Northwest AK, ID, OR, WA
Old 02-25-2014, 07:21 PM   #29
xia
Drives: 1995 Supra TT & 2013 FRS
Originally Posted by Sitha@ft86club View Post
haha what would you put in this? a ls1
Oh i dont know...beams, k20, 2jz, alot of options when you have spare cash laying around lol.
xia is offline
The Following User Says Thank You to xia For This Useful Post:
Sitha@ft86club (02-25-2014)
Old 02-25-2014, 07:25 PM   #30
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Subscribed. I think there is more to this story than OP owns up to.
zinzan is offline
The Following 4 Users Say Thank You to zinzan For This Useful Post:
lantsalot (02-28-2014), Marchy (02-26-2014), Sitha@ft86club (02-25-2014), xia (02-25-2014)
Old 02-25-2014, 07:27 PM   #31
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Originally Posted by ilpad View Post
Dont feel too bad...
We ALL have done stupid shit, its a life thing.
yep. usually is.
ilpad is offline
The Following User Says Thank You to ilpad For This Useful Post:
Old 02-25-2014, 07:28 PM   #32
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by Marchy View Post
yeah but you've gone FI and are putting more strain on your engine. its overkill on a stock NA car that see's daily driver duties.
Since I got free 5 oil changes every 3k was added insurance. Esp with how I drive. It's not about how many miles you go its about how you drove those miles. Oil isn't fairy dust.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline
The Following User Says Thank You to NickFRS For This Useful Post:
Old 02-25-2014, 07:33 PM   #33
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Let's approach this in a logical sense...
If your car has no oil -- where did the oil go?
This means:
1) Dealer didn't put enough oil.
2) Car burned it all.
3) Oil Leaked Out.
If 1 -- Dealer is held responsible. You paid them, they neglected to properly perform service.
If 2 -- If the car is burning oil, this is a significant amount of oil being burned. There is an another underlying problem.
If 3 -- The oil leaked out from the drain plug -- Again the Dealer is at fault. If the oil is leaking out of the seal -- there is an underlying problem.
Aside from that:
If your car doesn't have enough oil -- you don't mess up a "bearing". You seize the entire engine. Meaning the entire block melts together.
Also -- Who gave you the quote of 6-8k?
Check your work order. If you authorized the 6000-8000 estimated repair -- I'm afraid there's nothing you can do.
If your work order says "Repair under warranty" then you should be good.
If your work order currently says "0.00" and it doesn't mention anything about the warranty, they are just currently "tearing down the car" for inspection. As long as you didn't authorize the repair, you won't need to be forking out 6-8k.
If they find out this isn't under warranty, you'll be paying for the tear down/inspection.
If this is the case -- I would tell them to leave everything and to stop touching your car. Tow the car to another mechanic. Dealers always charge more. Tow it to a Subaru Specialist.
N1rve is offline
The Following 5 Users Say Thank You to N1rve For This Useful Post:
ilpad (02-25-2014), kavanagh (02-26-2014), Marchy (02-26-2014), SirBrass (02-26-2014), Sitha@ft86club (02-25-2014)
Old 02-25-2014, 07:50 PM   #34
This means:
3) Oil Leaked Out.
Aside from that:
@Sitha@ft86club, this is a good post from @N1rve ..... I suggest you read it carefully.
In my mind, at least, there is something in your story that is either misleading, missing or I'm just not understanding.
Has that dealership done all of the maintenance work on your car .. ??
Why do they suspect the engine gave out .. ??
Let's put that with N1rve's questions/comments and go from there....
humfrz is offline
Old 02-25-2014, 07:59 PM   #35
Sitha@ft86club
Drives: swp gt86 scion
No, I am not hiding anything I already admitted to running it bone dry. (My knowledge about a week) I did drive to Bellingham and back to Federal Way the week before. Because my girlfriend goes to school in Bellingham and her family lives in Fedway, that probably did play a downfall to this.
I own a automatic FRS. I usually drive it in the manual paddle shift mode. What had happen was I down shifted into 2nd gear and the next thing I know my engine is "CLANKING" like think of a clank noise.
@thehapaone not sure if i blew engine, just the bearing
@bkblitzed i am hoping this is what is going to happen to the boy 2 fingers cross, can you give me a little more of an explanation about this situation? was the women of a caucasion decent?
Sitha@ft86club is offline
Old 02-25-2014, 08:05 PM   #36
Sitha@ft86club
@xia a k20 in a frs, are you being serious
Old 02-25-2014, 08:19 PM   #37
sithasatsucks
Drives: ALL STOCK
time to change forums...
http://honda-tech.com/forumdisplay.php?f=85
sithasatsucks is offline
The Following 2 Users Say Thank You to sithasatsucks For This Useful Post:
Marchy (02-26-2014), Touge_ninja (02-25-2014)
Old 02-25-2014, 08:34 PM   #38
Luis_GT
You know... there's a nice booklet in the glove compartment called an owners manual... if you had read that, it clearly says that the Oil interval is 7500 miles.
Luis_GT is offline
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
Marchy (02-26-2014), sklimo (02-26-2014)
Old 02-25-2014, 08:38 PM   #39
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I don't think it has to do with the length between oil changes...going 2000 or 10000 doesn't matter since the problem was caused by an empty oil reservoir
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline
Old 02-25-2014, 08:41 PM   #40
Luis_GT
I must be old fashion, I check the dipstick every once in a while to make sure the car has the adequate ammount of oil...
I even checked it after the dealer did my oil change.
Luis_GT is offline
Old 02-25-2014, 08:46 PM   #41
thehapaone
Wasian Ninja
thehapaone's Avatar
I feel you I check it all the time....not everyone is a gearhead some people just expect a car to work
Old 02-25-2014, 08:49 PM   #42
Luis_GT
But they should at least read the fucking manual... my dealer tried to tell me that the oil change was 10K, It wasn't till I bitched and showed them the manual that they changed the oil coupons to 7500 (wish I hadn't said yes to that gimmick, but they where so damn insistent and I wanted my car now!)
Luis_GT is offline
Time to buy a new frs? Timmy_Jones Scion FR-S / Toyota 86 GT86 General Forum 47 03-01-2014 05:52 PM
Your first time? dem00n Off-Topic Lounge [WARNING: NO POLITICS] 52 09-05-2013 12:25 PM
Is now the right time to get a FR-S? noobcake Scion FR-S / Toyota 86 GT86 General Forum 19 07-26-2013 10:20 AM
Time to put away the BRZ? DeepHunta BRZ First-Gen (2012+) — General Topics 96 10-29-2012 01:00 PM
About time Touge_ninja Scion FR-S / Toyota 86 GT86 General Forum 12 08-21-2012 05:08 AM
