Old 02-25-2014, 06:19 PM   #15
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
@NoFear99 any tips on the installation? did you use the factory mounting points and 3M tape?
I'm looking to get the FRP but just want to make sure i install it securely as possible. No drilling is a big plus but i don't mind doing so.
JonAvalon is offline   Reply With Quote
The Following User Says Thank You to JonAvalon For This Useful Post:
NoFear99 (02-25-2014)
Old 02-25-2014, 09:20 PM   #16
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
From what I remember I think some holes need to be drill and some of them dont because they match with already existing holes from the factory.
Very easy to install.
I also used some 3M tape for a better straight flush fit to the OEM front lower bumper.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
The Following User Says Thank You to NoFear99 For This Useful Post:
JonAvalon (02-25-2014)
Old 02-25-2014, 09:56 PM   #17
NoFear99
NoFear99's Avatar
Some more pictures... If summer can be back again...
The Following 2 Users Say Thank You to NoFear99 For This Useful Post:
JonAvalon (02-26-2014), Nsot (03-01-2014)
Old 02-25-2014, 10:13 PM   #18
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looks great overall with the spats.
Old 02-26-2014, 04:22 AM   #19
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
what side skirts are those?
914_WHITE_FRS is offline   Reply With Quote
Old 02-26-2014, 07:41 AM   #20
NoFear99
NoFear99's Avatar
Chargespeed style replica side skirt sold by Jon Motoring.
They come in black plastic. I wrapped them into a carbon fiber vinyl.
Old 02-28-2014, 02:53 AM   #21
Vic
63 Auto Body
Vic's Avatar
Drives: 2013 SCION FR-S WHITEOUT
What are the sides of the front lip being held by? I just got mine and the sides do not come predrilled, so did you drill it or did you use tape?
Vic is offline   Reply With Quote
Old 03-01-2014, 08:44 AM   #22
NoFear99
NoFear99's Avatar
Take a look closely at your front lip.
There is a place especially marked to mount a 3M tape everywhere.
Vic (03-02-2014)
Old 03-01-2014, 12:18 PM   #23
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Originally Posted by indesign View Post
jon motoring sells a replica. i think the only vendor for legit downforce aero parts is evasive motorsports.
Jon Motoring only sells one for the BRZ I think. The one for the FRS is nothing like this on, sadly. I want one so bad but I want the cheapest on possible due to horrible roads here.
boooooooooooooooooost
Ammonia is offline   Reply With Quote
Old 03-02-2014, 03:18 AM   #24
Vic
63 Auto Body
Vic's Avatar
There are grooves for the tape, but im pretty skeptical about if 3M's VHB tape will hold up against really cold winters or high speeds.
I was just thinking of drilling a 1/2" hole to match up with the ones on the corners of the bumper then using a nut, bolt, and washer to hold everything in place.
Old 03-02-2014, 08:41 AM   #25
NoFear99
NoFear99's Avatar
At first I used the standard 3M tape but it wasnt strong enough. It doesnt make it.
I had to reinstall the lip a second time but this time I used something like this with an adhesive surface twice large.
http://www.ebay.com/itm/3M-Tape-30mm...ht_4066wt_1239
It is now solid like a rock. No need to drill others holes for extra nuts and bolts.
But you can always do it if you want to. It is up to you.
ultra (03-02-2014), Vic (03-02-2014)
Password JDM 3 Piece front splitter/Version Select CF Side skirt Paint Matched BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 15 08-10-2013 07:08 PM
FS: Version Select TRD Front Lip Kit gvan1998 Exterior Parts (Aero, Lighting, Etc.) 13 06-16-2013 10:33 AM
FS: Version Select TRD Front lip painted gvan1998 Exterior Parts (Aero, Lighting, Etc.) 7 06-04-2013 10:56 AM
FS: Version Select TRD Front lip Painted gvan1998 Mid-Atlantic 2 06-02-2013 11:37 PM
FS: Version Select TRD Front lip painted gvan1998 NY / NJ / CT / PA 4 06-02-2013 11:32 PM
