Old 02-25-2014, 03:14 AM   #1
CSG David
CSG David's Avatar
Desired Wheel Size, Width, Offset - OPINIONS
What are your desired wheel specifications?
Diameter
Width
Offset
Color
The Following User Says Thank You to CSG David For This Useful Post:
ZionsWrath (03-18-2014)
Old 02-25-2014, 03:45 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
17x8.5 +40-45 silver or hyper silver/black
The Following User Says Thank You to ZionsWrath For This Useful Post:
FreshFRS (03-18-2014)
Old 02-25-2014, 03:48 AM   #3
DAEMANO
Time Traveller
Diameter - 17"
Width - 8.25 - 8.50
Offset - 35
Color - Satin Black, Brushed Bronze, Brushed Gold, Brushed Alloy, Polished Alloy
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 02-25-2014, 04:53 AM   #4
YDNA
YDNA's Avatar
Drives: Raven FR-S
17x9.5+25/10. Color depends on wheels, but maybe mag blue if it doesnt have much lip, but a bronze lip black face if there is lip.. or vice versa.
YDNA is offline   Reply With Quote
The Following User Says Thank You to YDNA For This Useful Post:
Old 02-25-2014, 04:02 PM   #5
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
18x9.5 +45 Flat Gold
The Following User Says Thank You to switchlanez For This Useful Post:
Old 02-25-2014, 05:11 PM   #6
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
17 x 8-8.5 +45(or whatever clears AP Racing sprint kit)
black/gunmetal/dark chrome
weight - under 17 lbs
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
ZionsWrath (02-25-2014)
Old 02-25-2014, 05:22 PM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
16x7s square (performance oriented) with a +40ish offset, and some zany color.
I'm close with my 16x7 +46 TE37s + spacer but I don't think I like the bronze...
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
Old 02-25-2014, 05:32 PM   #8
JerryMichaels7
Drives: Whiteout FRS
what happened to the other thread?
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
The Following User Says Thank You to JerryMichaels7 For This Useful Post:
Old 02-25-2014, 05:49 PM   #9
CSG David
CSG David's Avatar
It got moved to the commercial section without notification. I made a new thread since it would eventually be buried in the stack of advertisement posts.
Old 02-25-2014, 05:59 PM   #10
switchlanez
Maybe you can ask one of the friendly mods/admins to move relevant posts from that thread over to this thread so everyone can see what's been posted.
Old 02-25-2014, 06:10 PM   #11
CSG David
CSG David's Avatar
Deleted the thread to just provide a clean slate. I have some ideas why it may have been moved, but, I prefer to have a thread meant for nice wheel sizes. I'm pretty sure this will provide a place to provide opinions and ideas that aren't constrained by what is already available on the market.
Old 02-25-2014, 06:37 PM   #12
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
18x9 18x9.5 or 18x10... +35 to +38 range.
I say 18's because there's a wider selection of tires. 285/30r18 Direzza Z2's would be the shit wrapped on 18x9.5 +38 wheels.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
Old 02-25-2014, 07:02 PM   #13
CSG David
CSG David's Avatar
With 285, a 18x11 would look better.
Old 02-26-2014, 11:29 AM   #14
hmong337
Emperor JDM
hmong337's Avatar
For sure! Problem now is, you're going to need coilovers and flares or some kind of wbk to cover the wheels. Pretty extreme with a 18x11. Too much for me. However, you can get away with a 285 wrapped on 9.5's. But yea, 255's are as much as I probably need anyways. I'm a meaty functional tire lover
Evasive's riding on 18x10's. Probably way more than what everybody needs.
http://motormavens.net/threads/evasi...mate-frs.1744/
But for the most of us, a 17x9, 18x9, or 18x9.5 is plenty. Heck, even the stock wheels are enough for many!
I say it's all personal choice and what you're going to be using your rims for. For example, this season, I'll eventually get around to wrapping my OEM wheels with rs3's. Should be plenty for a stock everything, but tire, setup.
Pure performance and still non-turbo like the most of us, I'll take a crack and say the best budget lightweight setup would be 17x9 with 245's or 255's. Hard to beat the Enkei's. 18x9 would probably be next. 18x9.5 is sweet too! Hard to say. Depends on what market you want to capture.
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
235/40/18 on 8.5 rim width, all around. recommended offset? terenshu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-05-2013 10:27 AM
Need Opinions on Wheel Offset (+35 or +15) for Flush Fitment Dustin2JZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-30-2013 08:33 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
