#15 |
SCBYD0
Drives: 18 BRZ (WRB)
@NoFear99 any tips on the installation? did you use the factory mounting points and 3M tape?
I'm looking to get the FRP but just want to make sure i install it securely as possible. No drilling is a big plus but i don't mind doing so. |
| The Following User Says Thank You to JonAvalon For This Useful Post: | NoFear99 (02-25-2014) |
#16 |
Drives: FR-S Firestorm
From what I remember I think some holes need to be drill and some of them dont because they match with already existing holes from the factory.
Very easy to install. I also used some 3M tape for a better straight flush fit to the OEM front lower bumper.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
| The Following User Says Thank You to NoFear99 For This Useful Post: | JonAvalon (02-25-2014) |
#17 |
Some more pictures... If summer can be back again...
#18 |
Just a dude
Drives: Scion FR-S 2013
Looks great overall with the spats.
#19 |
Drives: White 2013 Scion FR-S
what side skirts are those?
#20 |
Chargespeed style replica side skirt sold by Jon Motoring.
They come in black plastic. I wrapped them into a carbon fiber vinyl.
#21 |
63 Auto Body
Drives: 2013 SCION FR-S WHITEOUT
What are the sides of the front lip being held by? I just got mine and the sides do not come predrilled, so did you drill it or did you use tape?
#22 | |
Take a look closely at your front lip. There is a place especially marked to mount a 3M tape everywhere.
| The Following User Says Thank You to NoFear99 For This Useful Post: | Vic (03-02-2014) |
#23 | |
Drives: Whiteout FRS, Audi A4, 135i (sold)
Jon Motoring only sells one for the BRZ I think. The one for the FRS is nothing like this on, sadly. I want one so bad but I want the cheapest on possible due to horrible roads here.
boooooooooooooooooost
#24 | |
63 Auto Body
I was just thinking of drilling a 1/2" hole to match up with the ones on the corners of the bumper then using a nut, bolt, and washer to hold everything in place. |
#25 | |
I had to reinstall the lip a second time but this time I used something like this with an adhesive surface twice large. http://www.ebay.com/itm/3M-Tape-30mm...ht_4066wt_1239 It is now solid like a rock. No need to drill others holes for extra nuts and bolts. But you can always do it if you want to. It is up to you.
| Password JDM 3 Piece front splitter/Version Select CF Side skirt Paint Matched | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 08-10-2013 07:08 PM |
| FS: Version Select TRD Front Lip Kit | gvan1998 | Exterior Parts (Aero, Lighting, Etc.) | 13 | 06-16-2013 10:33 AM |
| FS: Version Select TRD Front lip painted | gvan1998 | Exterior Parts (Aero, Lighting, Etc.) | 7 | 06-04-2013 10:56 AM |
| FS: Version Select TRD Front lip Painted | gvan1998 | Mid-Atlantic | 2 | 06-02-2013 11:37 PM |
| FS: Version Select TRD Front lip painted | gvan1998 | NY / NJ / CT / PA | 4 | 06-02-2013 11:32 PM |
