Old 02-25-2014, 01:19 PM   #3641
ntaphse
Drives: beater
Originally Posted by choi0706 View Post
serrated .. they resist from loosening..
http://www.mcmaster.com/#90074a108/=qu6ev7
Bigger head might not fit anywhere there's a counterbore.
ntaphse is offline   Reply With Quote
Old 02-25-2014, 01:31 PM   #3642
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
@xxscaxx
After running it hard, the blower is still just warm to the touch. 13500 is the p/n from Thermotec. For the BRZ, I’d put some on the very bottom face of the manifold and the runners. The next effective place would be the bottom facing of the nosedrive casting and the inlet casting.
I am not sure I would do that.. their website says it is for radiant heat. Most of the heat that is getting into the manifold is caused by conduction and convection. Not to mention most of the heat is caused by the blower itself. Aluminum does a pretty good job at conducting (or dissipating in this case because the heat is coming from the blower) heat. Put that stuff around it and it will likely hold more heat in assuming the heat transfer coefficient is less than the aluminum.
stand in a house temperature controlled at 70 F in front of a window on a really sunny day.. you will get pretty warm in the sunlight. now wrap yourself in that termotech stuff.. it'll do its job and you will feel 70 F again.. now stand in the 70 F house in the shade and wrap yourself in that thermotech stuff.. nothing happens.. its only good for radiant heat..
sure there is some radiant heat in the engine bay.. but like I said. MOST of it is coming from conduction from the engine heads through the manifold and convection by being trapped in a closed room with a bunch of hot stuff and hot air.. oh and the fact that when you compress air it gets SUPER HOT (THE BIG PROBLEM).
[ame="http://youtu.be/-MMGzeA1TXo"]http://youtu.be/-MMGzeA1TXo[/ame]
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
xxscaxx (02-25-2014)
Old 02-25-2014, 03:18 PM   #3643
olorin
olorin's Avatar
Drives: GBS Premium
Is there any trick to removing the pulley?
Edit: Never mind. Red Loctite made it a real bitch to get off.
olorin is offline   Reply With Quote
Old 02-25-2014, 04:20 PM   #3644
xjohnx
Grip>Slip
xjohnx's Avatar
False alarm, still looking. Definitely not the PVC after removing and zip tying that into place.
Calum (02-26-2014)
Old 02-25-2014, 04:26 PM   #3645
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by DeliciousTuning View Post
Completely agree but HG wants to give comparison modes out due to too many customers getting hurt feelings after getting tuned or running baseline pulls. LOL
Cheers,
William Knose
Bill please put your car on a DynoJet so we can see what it makes when you are done tweaking
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-25-2014, 07:39 PM   #3646
20firestorm13
Drives: 2017 Halo Toyota 86
Anyone running a 70mm pulley? How are you getting more then 10lbs of boost? Are you using a boost controller?
20firestorm13 is offline   Reply With Quote
Old 02-25-2014, 07:47 PM   #3647
evan
Drives: fr-s
Many of us are. I'm seeing almost 12lbs.
Sent from my Nexus Five, I'm Alive!
evan is offline   Reply With Quote
Old 02-25-2014, 08:17 PM   #3648
NickFRS
Drives: 2013 Asphalt FRS
This. Even the 75 pulls like 6-8lb's I think. Evan you have a upgraded bar sensor? I'm thinking about ordering one today. Don't know how that works with BRZedit.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 02-25-2014, 08:19 PM   #3649
evan
Drives: fr-s
I'm having a 3 bar omni put in this week. It just needs to be calibrated/scaled in the tune with BRZedit. Talk to Erich at PRE. He's doing the work
Old 02-25-2014, 08:37 PM   #3650
Gen
Drives: Scion FR-S
Originally Posted by Powersfrs View Post
Gotcha! So I thought the 70 mm e85 tune was good for 300whp dyno jet
That particular dyno will read <210 HP with an FBM or Avo kit on 91. It's pretty brutal.
Gen is offline   Reply With Quote
Old 02-25-2014, 09:07 PM   #3651
20firestorm13
Did you use a boost controller? What kind? Right now I'm only able to get around 10
Old 02-25-2014, 09:12 PM   #3652
calispec
calispec's Avatar
You can't use a boost controller on a supercharger. Depending on altitude, exhaust, can timing etc there can be differences in max pressure.
Edit: you can't use a boost controller on a twin screw supercharger. Centrifugal.. That's a different story.
Also. Boost controllers will only limit boost. Not increase it.
www.GT86Mounts.com
evan (02-25-2014)
Old 02-25-2014, 09:26 PM   #3653
NickFRS
My car will be in Tuesday for my tune to be re-done by Erich. Where are you getting the 3bar from? Might order it so I can pop it in then. Looking forwards to you input once your car is done this week.
This one?
http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 02-25-2014, 11:29 PM   #3654
evan
Drives: fr-s
No
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
