offline   Reply With Quote
Old 01-14-2014, 01:41 PM   #159
Raceseng
Raceseng's Avatar
Hey Kuri
Yes I can... Give me a little time to get them put up. I'm in the process of revamping this site navigation.
Kuri (01-14-2014)
Old 01-14-2014, 09:25 PM   #160
xsuperbeex
Drives: Toyota Galaxy Blue Silica 86
Loving my blue ones... haven installed it yet though... its too beautiful to put it on the car... lol
xsuperbeex is offline   Reply With Quote
Old 03-02-2014, 10:33 AM   #161
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Any DIY videos available for a complete pulley swap? Took a look around, nothing conclusive.
Jarrett, would you recommend this as a DIY? I see a few people taking the install to shops in the thread.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 03-02-2014, 10:42 AM   #162
Malt
Drives: 2015 WRX
Thanks!
http://www.ft86club.com/forums/showthread.php?t=26386
http://www.ft86club.com/forums/showthread.php?t=12583
The crank pully is the only one that sounds like you need to seriously pay attention to. The other pulleys are pretty straight forward minus the alternator pulley, which sounds like a pain in the ass to get the bolt off.
The directions that came with my cascams and the rear shock tops were pretty good. Jarrett has personally answered all my questions when I've called him several times. If you were going to do puleys, there is no other company than raceseng I'd recommend. The customer support was outstanding.
The Following User Says Thank You to Malt For This Useful Post:
Raceseng (03-02-2014)
Old 03-02-2014, 10:50 AM   #163
Raceseng
Raceseng's Avatar
Thanks!
This can be done as a DIY. The hardest part is getting the crank pulley bolt to loosen. It requires a breaker bar and some effort. The other pulleys are simply bolt off and bolt new pulley on.
Email me jarrett (@) raceseng.com and I can email you the instructions to see if it's something you want to tackle.
Thanks!
Jarrett Seng
Raceseng | Owner
610.336.0206
1Cor10:23 (03-02-2014)
Old 03-02-2014, 10:50 AM   #164
xwd
Yeah the instructions are basically what you would find in the DIYs posted. I just did the install last week. The crank pulley is a PITA to get loose, and just make sure when you pull it off you put your finger in to keep the sleeve from pulling out with the pulley.
The water pump pulley if you have the belt on you can get them loose very easily, just keep the car in 6th gear with the ebrake on.
Alternator pulley I used an electric impact wrench to get off so I can't help you there but if you have a strap wrench you can probably hold it in place to get it off or again if the belt is on it might have enough tension to keep it in place since it's not that tight.
The Following 2 Users Say Thank You to xwd For This Useful Post:
1Cor10:23 (03-02-2014), Raceseng (03-02-2014)
Old 03-07-2014, 09:11 AM   #165
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
I've done a few searches to no avail. You know of any thread with that response from Subaru? thx!
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 03-07-2014, 10:06 AM   #166
Malt
Drives: 2015 WRX
http://www.ft86club.com/forums/showp...78&postcount=9
red_comet (03-07-2014)
Old 03-07-2014, 10:21 AM   #167
red_comet
Severed Member
red_comet's Avatar
Ironic because I read and thanked that post a long while ago! OMG I'm stupid
13 FRS doriftoooo!
DON'T PANIC
Old 03-29-2014, 07:46 PM   #168
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I need some help.
Had a hard time taking off crank pulley, so started searching on the forums for other alternative. Read it would be best to take off the serpentine belt first. Eventually got it off, but now I'm having a hard time loosening the alternator pulley. I put the belt back on, but the the alternator screw moves as I try to loosenit.
Any advice?
Thanks.
Carlitoz3 is offline   Reply With Quote
engine pulleys, raceseng
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 10:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
