Old 02-26-2014, 10:20 AM   #15
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I've done it before and as mentioned fluid is a must. I boiled mine, the pads held up as long as you're easy on them.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-26-2014, 12:10 PM   #16
CSG Mike
CSG Mike's Avatar
Originally Posted by Bg8780 View Post
@CSG Mike , what pads would you recommend for a DD but can take the abuse on occasional track days? I don't have the cash for a BBK so I'll have to settle for beefier pads and high temp fluid. I have 25k on the car already so when I do the brakes I plan on putting better rotors and pads instead of OEM replacements from the dealer.
Are you comfortable swapping pads on your own? If so, I'd recommend you use a race pad for the occasional track day, and then swap back to a street pad. You can buy pads that are compatible in terms of bedding.
If you can deal with increased dusting and the possibility of noise, then you can start with a hybrid pad or a race pad, and leave them on your car full time.
I leave Project Mu race pads on my car full time.
Swapping options:
Carbotech 1521 (street) / Carbotech XP10/12 (race)
Project Mu NS400 (street) / Project Mu Club Racer (race)
Winmax W1/W2 (street) / Winmax W5/6 (race)
Compromise options:
Carbotech AX6/XP8
Project Mu HC+800
Winmax W3/4
Bg8780 (02-26-2014)
Old 02-26-2014, 12:59 PM   #17
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Swapping options:
Compromise options:
Carbotech AX6/XP8
Project Mu HC+800
Winmax W3/4
Thanks! I'll probably end up going with a compromise. The car will see much more street use than track use. I'll only track the car as much as I can afford it. I don't have access to tools to swap pads that much so I'd be happier with a full time solution. I'll look into those three compromise options.
Thanks a lot for the help!
Bg8780 is offline   Reply With Quote
Old 02-28-2014, 08:33 PM   #18
DR 86
DR 86's Avatar
That's what you think until you hear the SQUEEEEEEEEEAAAL. Even with a tame pad like Carbotech XP8, squeals like a stuck pig. If you're going to track, do yourself a favour and buy a torque wrench to check that your lug nuts are torqued down to spec. Once you have that, all you need is one wrench to take off two bolts to remove the caliper and swap the pads.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
The Following User Says Thank You to DR 86 For This Useful Post:
Bg8780 (03-01-2014)
PIR track day stock review FRSfan111 Tracking / Autocross / HPDE / Drifting 1 08-11-2013 02:14 AM
good track tyres for the track? stock rims Rejor11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-22-2013 12:35 AM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
Any stock FRS/BRZ looking to get some track time in? DNAPoPo Southern California 0 03-21-2013 03:18 PM
Going to track with stock setup good or bad idea? evasquez7 BRZ First-Gen (2012+) — General Topics 11 08-21-2012 02:33 PM
