Old 10-23-2012, 10:16 PM   #1
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Clutch..
I'm eyeballing a few supercharger/turbo options, Exhaust, Tune, which would put me around 300 HP, +/- 25HP.
This will put me in a position to require a upgraded clutch... What are the better options for clutch on Boxer's, and other then being able to handle the more power what do these performance clutches feel like when compared to a stock..
RedRocket is offline   Reply With Quote
Old 10-23-2012, 10:21 PM   #2
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
As far as i have seen, there is a "ONE-OFF" Exedy clutch that AP is using. And there are several stages of the Clutch Masters. The more clamping force, the more TQ it will hold and with that, it means faster and harder engagement.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-23-2012, 10:28 PM   #3
Pete
Pete's Avatar
Drives: 22 BRZ
I had the same question, once I settle on a FI solution. (IE after SEMA)
Pete is offline   Reply With Quote
Old 10-23-2012, 10:52 PM   #4
gmookher
fx300/400?
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
usptwins (10-23-2012)
Old 10-23-2012, 11:13 PM   #5
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Personally I like Spec clutches.
kmbkk is offline   Reply With Quote
Old 10-23-2012, 11:14 PM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why? (genuinely asking)
Sent from my HTC One X
Old 10-23-2012, 11:29 PM   #7
subatoy
subatoy's Avatar
Drives: subatoy
I hate staged kits! the clutch pedal gets really hard and it's a pain to drive smoothly or comfy. I seriously had a bigger left leg than my right left after my WRX.
subatoy is offline   Reply With Quote
Old 10-23-2012, 11:36 PM   #8
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I had one put in my GSX and it worked really well. It had a good feel and engagement. I also put and ACT street disc setup in my EVO. It was harder to shift and work than stock. Of the two brands I like the Spec better.
The Following User Says Thank You to kmbkk For This Useful Post:
Sportsguy83 (10-24-2012)
Old 10-23-2012, 11:37 PM   #9
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Emailed Across/carbonetic. they should have a carbon blade clutch out for sale in the new year. email said it should be able to hold about 300-350lb/ft using their pressure plate. but thats all i got from them.
here is to hoping that ACT has a Pro-Lite Flywheel at SEMA. 9lbs would be about perfect on this car i think.
FreshFRS is offline   Reply With Quote
The Following User Says Thank You to FreshFRS For This Useful Post:
Old 10-23-2012, 11:41 PM   #10
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Damn, someone definately needs to send them links and dyno vids/sheets of all these turbo/sc kits making more than that and still pushing on stock internals...... Cereal guys....
Old 10-23-2012, 11:49 PM   #11
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
rememeber thats just the blade. they didn't give me anything when i asked about a twin-plate. so i'm betting its in the works.
Old 10-23-2012, 11:51 PM   #12
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
or just a full on race spec. Something that can handle over 500wtq... then we would all be safe with one of those
The Following User Says Thank You to usptwins For This Useful Post:
carbonBLUE (10-24-2012)
Old 10-24-2012, 12:23 AM   #13
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Old 10-24-2012, 12:40 AM   #14
Le86
Drives: Asphalt FR-S
As far as staged kits, you also need to look at sprung or unsprung. Sprung clutches will generally have a similar pedal feel as far as softness/stiffness goes, although engagement may still be harsh/soft depending on which stage you go with. I had a spec stage 3, 6-puck sprung clutch in my 240 and the pedal felt soft, almost like an OEM clutch, however the engagement was incredibly harsh. No room to ride the clutch at all, it was either in or out, no in between.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
Clutch billysangi BRZ First-Gen (2012+) — General Topics 10 06-15-2012 03:29 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
