Old 01-23-2014, 12:17 AM   #43
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by NJA View Post
Good work, love how everything was done on jack stands
Thanks! It wasn't as tough as I thought it would be on the ground. In fact, it worked quite well for me when I needed the ground for leverage or to rest my arms from holding the wrench up. I certainly got some intimate close time with the bottom of my car and the floor LOL. But hey, got it done without much hassle. I would do it all over again, it was a blast.
Originally Posted by midnight23 View Post
Around what time will you be going? I'll definitely come check it out before I head to work!
PMed :-) Can't wait to meet the other 86ers.
rb6freak is offline   Reply With Quote
Old 01-23-2014, 09:27 AM   #44
bjun
bjun's Avatar
Drives: white premium brz M/T
That looks awesome man!
bjun is offline   Reply With Quote
Old 01-28-2014, 09:29 PM   #45
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
She had a photoshoot yesterday, enjoy =)
Old 02-11-2014, 03:33 AM   #46
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
2014-02
Small update. Installed PTuning rear adjustable sway bar and a front lip. Next I will be putting in a wideband sensor with gauge - AEM. Following that I will finally be getting a complete tune, dyno pulls and some track time.
Exhaust sits way low.
Adjustable rear sway bar vs stock.
Rear sway bar installed.
Front lip, just before install.
Old 02-11-2014, 05:04 AM   #47
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Looking good, any way to raise the mid section of the exhaust?
Build Thread
Instagram
Old 02-11-2014, 11:37 AM   #48
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
It's not that low. See pic below. Keep in mind this is a 3" exhaust system. You can only move it up so far. The factory exhaust tunnel was designed for a 2.25" exhaust system. We tucked it up as high as possible without compromising the flow by having too may tight bends as well as having the exhaust system contact the undercarriage when going over bumpy roads.
Mrc@ptuning is offline   Reply With Quote
Old 02-11-2014, 11:38 AM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Man I love this car. Well done.
Old 02-11-2014, 02:36 PM   #50
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
No. The exhaust is the lowest part on the car. It's not like its dragging, MrC is right. But I do scratch the last clamp on some bumps. There is just no way around that because it's far forward from the wheels and not even asain'ing the steep bumps is enough. Its flexible so I'm not really worried too much. Although 100 scratches later that clamp might be dust. I'll probably keep a spare for safe keeping.
Thanks. Some credit is owed your way too, I've read many of your posts - helpful ones like this AEM gauge that I am installing. Still figuring out the wiring for brightness and such. So thank you too :-)
Old 02-11-2014, 02:39 PM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I never got that working on mine. I was too lazy to go back and fix it after trying a couple wires on the dimmer switch instead of going for the ILL off the radio harness. It really isn't needed, but the RPM wire is definitely worth hooking up for your datalogs.
Old 02-25-2014, 02:47 AM   #52
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Did you think I was done? I'm just getting started ;-)
I couldn't stand how reflective these mud flaps were at night with headlights. They attract too much attention, so I de-glossed them.
Greddy hood dampers arrived in the mail. So worth it.
AEM wideband gauge install process started.
Hose for the boost gauge routed.
Removed the battery and noticed my employer name. Didn't know they made the battery for the twins.
Finally found good use for the sound generator port and rubber grommet. Routed the Bosch o2 sensor wiring through here for the AEM gauge.
After wiring the Bosch o2 sensor, I noticed the PTuning etching on the turbo that I didn't even see when I first installed it. I must have been too excited during the install process. Anyways, it reminds me of MV Agusta and how they make beautiful parts that only a mechanic will see when disassembling.
Tapping into source for auto dim feature.
Tapping into the tach signal.
And power.
The o2 sensor wire has thermal wrap on it already, but I took extra precautions by wrapping it in additional thermal reflective wrap. Its far enough from the turbo, but better safe than sorry.
All wired up and ready for test.
Old 02-25-2014, 03:03 AM   #53
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
Really love that turbo turbo kit, nice work.
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 02-25-2014, 03:31 AM   #54
raven1231
Beautiful car man! Love the Pruning kit
Old 02-25-2014, 10:05 AM   #55
SnapOv3st3r
Drives: 400whp Scion tC
Sick. A+
SnapOv3st3r is offline   Reply With Quote
Old 02-25-2014, 10:28 AM   #56
charged86
charged86's Avatar
excellent work beautiful @rb6freak
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
My trip to FBM - FBM Premium Turbo Kit build brzaapi Forced Induction 170 11-12-2013 06:04 PM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 09:01 AM
Just wanted to show off my turbo build sw20kosh Forced Induction 5 04-01-2013 03:16 PM
Turbo engine build, and parts No Limit Motorsport Forced Induction 30 12-11-2012 07:32 PM
