Old 02-24-2014, 12:03 PM   #1
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Clutch discussion
Now that my car is boosted, I'm going to look into upgrading the clutch. I think I want to go with an organic clutch to keep it close to OEM in feel, and I don't have any plans to go over 300whp.
Right now I'm considering the AVO Stage 1 or the Exedy Stage 1. I've read that their rated torque holding capabilities are in the low 200's, but people have put much more power through them without any troubles. My main concern is driveability.
Any other suggestions?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 02-25-2014, 09:03 AM   #2
South Bend Clutch
South Bend Clutch's Avatar
Drives: 350z
I see people are stammering to give you a response... I'll just leave this here for ya
http://www.dxdracingclutches.com/
South Bend Clutch is offline   Reply With Quote
Old 02-25-2014, 09:16 AM   #3
Dinko
Drives: Scion FRS
I have the Exedy stage 1 clutch. Im boosted with 415whp/314wtq and have had no issues at all. However its going to have a different feel than stock. The peddle feel is lighter. Either way tho, its a good idea to upgrade the clutch if you are boosted!
Dinko is offline   Reply With Quote
The Following User Says Thank You to Dinko For This Useful Post:
otterpop (07-20-2015)
Old 02-25-2014, 09:22 AM   #4
JerryMichaels7
Drives: Whiteout FRS
Just gonna say go with the exedy stage one...oem feel and high underated on holding power
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-25-2014, 09:33 AM   #5
protpibe
protpibe's Avatar
That was the info I was looking for. The act was on the radar too, bit if the exedy will take 300, then I can just go with it
Sent from my HTC One using Tapatalk
Old 02-25-2014, 09:44 AM   #6
protpibe
protpibe's Avatar
Thanks for the info!
Does that come with a flywheel?
Old 02-25-2014, 10:35 AM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I just searched the word "clutch" on the Engine and Turbo sections...
http://www.ft86club.com/forums/showt...ghlight=clutch
http://www.ft86club.com/forums/showthread.php?t=29863
http://www.ft86club.com/forums/showthread.php?t=15850
http://www.ft86club.com/forums/showthread.php?t=20537
Old 02-25-2014, 02:06 PM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
this is a tad irrelevant to this but i had a exedy stg 1 on my civic years ago. loved the driveability but i boosted it up to 280whp on a 1.6l dohc. blew the disc springs out with only 3000miles on it
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-25-2014, 03:26 PM   #9
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Irrelevant indeed, a stage 1 on a civic is not at all comparable to a stage 1 on a frs/brz. Cross platform comparisons really don't work like that :P
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 02-28-2014, 12:10 AM   #10
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
So exedy stage 1 will hold how much tq?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 02-28-2014, 12:56 AM   #11
Zach3794
Rated at next to nothing, limit apparently hasn't been found in real world applications though. Apparently held up fine on ptuning's car at 400whp/300tq. This makes it perfect for me as my car is just a supercharged daily :P
Old 02-28-2014, 02:17 AM   #12
TreHarriss13
Drives: 2013 Scion FR-S & 1995 Nissan S14
Spec Stage 3. Good for 350+
TreHarriss13 is offline   Reply With Quote
Old 02-28-2014, 11:17 AM   #13
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Although the Exedy Stage 1 clutch is rated at 203tq @ wheels it has shown to last up until 320tq before you see any slip. The AVO Organic Clutch holds about the same maybe a bit more. While both kits give you a clutch pedal feel close to OEM.
DesertFrs is offline   Reply With Quote
Old 02-28-2014, 05:47 PM   #14
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Personally not a fan of Spec on ANY application I have used them on. I'm not typically one to bash on brands but i did my due diligence with them trying to give them a chance to redeem their products on several vehicle platforms and they always land as least favorite in feel, quality, hold ratings, and cost from my personal use of them.
I currently have the ACT street clutch on mine (just trying it out) and as far as street its near identical to stock minus a heavier clutch pedal. It can get slightly chattery if heated but that's not a common occurrence. Even when it does its very mild. It grabs and goes without any slip.
I will be installing an Exedy on another BRZ in 2 weeks so obviously I feel they have a good product as well.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
